Its all the same. Yes more fresh air
The only difference is the servo and decoder (which is in one chip in the 67 where its two chips on the 63) and the motor drive ics (which is why there is an extra 5v reg on the 67).
It's a straight swap.
The basic 67 has no sonic improvements over the basic 63/63MKII either.
Brent
Brent
Also the 67SE chassis is better than 63 (standard chassis) due to the screwed on bottom plate. The 67 plate fits to the 63 but with a little overhang.
If the 63 is better than the 67 remember to fit the 67 tx onto the 63 pcb for further improvements.
If you put a dedicated clock onto the 63 servo chip the sonic benefits are greater than on the 67.
Brent
Brent
rowemeister said:The basic 67 has no sonic improvements over the basic 63 either.
It looks like the move to the CD67 was a cost-cutting and product life-cycle lengthening exercise. The only good thing seems to be larger caps (and spaces) for the 12v smoothing caps.
Simon
aquar said:Hi Brent,
Assumtion: If I have fitted a few of transformer for independent supply (DAC,Servo,Clock,Decorder) like as your last list modd (5 toroids), What is the replacement transformer to tx in the CD63SE still advantageous?
aquar
Unless you can get hold of a KI TX I would leave the SE one in. Removing power to the muting and HDAM circuits will free up the full VA of the winding to the op amps
Brent
Here is the link to Simonty web site with my mods list at the top.
ROWEMEISTERS MODS LIST (LATEST EDITION)
You will notice most mods address the supply to the relevent circuits.
thanks Simon
Brent
thanks Simon
Brent
rowemeister said:Here is the link to Simonty web site with my mods list at the top.
thanks Simon
Brent
No problem. Sorry I forgot to post that link. I think the date is listed wrong, it's defo the newest modlist though.
Simon
rowemeister said:
What a list
This explaines the looks of your player
If I can agree on the price of the 63, I'll check the condition of it. Then I'll decide which chassis to use since my current cd67 is in mint condition Thanks again for the answers.
Paulus1981 said:
What a list
If your CD63 is just skipping, mistracking, etc, you can get a new laser for about €30. They're easy enough to fit as well and you get new motors as well as laser.
Glenn2 said:If your CD63 is just skipping, mistracking, etc, you can get a new laser for about €30. They're easy enough to fit as well and you get new motors as well as laser.
Will pick it up tomorrow (80 euro isn't bad isn't it?), changing the TX will be my second weapon fact considering electronics
If I remain very quiet tomorrow you know something has gone wrong
If you end up paying €80 plus €30 for a laser so €110 for an almost-good-as-new CD-63KI that's not bad at all mate. You could sell it on for more than that.
You could use it as a reference (and to keep you in tunes) whilst you are modding the '67 even
Anyway - off the pub!
...lobs hand grenade...
OK so I've been working really hard at implementing LME49710s, the single opamp version of the LM4562, for a while now.
I don't like it. There's something subtly odd&unnatural about its presentation of music... as opposed to it's presentation of mere detail - which is first rate but totally boring. Can;t quite artuclate it, but its go to do with LF ambience which comes and goes depending on signal level, leading to a totally sterile presentation. Ho hum, not for me then, oh no...
KI not reading disks (yet again)
Hey guys.
I posted on here a while ago about my ki radial error and i'm still stuck.
I put a disk in, it spins, the laser seems to read, but then nothing - no toc reading or owt.
service mode with a disk gives error 10, without a disk gives error code 02.
HHHHHHEEEEEEELLLLLLPPPPPP!!!!!
PLEASE?
I read voltages at q105 - all ok except pins 7&8 - service manual says 2.5v for both, but I read 0.02v. When disk spins this reading goes up to ~5v but then dips to 0v when it stops spinning. Is this normal?
Lee.
Hey guys.
PLEASE?
Lee.
Brent
Tks for your answer Brent
rgds
aquar
Re: KI not reading disks (yet again)
Sounds like a ribbon/connector problem to me.
First of all (with power off) remove ribbon to mech from both connectors. Then re insert. test for reading cds
If that does not work can you try a different mech?
I think its the connectors for the ribbon. You would not believe how often these F up. Try hard wiring, this would improve signal transfer anyway. + you could do the HF coax mod.
Brent
Thomo said:Hey guys.
PLEASE?
Lee.
Brent
Ok, thanks Brent. I tried changing the ribbon and sockets but like you say they're really unreliable.
I planned to do the coax last to make removing the board for the other mods easier, but I think I'll change that.
One more question though (sorry to be a pest), do you know what parts to change on a superclock II to enable it to be used on the servo?
Regards, Lee.
Regards, Lee.
Re: ...lobs hand grenade...
Hi Martin,
That sums up my feelings on the LM4562 really.
I said on this thread t'other day that I was warming to it but I've changed my mind again (sorry Simon ).
It really depends what you're listening to... but sterile is my overriding impression.
Some favourite CDs didn't sound emotionally involving like they normally would so I popped in some AD825s which are the opposite really. Rough diamonds. Enthusiastic but a bit rough around the edges in comparison. The life and emotion came back to the sound. I found my fingers and toes tapping again.
I think AD chips are good at this aspect of sound. That's the main reason why don't like the BB op-amps. I prefer AD8610 over OPA627 for example.
Glenn
martin clark said:OK so I've been working really hard at implementing LME49710s, the single opamp version of the LM4562, for a while now.
Hi Martin,
Glenn
Re: Re: ...lobs hand grenade...
I have changed back to LT1361 again some 3 week ago. I missed the roughness and emotion. The 4562 still sits in my pre (for now).
Glenn2 said:
Hi Martin,
Glenn
Re: Re: Re: ...lobs hand grenade...
Interesting!
I have some samples of LT1361 and LT1364 on order and they should arrive any day now.
I've never heard these parts before.
They interest me because they seem to have a lot in common with the LM6172, which I like. Kind of like a VFB/CFB hybrid.
Glenn
Interesting!
Glenn
- Digital Source
- Marantz CD63 & CD67 mods list
