If you're going to feed it S/PDIF why not put it in a separate box?
If you're putting it inside I reckon it is much better to tap into the I2S inside the player and use a TDA1543 (less jitter).
The I2S in this player is non-OS as the oversampling occurs in the digital filter which is inside the original NPC DAC. Good news.
TDA1543 accepts I2S and TDA1545 accepts EIAJ.
Or why not do both and see which sounds the best!
TDA1543 via I2S would not need a receiver...
Re: noob's blown it again
Hi Lee,
Looking at the schematic, I'd be surprised if you killed anything.
Having said that, do we assume that you're asking means the player's not working?
Thomo said:Hi everyone. I have yet another noob question!
If I stupidly connected the rf signal through coax to the hf side of r501, could it possibly blow the decoder chip?
Lee
Hi Lee,
Thomo said:Yeah it's not working. i did the coax mod and now it won't work. The disc spins up really fast and then stops and that's it.
schematic says i should read 2.5v on pin 8 (hf in) but i read 0v. U183 reads ~5v. I dont think this is right!
Lee.
So you have 5V on the laser side of C505 and 0V on the decoder side of R509?
The HF pins should be floating at half the supply and the cap C505 should block any DC current flowing between the HF amp and the decoder. I'd check all these parts for shorts.
If your HF amp is fried the cap would save the decoder (and vice-versa).
What do you get either side of R505 (HF amp supply)?
Yup.
It seems to be doing exactly that.
4.9v & 5.04v
Thanks for your help Glenn. I think the problem is the hf area. I've measured all resistors but they measure ok. I have replaced the transistors so they should be good. Could it be the caps?
Lee.
Glenn2 said:If you're going to feed it S/PDIF why not put it in a separate box?
Just my point of view. I'd like a one box solution.
At my present skill level I need a complete kit. As long as you keep that limitation in mind I can try anything.
I see where DIY Paradise has a TDA1543 Kit listed but it has SPDIF input as well.
I also see where the much respected Peter Daniel was offering a 1543 kit. AudioSector
I would've really liked to have tried one of Scott Nixon's TubeDAC's but he doesn't offer them in kit form anymore.
Have I missed any other worthy candidates?
Regards,
Dan
dantwomey said:I see where DIY Paradise has a TDA1543 Kit listed but it has SPDIF input as well.
You could get this PCB and just build the right-hand side!
And looking elsewhere on that site, this chap has done it already.
See this.
He shows you what pins to connect to what resistors on the 63 (but 67 will be easy to adapt). You could trace those pins around to the empty component holes on the receive side for your inputs (or bend pins 1,2 and 3 into the air).
I'm tempted to try that myself - I have an old 63 lying around.
See this.
If I want to do an I2S feed directly from the SAA7345 could the solution be as simple as this?
Regards,
Dan
Glenn2 said:
I'm a bit confused by what you've written.
U164 takes the 5V from the 7805 to the DAC analogue and digital.
U200 takes the 5V to the DAC analogue after this point.
If you are using one new supply you need to remove U164 and put back U200. Feed the new supply in at the DAC side of U164.
If you are adding two new supplies, remove both U164 and U200. Insert digital feed at DAC side of U164 and analogue feed at the DAC side of U200.
Ensure U261 and U192 are intact as these feed the digital 5V to the pull-up resistors RD15 and RD16 and also the clock inverter via RD01.
Where have you connected your ground? U203?
Hi Glenn,
I should have been more clear.
My power supply was built with 5 wires coming off it for:
1) DAC clock at RD01
2) DAC digital at RD04
3) DAC analogue at U199
4) Decoder digital at R508
5) Decoder analogue at R511
For my latest test, I just used 2 & 3.
I had connected the ground for the whole power supply board to U170 (but U203 looks like a better option )
BTW I missed out on the EBay CD63
Glenn2 said:But where do we get these TDA1543?
http://www.grandata.co.uk/cgi-bin/s...TEVAR:RANDOM&PAGE=SEARCH&SS=tda1543&TB=A&SX=0
Andy
Glenn2 said:Do they make them in their shed along with these?
I thought TDA1541A was quite rare. Is that why you have your doubts Glen?
Simon
ps - I always have a wee chuckle @ your avatars
Glenn2 said:
Lee - are these regulator fed from the main transformer? Does it work if you put everything back to normal?
No, these are supplied from 1x12v extra tx. The regs are perfect, I have tried them on another circuit and they are good. Everything worked fabulously until the coax mod!
When you say i'm getting dc both sides of the cap, do you mean c505? If so then I think I got it wrong. I'm getting 4.2v on one side and 0v on decoder side.
Lee
- Digital Source
- Marantz CD63 & CD67 mods list
