Wow... Your pet rock really has grown since the last time we saw it!
I have a feeling a lot of these snake oils are simply banking on the placebo effect. Other than that, it should be that the shapes of certain "devices" might break up standing waves, or change how quickly certain reflections get to the listener. Which very well could improve SQ. And it could be that breaking down these standing waves and such is amplified by the placebo effect. Regardless, I don't think most of these "devices" are worth the amount they are advertised for. But then again, most other "art" doesn't seem to fit the bill for me either...
I read, but cannot comment. And so it goes.
i wish you would. From wikipedia:
While performing experiments, scientists may have a preference for one outcome over another, and so it is important to ensure that science as a whole can eliminate this bias.[28][29] This can be achieved by careful experimental design, transparency, and a thorough peer review process of the experimental results as well as any conclusions.[30][31] After the results of an experiment are announced or published, it is normal practice for independent researchers to double-check how the research was performed, and to follow up by performing similar experiments to determine how dependable the results might be.[32]
the non transparency is why science minded folks generally think of bybee and most of high-end audio as snake oil.
I admit that the box probably has a Crystal oscillator in it at some unknown frequency. But what is up with the other lumps of rose quartz, Quantum harmonization? Lets say the oscillator is set at 37.63Khz, the internal resonances of a lump of whole quartz would be in the Mhz range if they were very thin, the ones he is holding in the article are squares. You're going to need a hammer to make those "ring". Also with a Q in the 100,000 to 10,000,000 range you need to hit the sweet spot very very very very^10 precisely.
They went out of favor in the 70's. I think they put the fire of the music out.
Too bad they didn't last until the early digital era. Those dihydrogen monoxide cables could have made that early digital music sound sooooo liquid!
Sounds more like the monster cable phenomenon.
Spending money on something makes you think it will make an improvement. and your brain supplies the improvement for you.
Sort of like the way dating a beautiful woman makes you feel handsome when in fact you're as ugly as a turd and she's only into you for the money.
I think you mean non-repeatability, which means that one time phenomena are not real. So, the birth of the world never happened....
My personal opinion is one of the reasons high end audio is dying is because it is being choked by snake oil. $4K for rocks and a box that plays off some super natural concept--without any form of proof of what it does?
In the REAL world, if you invent something it is up to YOU to provide the burden of proof that it actually works! It is not up to the world to buy your junk and prove to themselves. If it works, it can be tested and proven that it does. If I get traditional audiofool BS language, it is fraud until proven otherwise.
I don't buy things that the burden of proof is on the buyer--it is on the seller and will always be.
Who want to buy these fuel line magnets that alter the molecular structure of fuel to improve your gas mileage by 25%. If, after 5 years of use, you are not completely satisfied you can have your money back! What do you have to lose?
Send $500 to
Magnoline
Bank of Nigeria
123 Audiophile St.
Lagos, Nigeria
No, non-repeatability is a totally different thing. So is irreversibility.
What is the chance that the H2 device simple emits a bit of energy at 40kHz? The frequency would be carefully chosen because it excites a little-known unpublished 'resonance' in 'air molecules', and also because cheap 40kHz transducers are readily available and circuits to drive them can be found on the net. Someone with a bat detector may be able to tell us.
No need to ask around, to have an answer to that.
Think about it, it would be some hefty battery, that could supply much beyond a LED for two years, as they claim possible.
So either they are real close to inventing the perpetuity machine, or nothing much is happening.
Magura
WHAT they have a loose change type of video for Lamarckism now? Seriously. Wikipedia says it has been discredited for larger lifeforms.It must really be embarrassing for you that Lamarckism has recently been very clearly and scientifically ---repeatably....shown to be a VERY real thing
What bothers me more than the H2 being sold for a lot of $. Is the fact that a "reputable" audio manufacturer has put it on the market. And that a at least 2 reviewers rate them as having a positive influence. Stereotimes and Positive feedback. Plus men like Norbert Mundorf endorse them according to stereotimes.
most likely
I'd go with #2...
Magura
I'd go with #2...
An audio manufacturer who does not put boring stuff like technical data on his website. For most equipment, all you get is a picture. His explanation goes like this (thanks to Google translate):Bas Horneman said:Is the fact that a "reputable" audio manufacturer has put it on the market.
If you have browsed through our website and read about to conclude the preface, you might have gained the impression that we keep because of the few technical data are not a lot of instrumentation. Exactly the opposite is the case.
A computerized measuring system is for us a long time has become indispensable tool for development and quality assurance. However, ultimately, its own hearing, if a concept has stock or will be shelved.
Our measurement system is a good tool, the circuits that sound good anyway, again relating to optimize frequency and phase linearity, harmonic distortion and noise ratios. We have a large extent on these pages does not insist on technical data, as frequency response, signal to noise ratio and phase curves for all devices beyond good and evil are, however, far from being alone in a position to describe their sound character.
They laughed at Ohm, Einstein and Chase!
That is Ohm of the now well regarded Ohm's law, Einstein of "Modern" physics (Not the bagel guy) and Chevy Chase who is sometimes quite funny.
Now SY and I differ on the issue of fraud. I think the manufacturers and reviewers are giving honest OPINIONS. He doesn't. There is no reason to attack him or his ability to discern what he hears.
Those folks who have tried magic silly string or whatever and hear a difference are welcome to their opinion. Those who have not listened to it can have an opinion also although even they must recognize it is not based on the claims made. If you have never listened to or measured some of the "ridiculous" claims but dismiss them entirely, then your opinion has less weight.
Now the reason why I pick on magic silly string is because that was one of the early acoustic patents. You stretch two sets of taut metal wires across a room. One set lines up vertically the other horizontally. The wires in each set should be about 18" apart. The sets should be around 1/3 and 2/3 of the length of the room. This serves to "Polarize" the sound in the room and reduce echoes and improve speech recognition. Yes I have seen this in action! So I can comment on the effectiveness with an informed opinion.
Less weight than someone who can spot nonsense when he sees it? You would rather listen to people who spout nonsense? They might not realise it is nonsense, of course; in some cases they may actually believe it.simon7000 said:If you have never listened to or measured some of the "ridiculous" claims but dismiss them entirely, then your opinion has less weight.
If I want to to sell a genuine audio enhancement for, say, $50 to intelligent people then I would expect them to rely on something more substantial than my opinion and an 'explanation' which does not use accepted science (but merely a collection of 'scientific' words and phrases). If, on the other hand, I wanted to sell an item for $250 to gullible people then that is exactly how I would do it. Of course, I have the disadvantage of some knowledge of science.
Those who have tried these items need to realise that their opinion of them may be partly (or wholly) based on the claims made. Dismissal of a clearly false claim is also, at least in part, based on the claim but in a negative sense.
Ohm's law was considered nonsense when he first published, even by the experts!
Every so often nonsense turns into common sense.
It remains there are independent reviewers who perceive a value. I will not be disrespectful of their opinions, even when I do not share them.
Every so often in my career I have encountered issues where the results were quite different than the expectations.
Now the issue of extraordinary claims requiring additional proof is a different issue. But the devices in question could actually change the sound field or one's perception of the sound field via several different methods. So an out of hand dismissal can certainly be your OPINION, but it has less weight than one from someone who at least listens to the devices.
[snip] I think the folks who offer these unusual products and the folks who review them are sincere. So I give them the benefit of the doubt. [snip]...
I have always found it risky to confuse sincerity with facts
jan
- Member Areas
- The Lounge
- More magic stones and hockey pucks
