yes. there is still 30v there.
T timwebb Member Joined 2010 2011-10-02 11:12 pm #41 2011-10-02 11:12 pm #41 yes. there is still 30v there. ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-02 11:16 pm #42 2011-10-02 11:16 pm #42 Reinstall at least one TIP35 and one TIP36 on each side of the amp and re-check the voltage on the speaker terminals. ••• More options Share T timwebb Member Joined 2010 2011-10-02 11:34 pm #43 2011-10-02 11:34 pm #43 i still got 30+ and 30- ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-02 11:37 pm #44 2011-10-02 11:37 pm #44 If you have a module plugged in, remove it and recheck the voltage on the speaker terminals. Do you have BOTH positive and negative regulated voltage on the power supply pins (pins 4 and 7) of the TL071s? ••• More options Share T timwebb Member Joined 2010 2011-10-02 11:55 pm #45 2011-10-02 11:55 pm #45 pin 4. -15.5 pin7. +14.9 ••• More options Share T timwebb Member Joined 2010 2011-10-03 3:28 am #46 2011-10-03 3:28 am #46 i found two shorted drive transistors. i checked them before guess i missed them. im looking them up now. ••• More options Share T timwebb Member Joined 2010 2011-10-03 3:49 am #47 2011-10-03 3:49 am #47 the smd part number is 2q. i got mmbt5087-2n5087 as the part.just checking to be sure. ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-03 9:22 am #48 2011-10-03 9:22 am #48 I think that's likely normal. There is an MMBT5087 in the circuit with the base and collector shorted by design. Post the DC voltage on all 8 pins of one of the TL071s. Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: ••• More options Share T timwebb Member Joined 2010 2011-10-04 1:14 am #49 2011-10-04 1:14 am #49 this was taken on the non bridging speaker terminal Pin 1: -15.2 Pin 2: -15.6- Pin 3: -13.5 Pin 4: -15.1 Pin 5: -15.1 Pin 6: 0 Pin 7: 14.8 Pin 8: 0 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-04 7:46 am #50 2011-10-04 7:46 am #50 On that same TL071, there is a resistor connected to pin 3. What is the DC voltage on the end of the resistor NOT connected to pin 3? Place the black probe on one of the non-bridging speaker terminals again. ••• More options Share T timwebb Member Joined 2010 2011-10-05 3:22 am #51 2011-10-05 3:22 am #51 -13.6 ••• More options Share T timwebb Member Joined 2010 2011-10-05 4:02 am #52 2011-10-05 4:02 am #52 i notice that the regulators are getting quite hot Attachments IMAG0114.jpg 677.3 KB · Views: 63 IMAG0115.jpg 630.7 KB · Views: 55 Last edited: 2011-10-05 4:14 am ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-05 2:23 pm #53 2011-10-05 2:23 pm #53 The end of the resistor that's NOT connected to pin 3 of the TLO71 should read 0 ohms to the non-bridging speaker terminals. What resistance do you read in your amp (no power applied)? ••• More options Share T timwebb Member Joined 2010 2011-10-06 12:50 am #54 2011-10-06 12:50 am #54 u202 right? Attachments IMAG0108.jpg 500.1 KB · Views: 51 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-06 1:10 am #55 2011-10-06 1:10 am #55 U102 and U202. ••• More options Share T timwebb Member Joined 2010 2011-10-06 1:31 am #56 2011-10-06 1:31 am #56 U202 r210-4mega ohms U102 r110- 0 ohms ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-06 1:46 am #57 2011-10-06 1:46 am #57 If the voltage you posted earlier was for U202, post the voltage for U102 now. 4megs is bad. It should be close to 0 ohms. Look for open traces leading away from R210. ••• More options Share T timwebb Member Joined 2010 2011-10-06 2:01 am #58 2011-10-06 2:01 am #58 U202 13v+ U102 0v ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-06 2:10 am #59 2011-10-06 2:10 am #59 Post the voltage on all pins of U102. ••• More options Share T timwebb Member Joined 2010 2011-10-06 2:23 am #60 2011-10-06 2:23 am #60 1pin 15.1v 2pin 15.5v 3pin -10.1v 4pin -15.1v 5pin -15.1v 6pin 13.8v 7pin 14.8 8pin 0v ••• More options Share Prev 1 2 3 4 5 Next First Prev 3 of 5 Go to page Go Next Last Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link Home General Interest Car Audio kicker xs100 Top Bottom
