If I correct the loading, I'm bracing for the complaint that the top end is suddenly tizzy. Unless, as I have suggested, hardly anyone has any auditory response up there anymore.
1.) How much material is there on a properly cut record? (I don't know if there are losses)
2.) Your point wouldn't surprise me. Most reviewers are older and probably beat their ears to death. Not good for top end response.
I am not telling you anything else other that I do not need DBT for my own practical use.
If something sounds good to me, it will do so independently of any test by anybody excpet if that somebody is using a mirror of ym system with only one variable change (e.g. he has different speakers). On the other hand, of what practical use is a verdict from a jury listening to a system which looks nothing like mine? If you need that kind of perspective from outside of yourself, that's your business, but what happens when you get a response which is quite opposite to your views? A clash between "subjective" and "objective"?
BTW, there is NO debiased jury, because each and every one of them has an idea of what he likes and does not like, so all you're doing is asking for an "average" view from a group of people. Put yourself into any jury you care to mention, and tell me, does being a part of the jury in any way change your views on wht is good sound, and what is not? In the end, if you don't like what you hear, how will you know whether it's the amp or the speaker falling short?
DBT is just so much crap put forward by wanna-bes to pull more wool over the public eyes not because it's silly or meaningless, but because it a panacea for all our audio troubles. And it's pushed on by people who have nothing specfic to say, and nobody's interested in what they do have to say.
DVV--DBT does well to set a limit of audibility, even if we set our standards to that of the most exceptional individual within a set of listeners (or just beyond that). We can talk preferences until we're blue in the face, but knowing what the limits of a young (undamaged), trained ear can actually hear is a critical first step, because it sets the boundary.
That and, Olive/Toole's work seems to strongly suggest that we as a greater population (accepting moderate deviation) tends to prefer a similar sound under DBT, which speaks directly contrary your point. So at least that tells me that I'd probably do well to align my goals with the common preference in the absence of better information.
So, no, DBT does NOT pull wool over anyone's eyes. It tempers unjustified enthusiasm. No, I don't expect you to do DBT within your own home unless you're the curious type. But, then again, you should really stick with, "I like this or that in my system" rather than "this or that is better". Note the difference? That's what this issue is about and why SY (more vocally than perhaps others) calls out the people/industry he does, as they're claiming something as absolutely better without any sort of attempt to remove biases.
Perhaps you're more fallible than you think? Or maybe not. The issue is you don't really know!
Well musical instruments have significant energy at harmonics, certainly to 10kHz. Electronic music has used higher fundamentals than the piccolo of course. But certainly the pink noise contours are pretty much obeyed for the high stuff. But a response to at least 15kHz used to be considered standard. And then there was quad and the Shibata stylus...1.) How much material is there on a properly cut record? (I don't know if there are losses)
(2) And a lot of kids believe their ears are indestructible, sadly.
Thanks, Brad--my question was additionally answered by http://wiki.hydrogenaud.io/index.php?title=Myths_(Vinyl)
(In my ignorance, I didn't know the tracking/response bandwidth of records -- seems in the 20 kHz -40 kHz range on the high end, but, as you note playback will depend on cartridge loading)
That is remarkable logic.
In which regard is it ?
Derf, we have studied this in detail since the 70's. There is always a fair amount of high frequency energy ready to do mischief and this is what a quality phono playback has to be able to handle without being overstressed by TIM ( a common problem in the past) or just plain high frequency clipping.
If you think I am not serious, carefully study SY's tube phono stage and note its dynamic limits.
That's a nice reference (note that the final parenthesis has to be added, as it got clipped off of the link as a link). So initially the thing comes up with no material. I repaired it above as part of the quote.Thanks, Brad--my question was additionally answered by Myths (Vinyl) - Hydrogenaudio Knowledgebase)
Be careful the guys at hydrogenaudio are not immune from being confused around dynamic range, SNR, effective noise BW of FFT's, etc. I could not find where someone computed 150dB DNR for CD. I can think off at least one wrong way to get that answer.
Yeah, that part (the dynamic range with dithering) didn't make sense to me, I was more looking at the bandwidth as a go/no go to 20 kHz than anything else. Seems at least, on the limits of the playback method, that this bandwidth is more than manageable, even if it's not necessarily exercised.
10-4 John. Didn't want to suggest this wasn't known information--I just didn't know (and should have done due diligence before asking), as I'm a child of the digital era. Thanks for the link/notes.
