Mezmerize DCB1 Building Thread
Hot Rod Mezmerize Level 2 transformer help
Hi All-
I've spent a fair bit of time reading and researching this thread and others so I apologize if this is redundant. I'm planning a build of a Hot Rodded Mezmerize DCB1. This is what I've figured I need to do to reach the 600mA level (level 2)
1. Switch to Mur-820 diodes with a small heat sink
2. Heat sink on the mosfets capable of dissipating 6w/mosfet or 12w per rail
3. I think the PS caps at 35V are ok, but would increase if you though I needed to
4. Transformer--this is where I am really stuck. I don't want to spend a ton of money (around 30$ US or less would be good) and I've found the Triad F-187U as a candidate. Center tapped, 28V, 112VA. I'd love some confirmation that this is right though. Data sheet here. https://system.netsuite.com/core/media/media.nl?id=5841&c=ACCT126831&h=8dbf43d15ce63188d8f9&_xt=.pdf
Sound right? Thanks!
Hi salas,
Did you tried B1 with bs129?
I remember you told me once you had a few to try out when you had the time...
i had a pretty good experience myself with them myself, except that for either noise or distortion in some particular case ( i dont have a scope).
Anyway, it sounded pretty good driving a f4 directtly to 96db bookshelves...
diyAudio Chief Moderator
Joined 2002
I know Andrew. But then its not a DCB1 when Jfets will become Mosfets and then cascoded. Its a classic with its own character and we will retire it only when no longer can find proper Jfets even from Linear Systems. For other differentiated design on its own there are many good ways of course.
I'm not exactly sure how the distortion mechanism work for the dcb1 (i'm no audio expert)...
but isn't 2sk170 and bsp129 Ciss curves pretty similar in their non-linearity?
...though Cgs is not Ciss.
Also, i'm not sure if it's of any help, but....
from my experience, soldering the drain to a small copper interface that i can screw to a heatsink,
2W didn't do any difference to case temp,
2,5W made the device a bit warm to touch
3W was probably a bit too much
So running 25V at 100mA with 2 Ohm or so source resistor is possible.
Joined 2002
They are similar in nonlinearity but that MOSFET has three times more. Statically any device's input capacitance reduces bandwidth the higher the source impedance. Dynamically it increases HF distortion & IMD. Although this can be still moderate for a purpose and the high bias drive can be a reward. Good thing in a follower is that no Miller is reflected to add up.
Life got in the way and I never built my DCB1 but things are stable again and I'm looking to finally getting this thing built! I have a question about internal wiring, and please be kind as I've searched this thread and others and seen many different recommendations.
For the Mez board, there are two signals (L & R) with one return. On the RCA jacks, I'd connect both signals to center, two separate returns and connect those two together on the single return pad on the PCB? If I'm measuring correctly, that's only about a 22-24 AWG hole, no?
For the wires, has anyone just used cat5, twisted pair? The tight twisting should be good for noise rejection, but are they good enough? Would I be better off with some shielded cable? I see many iterations (twisted pair, shielded, single core shielded, etc.) but given the small size of the hole on the PCB, I can't jam too much in there. Would cat5 be OK (assuming things are tightly twisted and the loop between signal and return on the RCA jack is minimal)?
For the return, you can just connect the outer barrel of the RCA jacks together and bring a single wire back to the PCB. I've seen some built where three wires come back from each RCA pair, I've seen other builds where ALL returns are joined together at the chassis and a single wire connects these to the PCB.
A twisted pair from CAT5 wire is PERFECT for signal wiring. I've never used shielded wire for an internal signal run and have never had a problem because of it.
