padman said:Hi all
Can anyone give advice on how to fit those tiny chip caps?
I'm looking to fit 10k0/0.1% at pos RD21-28, i'm not sure my hand is steady enough to just solder maybe a drop of superglue?
Cheers Ian
Superglue was excellent in this case
rowemeister said:Ray I will be sending you a C2 to test soon. Could be ideal for testing on the 63 or would it be better to test on your main cdp so that you can test properly
That's great! I'm looking forward to it. I have plenty of time beginning from next month, so I can do a good PFM Flea - C2 comparison. I will test it in my SA8400, because that's my best player. Make it a 3.3V 33.8688MHz then, if possible .
That diy pcb looks good by the way
Brent
Thanks, I still know how to do it, even though it's been a while
Half the batch is already sold over the weekend...
Ray
Help!!
I just made a big mistake
For some reason i had stored 100n x7r caps as the part no for 10k 0.1% resistors
I worked on the drivers, servo, Hf amp and controller had a short listen
In the same way as the last player i got over excited and ploughed on fitting what i thought was the 10ks at RD21-28
The player now wont read the disc... I dont want a 2nd dead player i have no test equipment any ideas very welcome...
Ian
Ian
Thanks Ray would this do?
Specifications:
Ranges Best accuracy
DC voltage
200mV, 2V, 20V, 200V, 1000V ±(0.5% of reading + 2digits)
AC voltage
200V, 600V ±(1.2% of reading + 10 digits)
DC current
200µA, 2mA, 20mA, 200mA,10A ±(1.0% of reading + 2 digits)
Resistance
200Ù, 2kÙ,20kÙ, 200kÙ, 2MÙ ±(1.0% of reading + 2 digits)
Diode Test
Transistor Test
Ian
Specifications:
DC voltage
AC voltage
DC current
Resistance
Diode Test
Transistor Test
Ian
padman said:Thanks Ray would this do?
I didn't do anything!? Must be the panic...
- Digital Source
- Marantz CD63 & CD67 mods list
