added
bercovici : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700
LOBOONE: PCM, 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
roger57: 1x I2S FIFO KIT V3.80
mhgawel: 1x I2S to PCM converter
nanocamp: pcm
lordvader : 1x I2S to PCM converter
4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator
Gogi x1 PCM board
JustBuildLspkAS x4 finished FIFO i2s isolator Board => FIFO ll , x4 Si570 Clock Board V3.5 => Dual XO ll , x2 spdif interface , x8 I2S to PCM converter =OK Got them
casshan: 1 x I2S FIFO KIT v3.8, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board V2.5
fordgtlover: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x pkg Universal SMT XO Adapters
curryking: 16 x Dual XO II clock board
bisesik: 1x I2S to PCM converter
MadKid: 1 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT
dant100: 1x I2S FIFO kit, 1x Dual XO Clock Board, 1x Pack of SMT XO Adapters, 1x Finished FIFO isolator board, 1x Finished Battery management board
Phi: 5x I2S FIFO kit, 3x Dual XO Clock Board, 3x Pack of SMT XO Adapters, 5x Finished FIFO isolator board, 5x Finished TPS7A4700 Regulator board, 2x Finished Battery management board , 5x I2S to PCM converter, 1 x Si570 Clock Board (at least this)
zz1969: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
kenneth_obee: 2 x I2S FIFO Kit, 2 x Finished FIFO Isolator Board, 1 x Dual XO Clock board, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board, 2 x adapters for Crystek if you still have them
SomekPoland: 1x I2S to PCM
henry97: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished isolator, 1x I2S to PCM converter.
nopants: 1x I2S FIFO Kit, 1x SPDIF Kit, 3x SMT XO Adapters, 6 x 6" double-ended U.FL coaxial cable
GhostMM : 1xFIFO board, 1xIsolator Board V2.5, 1XDuax XO clock board, 1xI2S to PCM board, 1X10P 1.0mm FFC/FPC cables, 1xPackage of Universal SMT XO Adapters
vertigen: 1xPackage of Universal SMT XO Adapters
zjerneic: 1x S/PDIF Interface Board; 1xI2S FIFO kit
lbamda: 1* I2S FIFO KIT ; 1* Dual XO Clock board ; 1* S/PDIF Interface board ; 4* SMT U.FL socket ; 1* 4" U.FL doublr ended coax cable ; 1* 6" U.FL doublr ended coax cable ; 1* I2S backdoor kit for S/PDIF board ; 1* Universal SMT XO adapter kit ; 1* Si570 clock board V3.5(with Si570) ; 1* Finished FIFO Isolator board ; 1* Finished TPS7A4700 low noise regulator board V.2.5 ; 1* SMT Finished Battery management mini kit V.2.5
johnmarkp: 1 x BIII adapter PCB, 1 x SMT connector package for BIII, 4 x 4" double ended silver U.FL
zapio : 3x Dual Clock board
Joonas: 1*I2S FIFO kit, 1*S/PDIF interface board, 1*Si570 clock board, 1*Finished isolator 2*I2S to PCM converter, 1*Finished Battery management kit
name_hase: 1* I2S to PCM converter
SalvationMen: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x Package of Universal SMT XO Adapters, 2x Additional BIII adapters PCB, 2x SMT U.FL socket, 8x 4” double-ended 50 ohm coaxial cable
sebna: 4x Finished TPS7A4700 regulator
Nige2000: 2x I2S FIFO KIT, 2x Dual XO Clock Board, 2x Finished FIFO Isolator Board, 6x Package of Universal SMT XO Adapters, 2x Si570 Clock Board, 2x I2S to PCM converters
Jogi: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board
skybug: 1x I2S FIFO II, 1x Dual XO Clock Board II with two 14PIN IC sockets populated, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator Board, 1x Finished TPS7A4700 low noise regulator board, 1x I2S to PCM board with soldered U.FL sockets, 1 x Package of Universal SMT XO Adapters, possibly some additional cables