Daniel
I've posted a survey article here before, the best noise shaped dither achieved 12dB improvement over TPDF when audibility was taken into account. That would look like -106-108dB or so perceived SNR. If you use quantization noise in one bin vs signal, with an FFT you can make it anything you like.
Derfnofred, I appreciate your reasonable and civil argumentation, but really do not want to run another circle on this well beaten path. I do not believe in DBT as anything but a bare pointer what to investigate. Over the years of reading mostly British audio magazins, I have tried and discovered that DBT actually tells me very little, but individual texts of some contributors (Alvin Gold comes to mind) are most useful for me, because ut appears that ontributor and I have very similar tastes and hearing. Ovwer the years, his findings very closely mirror my own, and then the difference is mostly in degree rather than the entire device. I also have a friend who has a totally different system to mine, yet our degree of agreement on the sound of this or that device is almost identical. I do not feel I need more confirmation than I already have.
DBT are, to me, just another mantra suported by those who do not have other mantras, but appear to need some. I do not deny their use for those who need them, but I do not. Just as classic THD measurement results are meaninful to those who need their instruments to tell them what they are hearing, while to me anything below 0.05% becomes essnetially meaningless. The question is, under which circumstances and into which loads- if that's into 3 Ohms in parallel with 2 uF at nominal power output, that's all I care about.
So, let's leave it at that, shall we?
I have a client who apparently believes that moving the cursor to be centered n the FFT baseline is an accurate reading of system noise. I don't know what the AP default binning is, but his results were unbelievable. One variable gain amp part for which the manufacturer quotes a typical output noise of 10.5uV at unity gain was said to have a noise floor down at -120dBu (775nV rms).I've posted a survey article here before, the best noise shaped dither achieved 12dB improvement over TPDF when audibility was taken into account. That would look like -106-108dB or so perceived SNR. If you use quantization noise in one bin vs signal, with an FFT you can make it anything you like.
Are you being truly honest here, Andrew?
When you described the sound of your CAF amp, I didn't see any reference to DBT testing, just your own say-so.
DBT testing is, at best, of limited use. Whatever the panel decides, may well be quite true of the system used at the time, but change the system and you could get very different results. What then? The refernce rig is in fact a moving target.
dvv, I did not test any of my amps with DBT.
And yes, the sound of the amps as I write about them is just my say-so.
However, if you read my write-ups, I am very careful not to make subjective claims based on technical matters. So, like government, I keep 'church and state' completely separate. One issue is to do with the mind (technical) and the other with the heart (subjective). When the two disagree, only the judge (DBT) can settle it.
I would think in the sampling that the noise floor is pushed down, so this is probably optimistic.
That said, AP could add a function to compute the real noise - enter the BW and get a noise number out.
Yes of course it does have that capability, and I have been suggesting that he use it. They are just infatuated with FFTs.I would think in the sampling that the noise floor is pushed down, so this is probably optimistic.
EDIT: Oh wait I see what you are saying. It probably does have that function based on the FFT, but I was thinking more of the traditional filters and rms voltmeter capability.
Same to you. Let's, happily, leave it here. I don't think we're as far apart philosophically as was being projected, unless you find Andrew's post between ours extremely objectionable. Even then, I'd still grab a beer with you at a pub and enjoy the conversation.
And yet the manufacturer claims response to 20kHz, while loading a 1.3kohm + 700mHy cartridge with the equivalent at high frequencies of about 24kohm! With the stated C loading, that equates to an electrical response down 13.5dB at 20kHz! With the stated loading C of the preamp, -3dBr at 7.3kHz.
Who loads a high L cart with 1.3k?
That's nuts.
My own position on DBT is somewhat ambivalent. The sighted tests, especially of loudspeakers, strongly favor big pretty boxes until they can't be seen anymore. The stress from quick evals of electronics is real, and I doubt that, other than in a few really terrible cases, that I would be very good at discerning differences (the Dynaco Stereo 120 was an example I cited, the schematic sent to me as a joke by Walt Jung, but I had indeed listened to them and thought I didn't like the sound).
But what I do object to are people who go on at great length about some tweak making an amazingly great difference, and that without it the music dies etc. When these people are unable to distinguish in a DBT the sound with and without the tweak, I am troubled.
No the cartridge is itself the 1.3k + 700mHy. The loading was a mere 23.5k at high frequencies, just half of what it ought to be.Who loads a high L cart with 1.3k?
That's nuts.
- Member Areas
- The Lounge
