Krell KSA 50 PCB
Krelloutputs
acenovelty said:
Just curious. Did the KSA 50 use plastic output transistors like the MJL21194/93 and MJE15033/32?
Seems like both NUTTTR and Stuart Easson confirmed "The schematics I have show mj15003/4 pairs" albeit with a small disclaimer about
"the choice of output transistors is a somewhat sensitive subject, close to religion or politics... "
But then if this is a clone, it might be a good idea to publish a parts list that reflects the original components accurately.
The MJ15003/4 sell for about 2 bucks and 25 can be had from onsemi as free samples.
Prosit :drink:
Hi acenovelty.
Original output transistors were TO-3 MJ15003/MJ15004.
http://home.ca.inter.net/~lloyd.maclean/Krell/Krell.htm
Direct link to the KSA-50 schematic:
http://home.ca.inter.net/~lloyd.maclean/Krell/KSA50.pdf
output devices (again)
Hate to bring this up again, but I wasn't crazy (this time)! The MJL21193 and MJL21194 are TO-220 type package and the MJ21193 and MJ21194 are TO-3 type package. Other than this the data sheets look like photocopies of each other. I must have missed an "L" when I retyped in the parts.
As I said before, my heatsinks are predrilled for TO-3, so would I be better off using MJ21193/94? Any reason not to (other than that I wouldn't be able to use the output boards)?
By the way, which is considered to be a better package for heat dissipation?
A few comments
acenovelty:
The plastic MJL's where chosen due to the fact that the risc for shortenings are lower than for TO-3's, and because they are easier to fit for most of the diy'ers...
The MJL's are also avaiable as samples from Onsemi ;)
wim:
Yes! Thats because I'm not sure of the correct value ;)
And D201 and D202 are not on the PCB's any more. These >120V/1A diodes must be fitted separately......
Re: output devices (again)
According to the data sheets both have a resistance of 0.7 degC/W. Presumably this is them bolted to the sink- it may be that the plastic transistors will show a lower resistance if they're clamped to the sink with a big chunk of aluminium, so heat is conducted out of both sides of the package.
The plastic versions are rated at 200W, the metal 250 by the way.
I'm thinking about isolating the heatsinks from each other and ground and bolting the trannies straight onto them without an insulating pad, in the interests of reducing thermal resistance.
getting started with heatsinks
My Mystery Amplifier should get me 1/2 way there, well at least as far as heat sinking goes.
Its big enough I suppose for an 8 channel KSA-50, but I'll probably use extra output devices on each channel and use half of it, saving the other half for something else.
I'm going to be using MJE15030/31's as drivers from memory... I'm swimming in parts here, they are here somewhere....
I'm going for 4 pairs of outputs per channel, possibly depending on where it sits in the SOA, i might make it 6, i *think* the driver pairs and circuits will "support" it as such, i may need another pair of drivers - the KSA-100 had 2 pairs of drivers however only had 4 outputs, which makes me wonder a little....
Aaron
Jan - the parts you mentioned - 120v - 1a diodes - what were they for? i can't see where they'd popped up on original schematics