emyeuoi: 1X I2S FIFO Kit, 1X Dual XO II Clock Board, 1X Finished FIFO Isolator Board
Nikon1975: 2x I2S to PCM converters
ernesternest: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x I2S to PCM converter, 4x 6"double-ended U.FL coaxial cable, 8x SMT U.FL socket
COX77 : 1x I2S FIFO KIT V3.80, 1xS/PDIF interface board
mikeg88: (1x) I2S FIFO KIT V3.80, (1x) Dual XO Clock Board, (1x) Finished FIFO Isolator Board, (1x) Package of Universal SMT XO Adapters, (6x) 6" double-ended U.FL coaxial cables, (1x) 2" double-ended PH 2.0 mm 7-pin I2S bridge cable, (1x) 2" 10-pin FPC/FFC cable, (1x) universal i2s isolator PCB, (1x) U.FL signal input connector board for BIII DAC
Luke: 1* Finished I2S to PCM Board; 12* SMT U.FL socket; 12* 4" U.FL doublr ended coax cable
sernikus : 2x DualXoBoard II, 2x I2S FIFO II
Brumjam : 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator
zlahmoon : 2 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT
walangalam: 1x I2S to PCM converter
GaryB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator V2.5, 1 x S/PDIF Interface Board
ryanj: 1x I2S to PCM converter, 1X Finished FIFO Isolator Board, 4x Finished Battery management board
JimS:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator
badrisuper: 1 x I2S to PCM converter, 8 x U.FL socket, 8 x 4" double-ended U.FL Coax
damohpi: 1x I2S FIFO Kit, 1x Finished FIFO Isolator, 1x Dual XO Clock Board, 1x I2S - PCM Converter Board
LuisMCP: 3 x (Dual XO + i2s FIFO + Finished FIFO Isolator) + 2 x (I2S to PCM Converter + 1 x (Finished Battery Mngmnt brd. + SPDIF interface brd.)
IanS1 : 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator, 1 x S/PDIF Interface Board
bkdog: 1 x Dual XO II board, 1 x FIFO II, 1 x BIII adaptor board, 3 6" UFL cables.
mjensen: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,2x Finished FIFO Isolator
dubai2000: 1x I2S FIFO KIT, 1xDual XO Clock Board, 1x Finished FIFO Isolator Board
Aronier: 2x I2S FIFO Kit, 2x Finished FIFO Isolator, 2x Si570 Clock Board V3.5(with Si570), 2x low noise reg 2x I2S - PCM Converter Board, 2x 4 x 4" double-ended U.FL Coax, 2x Finished Battery management board
Aive: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board, 1 x SPDIF Interface Board, 1 x Finished FIFO Isolator, 2 x finished adapters for Crystek, 2 x 8" double-ended PH 2.0mm 7-pin I2S cables, 6 x 6" double-ended U.FL coaxial cable
brookbphx: 3x SMT XO adapter[/QUOTE
Myint67: 1x finish SPDIF interface board ,6 x 4" double ended Ufl,12inch double end 50ohm coaxial cable,L2S PCM board.
danielkol: 2 x I2S to PCM converter board V2.0;
nacder: 2x I2S FIFO Kit, 2x Dual XO Clock Board II, 2x SPDIF Interface Board, 2x Finished FIFO Isolator Board, 2x Adapters for Crystek, 6x SMT u.fl sockets, 6x 6" Double-ended u.fl Coaxial Cables.
chi0001: 10x SMT XO adapter, 5x U.FL input adapter, 2x finished FIFO-Clock Isolation, Board, 1 x Finished Si570 Clock board (with Si570), 1 x I2S to PCM converter
kenlaumm: 1x I2S FIFO KIT II, 1x Finished FIFO Isolator, 1x Dual XO Clock II
lazybonesxp: 1 x I2S to PCM converter, 8 x U.FL socket, 8 x 4" double-ended U.FL Coax
emrpus: 1x I2S FIFO Kit, 1x Finished FIFO Isolator, 1x Dual XO Clock
ceglar: 1x Dual XO v2.0
giordano: 1x I2S FIFO Kit, 1x Dual XO Clock (II?)
