john curl said:NO, you do not understand. There is a complete paper on this amp in the JAES.
John,
It's often not clear who you address your reply to. If you check the 'quote' button on the post you want to reply to, it helps a lot.
Jan Didden
the mother of all amps
I don't believe that , he merely refined some of RCA's ideas (harry lin 1956) . THAT might be the "mother" of the modern SS amp (single ended ones at least.)
OS
Post #42
Are you deliberately twisting my words?
I said: '...NOT the 'mother of all amps'...
Or was it an oversight?
Jan Didden
OS
Jan Didden
hi,
I think there was an IEEE article too
http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=1162523
and two authors.
örjan
and two authors.
örjan
ostripper said:
Who then ? you ?
Sorry ostripper, it was was just a funny memory about a man called "boloney"
MY post was in no way aimed at you
You should rather ask mr Curl what he means
tinitus said:
is the famous swedish "25watter" from Electrocompany of this origin ?
Swedish?
It’s a Norwegian amplifier
orjan said:hi,
and two authors.
örjan
This paper has the same contents as the AES paper, same authors (Lohstroh and Otala):
Preprint NO. H-6 (R)
AN AUDIO POWER AMPLIFIER FOR ULTIMATE QUALITY REQUIREMENTS
by
Jan Lohstroh and Matti Otala
Philips Research Laboratories
Eindhoven, The Netherlands
PRESENTED AT THE
44th AUDIO ENGINEERING SOCIETY CONVENTION
FEBRUARY 20-22, 1973 - ROTTERDAM
Jan Didden
It is interesting how people apparently connect the terms 'Otala amp' and 'high quality' for no obvious reason (not obvious to me at least).
Otala's amp is NOT the worlds best amp. It isn't even a very good one in spec terms. It was a 'reference design' to show one way to build an amp with low or close to zero TIM.
There are other ways, and now that we understand the real mechanisms of TIM we can build very high feedback, very linear, very low distortion amps that are as free of TIM as anything proposed by Otala.
If, for instance, the PGP would be no better than Otala's low TIM amp, we would have been spinning our wheels for 35 years. Thankfully, that is not the case!
Jan Didden
Jan Didden
Some people just enjoy making stuff up to stir the pot.
From that AES paper:
"The approach chosen is to avoid all apparently “elegant” tricks frequently employed (bootstrapping, positive feedback, distortion compensation, higher feedback for dc than ac, gliding bias etc.)....."
You’d never better even the “Blameless” linearity benchmark with this prescription.
Oh really now, do your homework, do you really think I didnt do any improvements, for instance take the pioneer circuit Os posted, that one is already a very good performer THD wise .003 at 200 w output 20 khz, actually that amp measures a bit better than what is stated on its specsheet, up the loopgain use different compensation scheme and see what you get .
Glen are you still toying with self based amps , I dumped them long ago, was building very low distortion so called Self amps 12 years ago, but not according to Self but John Linsey Hood ideas from 1970s , which is where most of Self s theories comes from. That Pioneer circuit dating from the 80 s measures better and is much faster and clips beautifully than any Self based circuit that you have shown in this forum upto date with a little more than half the parts of your designs. Do you really think you are the only person that can design amps that measure or sound good,
Janneman the PGP is miles ahead of otalla amp, that doesnt mean we cannot improve it, the basics is good, I use higher feedback than otalla, have no case against feedback like some.
homemodder said:[snip]Janneman the PGP is miles ahead of otalla amp, that doesnt mean we cannot improve it, the basics is good, I use higher feedback than otalla, have no case against feedback like some.
Sure, but you said that 'this amp' (the Otala amp) would give 'PGP performance' at half the parts. And with that I take exception.
Jan Didden
homemodder said:Oh really now, do your homework, do you really think I didnt do any improvements, for instance take the pioneer circuit Os posted, that one is already a very good performer THD wise .003 at 200 w output 20 khz, actually that amp measures a bit better than what is stated on its specsheet, up the loopgain use different compensation scheme and see what you get .
More :bs:
That Pioneer circuit isn't an "Otala" amplifier and there is nothing special about the front-end circuit at all. It owes it's linearity to a non-switching output stage and multiple parallel output devices, not to any magic of the "Otala" front-end. As for the linearity and slewrate of some of the circuits I have presented, I guess you haven't been paying a lot of attention.
Also, if you use higher feedback just for one, like you claim, then it is a departure from Otala's design philosophy, which, to reiterate:
This 'Otala' amp was designed over 36 years ago. I bought the prototype from Electrocompaniet and used it as my reference for years, while developing preamps , xovers, etc. It is a wonderful little design, and I own and use one, today. It will sonically beat most better sounding amps. I know this from direct comparison with electrostatic headphones.
john curl said:This 'Otala' amp was designed over 36 years ago. I bought the prototype from Electrocompaniet and used it as my reference for years, while developing preamps , xovers, etc. It is a wonderful little design, and I own and use one, today. It will sonically beat most better sounding amps. I know this from direct comparison with electrostatic headphones.
OK I'll wait, see if anyone else picks it up...
Jan Didden
The real 'secret' behind the success of this design is because it has a 20KHz, open loop bandwidth. I know that many of you will hiss at this, but it is true, nevertheless.
Just yesterday, an engineering colleague, a video engineer, has made a break-though in measurement of PIM in amps of this type. He is getting a patent, so it might be awhile before more will be divulged. I am very happy with this, as it proves what the ear has known all along, and even if Matti Otala could not completely 'prove' it in his lifetime, what he initially was trying to find, has been measured. Hurray!
- Matti Otala - An Amplifier Milestone. Dead or Alive
