Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans
Thanks guys.
Looks like I should head over to the fish market. :)
Dennis,
Please know that I do things in a very limited and subjective manner. In other words, not so organized. :D
You see that random THF-51 acquisition is risky for DEFiSIT, except for the forced bias circuit.
@ Mighty Man
What I cheked is below and I forgot what condition I did. Maybe one of 28V 2A / 31V 2A / 32V 3A. I was dreaming of big tower amp driving my Dynaudio.
But you can see the Vgs are not so jumpy, but too low. :(:(
Official Court Jester
Joined 2003
@ Dennis
well , I believe things are much easier as I made them .... even if THF I've put in two channels are just similar (not identical) , and those pentodes down (IRFP9240) are even less similar , I didn't found some difference in THD measurements of two channels
however , I'm much often Plonker than Genius ...... even if Papa insist calling me that
(now I just need to remember how exactly is he calling me - Genius or Plonker)
:rofl:
Joined 2003
Dennis,
@ Mighty Man
counting on fact that all 3 tables were made with same goal in mind , we can count on fact that thety're comparable
from that I can see that 2SK182S is having too big Ugs ...folding on other side of IRFP9240 Ugs , so wee need to fill gap between sources , to have gates in same point
while with 2SK180 - I see Ugs is even smaller than THF , so opto bjt will have even more space to be put in
from that point of view , SissySIT is most probablydoable with 2SK180 , while possible difference in sound vs. THF iteration , I can't predict ...... probably not much , but that only real test can show us
OK ZM, here goes the random pics.
2SK82-IRFP9240 with 0.6 ohms Source R
2SK82-IRFP9240 with no Source R CCS from 12V batteries to the 100 ohms gate resistor
THF-51S-IRFP9240, same as above
THF-51S-IRFP9240 with CCS from regulated supplies to the 100 ohms gate resistor - hum
THF-51S-IRFP9240 with separate bias from regulated supply to the 100 ohms gate resistor - still hum
The SIT-3 serving my curiosity
Chassis .... dear old F2 (hardcore porn right?):devilr::devilr:
YBA slaughtered into KORG B1. This YBA circuit is just ridiculous and I punished ..:devilr::devilr:
Thank you folks,
It will be most probably simple 2SK82 with 0.6 ohms source R, provided the speakers are sensitive enough for the near field listening.
What I see about my friend is life goes on whatever happens. I am in a risk to be his robot arms to do this and that. :D:D
Joined 2003
did you tried adding it up , having output from P source ?
as I said :
I had a dream ............ no , wrong start :rofl:
I had a big dilemma last night - trying to nest THF51-S in SEF amp concept , where upper part is having source resistors and optocoupler (biasing main device ) is fed on them ........ or to nest it in Babelfish M25 concept , so no source resistors and where optocoupler is fed from Hall current sensing chips in rails
first one is having lesser THD , accordining to sims ;
second one is having greater THD, again according to sims , but higher level of purity , rawness , call it whatever you want ..... sans source resistors it is closer to Papa's most wakoo one - DEFiSIT amp
so , this morning decided to try it thrown in Babelfish M25 cradle ......