MarcellD: 1x Si570 Clock Board V3.5(with 10MHz Si570), 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT
Fridrik: 1x I2s to PCM, 4 x 4" Double-ended u.fl Coaxial Cables,8 x U.FL socket,.
Clsidxxl:1x Dual XO II-1xI2S to PCM board
kvl: 2x I2S FIFO Kit, 2x Dual XO Clock Board II, 1x SPDIF Interface Board, 2x Finished FIFO Isolator Board, 1x Finished TPS7A4700 low noise regulator board V2.5
Arledgsc: 1x I2S FIFO Kit, 1x Dual XO Clock Board II, FIFO Isolator board V 2.5, U.FL Connectors/ Cables
davej:1x Dual XO II
rab28: 1x I2S FIFO Kit, 1x Dual XO Clock Board II, 1x Finished FIFO Isolator Board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT, 1x I2S - PCM Converter Board
TNT: 2x Dual XO II
hires: 2x DualXO II + 2 x I2S FIFO-II
heathkit: 1x I2S FIFO kit, 1x Dual XO Clock Board II, 1x SMT finished Battery Management V2.5 Mini KIT, 2x Finished TPS7A4700 low noise regulator board V2.5
grepap: 1x I2S to PCM converter
ppap64: 1 x I2S FIFO Kit v.3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1 x I2S to PCM Converter
Zoran: 2x DualXO II
Nikon1975: 1x I2S FIFO kit, 1x Dual XO Clock Board II
MeiT: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5
andrea_mori: 3 x Dual XO II + 3 x Finished FIFO isolator board V2.5
Crom: 1x Dual XO v2.0, 1 x FIFO v2.0
Lindamar: 16x SMT U.FL socket, 3x Additional BIII adapters, 3x SMT connector package for BIII adatpers, 4x 10P 1.0mm FFC/FPC cables combo (3 cables), 4x 4" double-ended silver plated U.FL coaxial cable, 2x Dual XO II, 1x I2S to PCM convertor board
tods: 1 x I2S FIFO Kit v.3.80, 1 x Dual XO Clock Board II, 1 x S/PDIF Interface Board, 4 x SMT U.FL socket, 4 x 4"double-ended U.FL coaxial cable,
4 x 6"double-ended U.FL coaxial cable, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters KIT lot of 5, 1 x Finished FIFO isolator board V2.5, 2 x Finished TPS7A4700 low noise regulator board V2.5, 2 x Bare PCB of TPS7A4700 low noise regulator, 1 x I2S to PCM Converter
Stixx: 1 x I2S FIFO-II, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, , 1 x I2S to PCM Converter, 2 Finished TPS7A4700 low noise regulator board V2.5
ripson: 1 x I2S FIFO finished, 1 x Dual XO Clock board, 1 x finished FIFO isolator, 1 x S/PDIF Interface Board
Zoef: 1 x Finished I2S FIFO Kit (v 3.80?), 1 x Finished Dual XO Clock Board (II?), 1 x Finished FIFO Isolator Board v.2.5, TPS7A4700 regulator? much as needed for this.
palmito: 2 x Dual XO II, 1 x I2S FIFO II
tagheuer: 1 x Dual XO II
jimchan : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
Luanak: 1x I2S to PCM Converter
minionas: 1 x I2S FIFO II Kit, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 10 x SMT U.FL socket
vanwykca: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, Package of Universal SMT XO Adapters, 1x I2S to PCM Converter, 1x Finished TPS7A4700 low noise regulator board V2.5.
