I have a problem, with my Mesmerize, not sure if it's a ghost, not sure what I am looking for.
Basically, when the system is powered no problem at all. I have 300mV of offset when the system is powered off. This with no connection to anything whatsoever.
The only explanation I have is that there is a capacitor trying to discharge from the output, but the funny thing is that if I shorten the output and then open it again, the 300mV come back.
I am really puzzled. It could be that I have been living with this for years.
Please let me understand.
Thanks,
Davide
Thanks,
Davide
Thanks,
Davide
Maybe something with absolute ground potential? Make it be shorting to ground when off. Is it the pcb with a T arrangement on the output relay that does it already, or one older?
I am not sure about the pcb, but when the system is off, I measure something like 100kohm. I think you are suggesting me a solution. I can add the connections.
D.
Look up close its parts side, use a flash light. Is there a possibility the "T" is missing from upper layer?
Long story short: I AM AN IDIOT !!!
When I assembled the PCB I did con solder all the pins of the relays, so that it would have been easier to remove them if I needed. I did not see that there was a T.
I put my speaker in danger for two years like this, I am surprise I did not destroy them.
Thanks for the help.
D.
D.
D.
NOT an IDIOT!
That was good thinking, it just didn't work out this time, a learning experience for everyone.
No harm, no foul - glad you figured it out.
Rush
They are iphone pictures.
D.
D.
- Mezmerize DCB1 Building Thread
