MOX-like crossover and discrete opamp group buy
I have completed mine a while ago but only now have I finally redesigned my amp chain. I have used the MOX now for a few weeks, a real blessing for the flexibility and I like the sound. I currently use OPA2134 with it.
Be warned though, you do need a clear understanding of crossover issues and ideally, of crossover topologies (Sallen Key) to use it properly.
If you use more than 2 channels and more than 12 dB/oct crossovers, you will also have several MOXes wired in series/parallel, as in my case, and the great flexibility of the MOX IMO then makes it a bit cumbersome to wire up and to use. Read, you'll have to sit for a while and ponder which jumper does what and where did that wire go.
But you will find the endless play with possibility very rewarding! You will try out things in a matter of days, which would have taken you months in passive crossover, or which you couldn't have done at all.
They were on Tiroth's site, I think. I should have them somewhere, and a truckload of the small pcb's. Didn't order the 2SK389's at the time (and punching myself for it now).
I'll see if I can dig something up.
Edit:
Well, that was quick, I found the files, PM me your e-mail address and I'll send them to you.
Joined 2000
Configuration(s)?
Hi Guys,
Been staring at my boards over the past couple of nights trying to decided what to do. I decided that since the design is so modular, I would just build 2out of 6 boards I have to learn the ins and outs as best as possible.
I do have a questions about markings on the board.
Each section of the HP and LP has 2 sections for selecting the frequency.
These are lableled LP(HP)_FRQ_1 and LP(HP)_FRQ_2. Both sections range from 25 to 200. Are these FREQ settings for each half of the dual opamp?
There is a jumps for 1st order. If using only 1st order, is the FREQ set by LP(HP)_FRQ_1 only? Is LP(HP)_FRQ_2 left open?
If you could give an example of these, it would be helpful.