RollE2k: 1 x I2S FIFO-II, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1x S/PDIF Interface board, 2x Finished TPS7A4700 low noise regulator board V2.5, 1x 10P 1.0mm FFC/FPC cables combo.
sidiropa: 2x Dual XO Clock Board II,1 x I2S FIFO-II
nedi: 1x Dual XO Clock Board II
bigpandahk : 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board, i x FIFO II
Eldam : Dual XO II + finished FIFO (v?)
number9 :1 X Dual XO Clock Board II, 1 X I2S FIFO II
Mikhail Vorozhtsov: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II
hsi68 : 1 x Package of Universal SMT XO Adapters, 4 x SMT U.FL socket, 4 x 4" double-ended U.FL coaxial cable
shendrik: 3 x I2S FIFO Kit
vladspb62:2x Dual XO Clock Board II, 1xS/PDIF Interface Board
blitz: 1xdual xo board ii, buffallo adapter and 4" clock cable
JeffreyD: 1x dual XO Board II, 1x SPDIF Interface board, I2S FiFo II kit, 1x TPS7A4700 low noise regulator board V2.5 incl. Interfacing cables and coaxes for the complete set.
Haiku: 1 x I2S FIFO Kit, 1 x Finished FIFO Isolator, 1 x Dual XO Clock Board II, 2 x I2S to PCM Converter incl. interfacing cables and coaxes for the complete set
AR2: 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board
necplusultra: 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board
Greg Stewart: 1 x Dual XO Clock Board II, 1 x I2S FIFO II
duster1: 1 x Dual XO Clock Board II, 1 x Universal SMT XO Adapter KIT
alecm: 1 x S/PDIF Interface Board, 4 x 4” double-ended 50 ohm coaxial cable
xaled: 5x SMT U.FL socket, 1x Clock BIII adapter, 1x u.fl BIII adapter, 1x SMT connector package for BIII adatpers, 1x 10P 1.0mm FFC/FPC cables combo (3 cables), 4x 4" double-ended silver plated U.FL coaxial cable, 1x I2S to PCM convertor board, 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 1 x FIFO isolator board, 1 x TPS7A4700 low noise regulator board, 1x Si570 Clock Board, 1x SMT Battery Management Mini KIT
moonong1: 1x I2S FIFO Kit v 3.80, 1x Dual XO Clock Board II, 1x Finished FIFO Isolator Board v.2.5, 1 x I2S backdoor KIT for S/PDIF board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT incl. Interfacing cables and coaxes for the complete set.
kenthf: 1 x Finished I2S FIFO, 1 x Finished FIFO isolator, 1 x Finished TPS7A4700 low noise regulator board, 1 x Finished SMT Battery Management Mini KIT, 1 x Finished Dual XO Clock board, 1 x Finished Si570 Clock Board, 1 x Finished S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" double-ended silver plated U.FL coaxial cable
oyvind: 1 x I2S FIFO-II
josoeff: 1 x FIFO II, 3 x finished TPS7A4700 regulator boards, 1 x Finished S/PDIF Interface Board II
damohpi: 1x FIFO kit, 1x FIFO Isolator, 1x dual xo board, 1x TPS7A4700 reg board, 1x I2S-PCM board, various cables
supra: 1x Fifo finished, 1x iso finished, 3x dual clock finished
kannan_s: 1 x I2S FIFO Kit, 1 x Finished FIFO Isolator, 1 x Dual XO Clock Board II, 2 x I2S to PCM Converter incl. interfacing cables and coaxes for the complete set
triode_al - PCM board
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
just to make clear ...
