Is this a real TDA1541A?
If I understand this thread correctly the two digits after for example "HSH"
is a datecode?
Which makes wonder when I see a TDA1541A marked:
TDA1541A
11189
HSH0815 2
Or are they back in production as I've seen in some posts?
Now one that i got myself...
To me the datecode/batch seems ok, just the typeface is very very clean. I have some other tda's, all with a more fuzzy print than this.
Also to be seen on fleabay (i bought it from a dutch seller though):
ttp://www.ebay.nl/itm/TDA1541A-Stereo-high-performance-16-bit-DAC-Philips-/120836576628?pt=LH_DefaultDomain_0&hash=item1c226bd574#ht_806wt_922
From China.... 58 available.... Bad signs...
This is how the TDA1541 (from my Phillips CD-473) typeface looks like. Year 87, non-A. Notice the specific "A", "4" and "7" in name and datecode. But not in the middle serial (at least not in what I have).
is a datecode?
TDA1541A
11189
HSH0815 2
That chip will work I have seen 2004 dated chips and 2008 chips and they all worked .
It is a pretty elaborate fake for them to be pin identical to the TDA1541A and also sound and function like one .
As has been mentioned by quite a few in the know on this forum the TDA1541A is still bizarrely enough still in limited production .
Work, yes, but could it be a relabeled TDA1541 non A?
I'm not in the know, but I guess there could be a limited production for spares?
Anyhow I did choose to go the safer path and got a few used TDA1541A SAA7220P/B cd-players/mainboards.
Ok... So what's the worst that can happen if I just plug this chip in my board?
