kicker xs100
i came across this 1ohm resistor while looking for bad solder joints. i replaced it. now the other side with the drive transistors still in. those outputs started to get very hot.
i didnt see any dc voltage for the little time i had it on.
The following image shows the location of the fuse in the ZR1000.
If this amp is like the ZR1000, the screw between the transformer and the inductor has it's pad connected to the secondary center-tap. If you use a metallic screw, it shorts the secondary CT to the heatsink. If you mount the amp to the chassis of the vehicle, you'll get engine noise. This problem can be eliminated if you use a nylon screw and make sure that the cylindrical standoff is in place around the boss in the heatsink. This also applies to the ZR600.