1. jbercovici : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700
2. LOBOONE: PCM, 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
3. Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
4. wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
5. roger57: 1x I2S FIFO KIT V3.80
6. mhgawel: 1x I2S to PCM converter
7. nanocamp: pcm
8. lordvader : 1x I2S to PCM converter
9. 4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator
10. Gogi x1 PCM board
11. JustBuildLspkAS x4 finished FIFO i2s isolator Board => FIFO ll , x4 Si570 Clock Board V3.5 => Dual XO ll , x2 spdif interface , x8 I2S to PCM converter =OK Got them
12. casshan: 1 x I2S FIFO KIT v3.8, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board V2.5
13. fordgtlover: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x pkg Universal SMT XO Adapters
14. curryking: 16 x Dual XO II clock board
15. bisesik: 1x I2S to PCM converter
16. MadKid: 1 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT
17. dant100: 1x I2S FIFO kit, 1x Dual XO Clock Board, 1x Pack of SMT XO Adapters, 1x Finished FIFO isolator board, 1x Finished Battery management board
18. Phi: 5x I2S FIFO kit, 3x Dual XO Clock Board, 3x Pack of SMT XO Adapters, 5x Finished FIFO isolator board, 5x Finished TPS7A4700 Regulator board, 2x Finished Battery management board , 5x I2S to PCM converter, 1 x Si570 Clock Board (at least this)
19. zz1969: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
20. kenneth_obee: 2 x I2S FIFO Kit, 2 x Finished FIFO Isolator Board, 1 x Dual XO Clock board, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board, 2 x adapters for Crystek if you still have them
21. SomekPoland: 1x I2S to PCM
22. henry97: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished isolator, 1x I2S to PCM converter.
23. nopants: 1x I2S FIFO Kit, 1x SPDIF Kit, 3x SMT XO Adapters, 6 x 6" double-ended U.FL coaxial cable
24. GhostMM : 1xFIFO board, 1xIsolator Board V2.5, 1XDuax XO clock board, 1xI2S to PCM board, 1X10P 1.0mm FFC/FPC cables, 1xPackage of Universal SMT XO Adapters
25. vertigen: 1xPackage of Universal SMT XO Adapters
26. zjerneic: 1x S/PDIF Interface Board; 1xI2S FIFO kit
27. bamda: 1* I2S FIFO KIT ; 1* Dual XO Clock board ; 1* S/PDIF Interface board ; 4* SMT U.FL socket ; 1* 4" U.FL doublr ended coax cable ; 1* 6" U.FL doublr ended coax cable ; 1* I2S backdoor kit for S/PDIF board ; 1* Universal SMT XO adapter kit ; 1* Si570 clock board V3.5(with Si570) ; 1* Finished FIFO Isolator board ; 1* Finished TPS7A4700 low noise regulator board V.2.5 ; 1* SMT Finished Battery management mini kit V.2.5
28. johnmarkp: 1 x BIII adapter PCB, 1 x SMT connector package for BIII, 4 x 4" double ended silver U.FL
29. zapio : 3x Dual Clock board
30. Joonas: 1*I2S FIFO kit, 1*S/PDIF interface board, 1*Si570 clock board, 1*Finished isolator 2*I2S to PCM converter, 1*Finished Battery management kit
31. name_hase: 1* I2S to PCM converter
32. SalvationMen: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x Package of Universal SMT XO Adapters, 2x Additional BIII adapters PCB, 2x SMT U.FL socket, 8x 4” double-ended 50 ohm coaxial cable
33. sebna: 4x Finished TPS7A4700 regulator
34. Nige2000: 2x I2S FIFO KIT, 2x Dual XO Clock Board, 2x Finished FIFO Isolator Board, 6x Package of Universal SMT XO Adapters, 2x Si570 Clock Board, 2x I2S to PCM converters
35.Jogi: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board
