JN, a VFET is not necessarily a VERTICAL FET.
He didn't say that.
just like Demian just did by implying that a TO-92 part could easily replace a T0-220 part, even though the die inside are the same.
He didn't say that.
Reading and responding to what's actually been written is much more useful than responding to the voices in your head.
Calm down john or your blow out a keyboard again, I can just picture the frothing going on.
http://gifsoup.com/view/1578007/bloody-keyboard-wreck.html
GIFSoup
Scott, your attempted insertion of this schematic at this time was inappropriate. It would have answered nothing and would not have contributed to further understanding of the questions recently posed. Secondly, you didn't appear to 'understand' the schematic details to do anything but confuse the situation, just like Demian just did by implying that a TO-92 part could easily replace a T0-220 part, even though the die inside are the same.
That is something that JN might do, Demain! After all, with a 45 degree spread angle of heat flow, anything should be possible! I maintain that only liquid Freon would do the job properly, and maybe not well enough, given the plastic thermal resistance. '-)
I knew exactly what the FET's were, I had no intention of refering to those very obscure parts. I find the circuit far more interesting than piles of paralleled unobtainable JFET's. I suspect I understand the circuit well enough, but if that were the case we might see the man behind the curtain.
JC-80 is shown here:
http://www.diyaudio.com/forums/anal...rch-preamplifier-part-ii-317.html#post2022301
And the reason you felt it necessary to say that is????JN, a VFET is not necessarily a VERTICAL FET. It is an early power jfet that was made by NEC, Sony, and Yamaha, for example. It is a DEPLETION MODE device and it was discontinued, because it was too difficult to get a suitable yield. It is also sometimes called a Static Induction Transistor.
The power devices used in the JC-80 are called VMOS, because they are a vertical MOS structure, with ENHANCEMENT instead of DEPLETION as the fundamental property of the device. They cannot be easily interchanged.
As Sy stated, you seem to be reading what is not there.
It all about the conduction path John. It's not about the package size. While you may be impressed with the amount of plastic or the color of the leads, neither contribute to thermal conduction. The world of electronics packaging has advanced in the last 30 years, perhaps you should come down off the pedestal and learn something.Scott, your attempted insertion of this schematic at this time was inappropriate. It would have answered nothing and would not have contributed to further understanding of the questions recently posed. Secondly, you didn't appear to 'understand' the schematic details to do anything but confuse the situation, just like Demian just did by implying that a TO-92 part could easily replace a T0-220 part, even though the die inside are the same.
What is it with you and that liquid freon?? You've no idea what you are talking about here.
Where's the fun in that??
jn
I thought I went through this exercise before (what's that definition of insane)?
I still think there is an essential cleverness here, that is fun to look at.
Some things need to stew a couple of hours, others a couple of years.
(each morning in the bathroom, I'm experiencing a groundhog day start episode)
Sot-89 on something like this:
http://www.ceramtec.com/files/ca_press_release_2009-11-09_1_en.pdf
or have an assembly made up with something like this:
Integrated Heat Pipe Assemblies - heat sinks
Ceramic heatsinks avoid EMC problems, or use the heat pipes to move the heat from the active devices to heatsinks moulded into the case.
*click*
Then put your little hand in mine
There ain't no hill or mountain we can't climb
Babe
I got you babe
I got you babe...
se
If I were in need of a good thermal interface, I'd go with a beryllia piece metalized as solderable on both sides. The stuff's got a thermal conductivity coefficient close to that of aluminum, and about 60% of copper.
http://materion.com/~/media/Files/P...s/CC-007BerylliumOxideCeramicsDesignGuide.pdf
For small quantity, I'd just buy some of the rf packages and use them, they already have mounting options built in. Just solder the entire package to a good piece of berquist, an alumina substrate, or directly to a good copper spreader if you need even better thermals than what the package offers as a simple screw down.
Ceramic Package|Beryllium Oxide Package|BeO package|Electronic Packaging|Materion Microelectronics - Materion
Edit: For most, just use a simple copper mounting pad and solder the device to it. While the heat flux density is high, use copper. As it spreads out, then you can use an insulator. Just don't expect an insulator like sil pad or mica to work well very close to the die, as the effective cross section of the heat path isn't large enough there. Even berquist board uses an epoxy directly under the foil, so if you solder the chip directly to the board, the thermal drop is high before it gets to the aluminum. Use a spreader over the higher resistivity materials.
jn
Patient: Doctor, each night I have the same dream: I see mices playing football.
Doctor: I’ll prescribe you these pills. Start taking them tonight and in a few days you won’t have these dreams again.
Patient: Can I start taking them tomorrow because tonight are the finals?
George
Silly student.Hi again, everybody. I found that if you just 'Google' freon heat sink' or something similar, you can find out HOW to make your very own 'freon heat sink' and maybe its history. JN, please ignore this message. '-)
Eventually, via continual random snarky erroneous statements, hopefully you will decide to learn something. But, maybe not.
However, there is a good aspect of your continual badgering, that is, others can learn and discuss.
The coolers you refer to are used to transport lots of heat from a large area device. Think about the area of a CPU chip. It's major. But the power density per square inch is low.
Now try to pull 280 watts out of an IRFP460 using that thing.What do you expect to happen?
First, you mount the case to the copper spreader used in quite a few of them.. you do so using what, grease? What's the thermal interface resistance? What's the power density?
Hint..it takes calculation.
The die is .250 by .360.
The spread at the bottom of the package is .330 by .440.
Now what's the thermal resistance of a greased contact to an electrically hot sink where the effective thermal channel is .145 sq inches? Or Mica with two interfaces?
The entire thermal mangement game is all about keeping the junction temperature as low as possible.
Tossing a "freon cooler" at a high power density semiconductor is not engineering.
No wonder you blow up silicon.
Try engineering a thermal solution instead.
jn
"I know the voices in my head aren't real. But they do have some good ideas."Patient: Doctor, each night I have the same dream: I see mices playing football.
George
- Member Areas
- The Lounge
