John Curl's Blowtorch preamplifier
This seems optimized for 1.5mA bias current:
(but increasing emitter resistors has increased noise to some 0.6nV/rtHz). Gain is 49dB at this setup.
PMA said:
Yes, it changes gain, and should be chosen according to bias current.
Of course it changed the gain. And of course this circuit has relatively low distortion. This circuit is nothing but heavy NFB so there's no surprise about. This FB type also decreases both the input and output impedances by the loop gain. This makes this little circuit a transimpedance amp.
And of course it has a low noise - having such a low input impedance.
And of course it needs high Iq - the 100 ohm resistor loads the output, in parallel with the 50k "load" and it's of course the gm*100 ohm that sets the OL gain. And if you want any performance improvement by means of NFB you need some OLG, isn't it?
And of course you can lower the Iq if you increase the feedback resistor to 10k, to get the same OL gain.
It's funny how people moan about feedback but don't miss any opportunity to conveniently use it in their circuits.
PMA, thanks for your input. I beta match to remove any significant bias. Typically, 2.5 ma and 10 ohm Re is normal. 2 x D battery powered. Re could be slightly offset to remove even harmonics. i.e. 11 ohm, 9 ohm for example. Initial even harmonic probably due to bipolar model differences in diode equation.
This is the essence of the Levinson JC-1 pre-preamp, and the SOTA headamp. Made obsolete by Vendetta in 1982.
AX tech editor
Joined 2002
Thank you ;)
Jan Didden
This circuit can be OK without any feedback of any consequence. In fact, it will be even quieter. Please remember 100mV is the MAXIMUM output and usually measures about .1% DUH!. Actual operation is more like 10mV out and less. It drives other people's moving magnet phono stages directly, and will overload them if you are not careful.
IT IS A TRANSFORMER ELIMINATOR!
