Sir tony...good morning...can you pls. give me your email address...?
tnx...benny
pm sent....
sir jojo,
which of the two sound better?the degree of the piece pointed in red,how critical these in the design
wsx question
what is hyperbolic expansion law and large linear excursion
Dj jojo pls. explain it is good information what is the deferent between the TSW118 vs WSX.
TSW118 is a hybrid hornloaded 4th order bandpass cab ...WSX is a sealed horn loaded cab...hyperbolic because it is somewhat has a expansion rate of a hyperbola of a cone?...
hehehe....
some of the voice coil I fabricate on an aramid inorganic paper and fiberglass former/ bobbin:ev dh1, celestion truvox, kicker, jbl e120, 1545 and some hifi etc....enjoy
hello sir, very nice fabricated voice coils ! may I know sir where you get your v.c. formers? and also how or what do you use to 'glue' the magnet wire ? thanks in advance
makeing srx clone....
thank u very much sir JOJO...
Am also keen to know the answer of the question above. I wonder if 1860 is as good as JH series. Any idea will be very much appreciated. Cheers
im been using also pro-1815 crown this speaker are similar series with 1860. i used it my wsx sub. it just work fine.
Im using P Audio, For my 186horn. Yes Crown 1860 will work on 186 folded horn bin..To Sir Leinad61...
Sir... you mention that you use 4 186horn...and may i know what driver you use...in that bin...can it be possible that Crown 1860 will work on 186 folded horn bin...?
Hi Bossing, What model of P-Audio you used. How much and where? thanks, Al
Thanks for the info. I plan to use 186 folded horn (easier to build, IMO) instead of WSX. Does it have a huge difference in performance?
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
