Use PSU100 for F100 there is short circuit protect.
Thanks Mile..
I'll sure try this on tomorrow...
vargasmongo3435
Hello.
You have already finished amplifier HV23 titan? I am very interested to build it. Lukáš.
I'll check if I still got it I forgot where I place the file on one of my hard disk I let you know sir
Juan
I found the file maybe is a too crazy idea but can be done if you want I'll send you the files by e-mail I do have the Sprint file and I can send it to you no problem here is the image of the Apex HV23 I have no done this project cause I have way too many projects that I have not complete yet I also have the Apex HV23 too if you want the Sprint file too here is my e-mail vargasmongo@gmail.com
Juan
Juan
Wow very nice, e-mail sent. dimensions PCB?
sure thing sir I'll do that now
is quite a large PCB is size: 366 mm x 100 mm you can modified if you want to
Juan
okay sir. size is good. Thank you.sure thing sir I'll do that now
Juan
hi mr mile
i want make hv250 ampli for my subwoofer
my power supply is +-50v DC and 10A
how much ampli power in +-50v?
how much maximum voltage on 4ohm load?
i dont find bd243 and bd244 in my local city.can i replace them to tip31c-32c??
thanks from Pozdrav for pcb
respectfully
respectfully
hi mr mile
respectfully
With +/-50V power will be 200W/4R... you can use TIP31C/32C.
mr mile
in your opinion which one ampli is better for subwoofer ??
hv250 or hv23 or hv350?
which one scheme is newer?
i really do not know which one is proper for me
im confused!
please guid me
my subwoofer is w311 pioneer and power supply voltage is +-50v 10A
excuse me for many questions
respectfully
im confused!
please guid me
respectfully
mr mile
im confused!
please guid me
respectfully
Go to HV23
thanks
hv23 is class AB amp??
how much hv23 efficiency??
respectfully
70%, go to D200 if you want over 90%
d200 is good amplis and i like it70%, go to D200 if you want over 90%
but my power supply is +-50v max
how much d200 power in this voltage?
Do the arithmetic.d200 is good amplis and i like it
Do the arithmetic.
I think his way is calculated:
50v(my voltage)*0.9(efficiency)=45
V*V/R=45*45/4~500
means 500w on 4ohm speaker maximum with +-50v
is it right?
respectfully
45v/1.414=31.8No,
P=U^2/R. U is Vac output, regardless of efficiency
31.8*31.8/4~250w
250w power on 4ohm speaker
i think it is right
- MOSFET Amplifier IRFP240/IRFP9240
