Low-distortion Audio-range Oscillator
Joined 2011
... and the Panasonic / Levear VP7723D ...
600R load, 20kHz BW.
BR, Toni
The reference reminded me of a question.
On p.156 he states that examples use NPN bipolar but P channel MOS because the P channels have a better back gate connection, to the source rather than the substrate.
This surprises me because I would expect the N channel to be preferable due to better speed and presumably the fabrication process could be done a complementary way so it's the N channels with the better connection.
So, is this not done simply because of some established practice in the fabrication process?
Or is there a reason, to better match the P and N devices perhaps?
Best wishes
David
Sorry I missed your question, but I don't have a good answer. Maybe coupling through the substrate?
P channel mosfets have the S/D doped with boron, on a n type substrate. For good physical reasons (P+ concentration is usually one order of magnitude lower compared to the N+ concentration) the metallization contact on p+ is worse than on n+ so the source contact will have a larger contact resistance than the substrate contact resistasnce. This leads to the situation in which the body diode (drain-substrate, through the shorted source) will have a lower drop voltage for a given current. and will also be rather fast. A drawing of the mosfet cross section is worth more than any short written explanation.
N channel is exactly the other way around.
Note that the body diode properties have nothing to do with the channel carrier mobility in P and N mosfets. The body diode matters in switching applications with reactive loads, don't know why this would matter in linear applications.
Disabled Account
Joined 2012
BTW -- The Panasonic and Levear and maybe National, all share a common design concept in implementation; similar to the ShibaSoku 725 models.
The Panasonic etal are made by Matsushita Communications Industries Co. Ltd. Maybe they did the design as well as building them.
THx-RNMarsh
Administrator
Joined 2004
Hi David,
Yes, as Scott says, TV sound is FM, and TV stereo sound uses dBx. I need a frequency generator for the FM broadcast band that modulates in Stereo. It would be nice if it was xtal controlled as my current solution is a Radiometer Copenhagen SMG1. Adjustable frequency that drifts badly. I've even attempted to take the MPX output and use that to modulate my HP 8656B generator, but I have to use a modulation analyzer (HP 8901A) to set the pilot level and modulation levels. It's an extreme pain in the rear, let me tell you! It also takes far too long, but then at least my frequency is rock solid, and I can set it anywhere in the FM band. The Radiometer is only good around 100 MHz, a busy part on the dial.
-Chris
Hi David,
-Chris
Yes but FM broadcast is within the channel space of TV. Perhaps a small mod to a Shibasoku would work. There's so much of that stuff around and no longer any use for it. So it's cheap.
Shaw went 100% digital last week in my system. There is no more analog just QAM.
Disabled Account
Joined 2012
Hi David,
-Chris
Could you use my SENCOR SG80?
THx-RNMarsh
Hi David,
If only!
I need FM broadcast stereo (without the dBx component). I'm stuck with a non-TV instrument. So the Panasonic ones (or equiv.) would have been perfect.
Thank you though! Chris
Chris we carried FM station over the cable. This was discontinued about 3 years ago and I believe the equipment is now disposable. I'll bet it still sitting in the rack at our remote hub.
These units are essentially low power stereo FM transmitters.
Would something like this be useful to you? I can ask my supervisor if the stuff is being disposed off.
