Lepai T-Amp with TA2020
Hi Fin;
I've just received a Lepai 2.1 Amp that I'm using with a Visteon HD Radio. Both of these were purchased through ebay.
The Amp is listed as an S07 Motorcycle amplifier 200 watts 12V.
Prior to getting a bass unit, I'd be interested to know if you have used the sub-woofer connection and whether it can be directly hooked up to the speaker or if it requires a powered unit.
Thanks in advance...
Loaded4th said:
Hi Fin;
Sorry - I've never seen that particular amp. I only have the one mentioned earlier in this thread.
Lepai T-amp
I found Eric, said to be the supplier in HK, is hard to communicate as he responded "I am going to check about stock. It may take about 1 or 2 days" on Apr 23 to my inquiry but never talks back after regardless of my reminds. I guess I will have to forget the whole idea.
Kay
