Making car amplifier SMPS with tl494 + DC Protection
I have been working on this design with max power of 600 watts.Topology used is half bridge boost converter. Image has the detail of each component i have used.
It works fine without rectifying diodes. if diodes are connected then no load current goes high up to 2.5A at duty cycle above 80%. Mosfet are just warming a little.
Dead time provided by TL494 is at default value and is approximated as 7-8%.
What can be the problem? Suggest me the area of improvements in design of snubber circuit and gate driving circuit.
CAN Someone contact Workhorse for me and let him's know i am trying to contact him's for more questions. ;) I tried to contact hims with the email address provided but it got bounced :confused: :(
So if someones knows Workhorse please please tell hims i want to email hims for more info on this SMPS for a better parts list.
Gday
Greetings :cool: :)
happy holidays :drink:
ThanX for ur interest
here is schematics
greetings....sir i have read ur article and see ur designs,,and i think this is it,,this is the one i am looking for,,i thank you for answering our problems with regards to 12v smps for car audio and amplifiers..i hope,you continue helping us,,hope in the future,,u can help me build a quite bigger design of high powered car amplifiers..once again,,jephrell tolentino of iloilo philippines,,home of well known BORACAY ISLAND,,a summer get away. thaks and regards.
Hello simingx. The post is 624. I repeated assembly of your amplifier. Very high temperature keys. What resistance (Ohms) of primary winding of the transformer has to be? Sorry for my bad english, and computer translate.
I think you mean smps, not amplifier, since there is no amp there. Resistance of primary is below of what you can measure, so assume close to 0 on your multimeter
4+4 is about the lowest you would want to go, you can use even more if you can (more wire used). 6+6 is probably the highest you would want to go, if you don't know anything about your core.
Wire size... depends on the current, switching freq.
Start with something like 3-4x 1mm if freq is around 35k or even lower. If higher, you will have to use smaller wire and more of them.