36. skybug: 1x I2S FIFO II, 1x Dual XO Clock Board II with two 14PIN IC sockets populated, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator Board, 1x Finished TPS7A4700 low noise regulator board, 1x I2S to PCM board with soldered U.FL sockets, 1 x Package of Universal SMT XO Adapters, possibly some additional cables
37. emyeuoi: 1X I2S FIFO Kit, 1X Dual XO II Clock Board, 1X Finished FIFO Isolator Board
38. Nikon1975: 2x I2S to PCM converters
39. ernesternest: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x I2S to PCM converter, 4x 6"double-ended U.FL coaxial cable, 8x SMT U.FL socket
40. COX77 : 1x I2S FIFO KIT V3.80, 1xS/PDIF interface board
41. mikeg88: (1x) I2S FIFO KIT V3.80, (1x) Dual XO Clock Board, (1x) Finished FIFO Isolator Board, (1x) Package of Universal SMT XO Adapters, (6x) 6" double-ended U.FL coaxial cables, (1x) 2" double-ended PH 2.0 mm 7-pin I2S bridge cable, (1x) 2" 10-pin FPC/FFC cable, (1x) universal i2s isolator PCB, (1x) U.FL signal input connector board for BIII DAC
42. Luke: 1* Finished I2S to PCM Board; 12* SMT U.FL socket; 12* 4" U.FL doublr ended coax cable
43. sernikus : 2x DualXoBoard II, 2x I2S FIFO II
44. Brumjam : 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator
45. zlahmoon : 2 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT
46. walangalam: 1x I2S to PCM converter
47. GaryB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator V2.5, 1 x S/PDIF Interface Board
48. ryanj: 1x I2S to PCM converter, 1X Finished FIFO Isolator Board, 4x Finished Battery management board
49. JimS:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator
50.badrisuper: 1 x I2S to PCM converter, 8 x U.FL socket, 8 x 4" double-ended U.FL Coax
51. damohpi: 1x I2S FIFO Kit, 1x Finished FIFO Isolator, 1x Dual XO Clock Board, 1x I2S - PCM Converter Board
52. LuisMCP: 3 x (Dual XO + i2s FIFO + Finished FIFO Isolator) + 2 x (I2S to PCM Converter + 1 x (Finished Battery Mngmnt brd. + SPDIF interface brd.)
53. IanS1 : 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator, 1 x S/PDIF Interface Board
54. bkdog: 1 x Dual XO II board, 1 x FIFO II, 1 x BIII adaptor board, 3 6" UFL cables.
55. mjensen: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,2x Finished FIFO Isolator
56. dubai2000: 1x I2S FIFO KIT, 1xDual XO Clock Board, 1x Finished FIFO Isolator Board
57. Aronier: 2x I2S FIFO Kit, 2x Finished FIFO Isolator, 2x Si570 Clock Board V3.5(with Si570), 2x low noise reg 2x I2S - PCM Converter Board, 2x 4 x 4" double-ended U.FL Coax, 2x Finished Battery management board
58. Aive: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board, 1 x SPDIF Interface Board, 1 x Finished FIFO Isolator, 2 x finished adapters for Crystek, 2 x 8" double-ended PH 2.0mm 7-pin I2S cables, 6 x 6" double-ended U.FL coaxial cable
59. brookbphx: 3x SMT XO adapter[/QUOTE
60. Myint67: 1x finish SPDIF interface board ,6 x 4" double ended Ufl,12inch double end 50ohm coaxial cable,L2S PCM board.
61. danielkol: 2 x I2S to PCM converter board V2.0;
62. nacder: 2x I2S FIFO Kit, 2x Dual XO Clock Board II, 2x SPDIF Interface Board, 2x Finished FIFO Isolator Board, 2x Adapters for Crystek, 6x SMT u.fl sockets, 6x 6" Double-ended u.fl Coaxial Cables.
63. chi0001: 10x SMT XO adapter, 5x U.FL input adapter, 2x finished FIFO-Clock Isolation, Board, 1 x Finished Si570 Clock board (with Si570), 1 x I2S to PCM converter
64. kenlaumm: 1x I2S FIFO KIT II, 1x Finished FIFO Isolator, 1x Dual XO Clock II
65. lazybonesxp: 1 x I2S to PCM converter, 8 x U.FL socket, 8 x 4" double-ended U.FL Coax
66. emrpus: 1x I2S FIFO Kit, 1x Finished FIFO Isolator, 1x Dual XO Clock
67. ceglar: 1x Dual XO v2.0
68. giordano: 1x I2S FIFO Kit, 1x Dual XO Clock (II?)
