Mezmerize DCB1 Building Thread
diyAudio Chief Moderator
Joined 2002
Its posted before, but here it is again, the threads are too long to hunt it.
Happy new year with health, good job and enjoyment to everybody.
I need your lights about C8. Can I use 120uf (which I have on hand) instead of 100 ?
I understand that R24/C8 form the start up time delay and for this I'm nearly sure that 120uf is not a problem. I'm not sure how such a change affects "power off".
Joined 2006
No worries. Keep in mind, a 100uf is normally +/- 20% value anyways.
Since photos are never useless in a construction thread let me show you how I implemented the C1/C3 mod.
I left the the pcb holes unused (photo). I left the leads of the 1st and last led leads uncut. I wedged in between these leads the plastic capacitor leads and soldered.
Capacitors are 0,33 uF 250V NOS Siemens MKP.
You remember always well !!!!!!
The 627 was a buffered 10K ALPS with a touch of gain on both IC's (x 1,5 I think) . Recently disassembled to take ALPS for Mezmerize :D (photo).
I was playing it with 2 12V 7Ah batteries. That was were our roads crossed ... I replaced batteries with your shunts with sparkling results. Aaaaa I recently saw your reference to my impressions in the MPP thread. The thread is too long and dense... Did they agree with my impressions ?
I have finished staffing and I have a question before starting tests.
I will reuse an existing psu off board. On board bridge will be omitted but I would like to use the existing pads for local decoupling. What's the minimum capacitance you would advice me to use ?