69. MarcellD: 1x Si570 Clock Board V3.5(with 10MHz Si570), 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT
70. Fridrik: 1x I2s to PCM, 4 x 4" Double-ended u.fl Coaxial Cables,8 x U.FL socket,.
71. Clsidxxl:1x Dual XO II-1xI2S to PCM board
72.kvl: 2x I2S FIFO Kit, 2x Dual XO Clock Board II, 1x SPDIF Interface Board, 2x Finished FIFO Isolator Board, 1x Finished TPS7A4700 low noise regulator board V2.5
73.Arledgsc: 1x I2S FIFO Kit, 1x Dual XO Clock Board II, FIFO Isolator board V 2.5, U.FL Connectors/ Cables
74. davej:1x Dual XO II
75.rab28: 1x I2S FIFO Kit, 1x Dual XO Clock Board II, 1x Finished FIFO Isolator Board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT, 1x I2S - PCM Converter Board
76. TNT: 2x Dual XO II
77. hires: 2x DualXO II + 2 x I2S FIFO-II
78. heathkit: 1x I2S FIFO kit, 1x Dual XO Clock Board II, 1x SMT finished Battery Management V2.5 Mini KIT, 2x Finished TPS7A4700 low noise regulator board V2.5
79. grepap: 1x I2S to PCM converter
80. ppap64: 1 x I2S FIFO Kit v.3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1 x I2S to PCM Converter
81. Zoran: 2x DualXO II
82. Nikon1975: 1x I2S FIFO kit, 1x Dual XO Clock Board II
83. MeiT: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5
84. andrea_mori: 3 x Dual XO II + 3 x Finished FIFO isolator board V2.5
85. Crom: 1x Dual XO v2.0, 1 x FIFO v2.0
86. Lindamar: 16x SMT U.FL socket, 3x Additional BIII adapters, 3x SMT connector package for BIII adatpers, 4x 10P 1.0mm FFC/FPC cables combo (3 cables), 4x 4" double-ended silver plated U.FL coaxial cable, 2x Dual XO II, 1x I2S to PCM convertor board
87. tods: 1 x I2S FIFO Kit v.3.80, 1 x Dual XO Clock Board II, 1 x S/PDIF Interface Board, 4 x SMT U.FL socket, 4 x 4"double-ended U.FL coaxial cable,
88. Stixx: 1 x I2S FIFO-II, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, , 1 x I2S to PCM Converter, 2 Finished TPS7A4700 low noise regulator board V2.5
89. ripson: 1 x I2S FIFO finished, 1 x Dual XO Clock board, 1 x finished FIFO isolator, 1 x S/PDIF Interface Board
90. Zoef: 1 x Finished I2S FIFO Kit (v 3.80?), 1 x Finished Dual XO Clock Board (II?), 1 x Finished FIFO Isolator Board v.2.5, TPS7A4700 regulator? much as needed for this.
91. palmito: 2 x Dual XO II, 1 x I2S FIFO II
92. tagheuer: 1 x Dual XO II
93. jimchan : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
94. Luanak: 1x I2S to PCM Converter
95. minionas: 1 x I2S FIFO II Kit, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 10 x SMT U.FL socket
96. vanwykca: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, Package of Universal SMT XO Adapters, 1x I2S to PCM Converter, 1x Finished TPS7A4700 low noise regulator board V2.5.
97. RollE2k: 1 x I2S FIFO-II, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1x S/PDIF Interface board, 2x Finished TPS7A4700 low noise regulator board V2.5, 1x 10P 1.0mm FFC/FPC cables combo.
98. sidiropa: 2x Dual XO Clock Board II,1 x I2S FIFO-II
99. nedi: 1x Dual XO Clock Board II
100. bigpandahk : 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board, i x FIFO II
101. Eldam : Dual XO II + finished FIFO (v?)
102. number9 :1 X Dual XO Clock Board II, 1 X I2S FIFO II
103. Mikhail Vorozhtsov: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II
104. hsi68 : 1 x Package of Universal SMT XO Adapters, 4 x SMT U.FL socket, 4 x 4" double-ended U.FL coaxial cable
105. shendrik: 3 x I2S FIFO Kit
106. vladspb62:2x Dual XO Clock Board II, 1xS/PDIF Interface Board
107. blitz: 1xdual xo board ii, buffallo adapter and 4" clock cable
108. JeffreyD: 1x dual XO Board II, 1x SPDIF Interface board, I2S FiFo II kit, 1x TPS7A4700 low noise regulator board V2.5 incl. Interfacing cables and coaxes for the complete set.
109. Haiku: 1 x I2S FIFO Kit, 1 x Finished FIFO Isolator, 1 x Dual XO Clock Board II, 2 x I2S to PCM Converter incl. interfacing cables and coaxes for the complete set
110. AR2: 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board
111. necplusultra: 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board
112. Greg Stewart: 1 x Dual XO Clock Board II, 1 x I2S FIFO II
113. duster1: 1 x Dual XO Clock Board II, 1 x Universal SMT XO Adapter KIT
114. alecm: 1 x S/PDIF Interface Board, 4 x 4” double-ended 50 ohm coaxial cable
115. xaled: 5x SMT U.FL socket, 1x Clock BIII adapter, 1x u.fl BIII adapter, 1x SMT connector package for BIII adatpers, 1x 10P 1.0mm FFC/FPC cables combo (3 cables), 4x 4" double-ended silver plated U.FL coaxial cable, 1x I2S to PCM convertor board, 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 1 x FIFO isolator board, 1 x TPS7A4700 low noise regulator board, 1x Si570 Clock Board, 1x SMT Battery Management Mini KIT
116. moonong1: 1x I2S FIFO Kit v 3.80, 1x Dual XO Clock Board II, 1x Finished FIFO Isolator Board v.2.5, 1 x I2S backdoor KIT for S/PDIF board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT incl. Interfacing cables and coaxes for the complete set.
117. kenthf: 1 x Finished I2S FIFO, 1 x Finished FIFO isolator, 1 x Finished TPS7A4700 low noise regulator board, 1 x Finished SMT Battery Management Mini KIT, 1 x Finished Dual XO Clock board, 1 x Finished Si570 Clock Board, 1 x Finished S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" double-ended silver plated U.FL coaxial cable
118. oyvind: 1 x I2S FIFO-II
119. josoeff: 1 x FIFO II, 3 x finished TPS7A4700 regulator boards, 1 x Finished S/PDIF Interface Board II
120. damohpi: 1x FIFO kit, 1x FIFO Isolator, 1x dual xo board, 1x TPS7A4700 reg board, 1x I2S-PCM board, various cables
121. supra: 1x Fifo finished, 1x iso finished, 3x dual clock finished
122. kannan_s: 1 x I2S FIFO Kit, 1 x Finished FIFO Isolator, 1 x Dual XO Clock Board II, 2 x I2S to PCM Converter incl. interfacing cables and coaxes for the complete set
123. triode_al - PCM board
7. nanocamp: pcm
updated
7. nanocamp: pcm
84. andrea_mori: 3 x Dual XO II + 3 x Finished FIFO isolator board V2.5 + 3 x FIFO II
7. nanocamp: pcm
7. nanocamp: pcm
124. Alcaudon: 1 x I2S FIFO II, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1x Finished TPS7A4700 low noise regulator
7. nanocamp: pcm
1. jbercovici : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700<br />
2. LOBOONE: PCM, 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board<br />
3. Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator<br />
4. wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them<br />
5. roger57: 1x I2S FIFO KIT V3.80<br />
6. mhgawel: 1x I2S to PCM converter<br />
7. nanocamp: pcm<br />
8. lordvader : 1x I2S to PCM converter<br />
9. 4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator<br />
10. Gogi x1 PCM board<br />
11. JustBuildLspkAS x4 finished FIFO i2s isolator Board => FIFO ll , x4 Si570 Clock Board V3.5 => Dual XO ll , x2 spdif interface , x8 I2S to PCM converter =OK Got them<br />
12. casshan: 1 x I2S FIFO KIT v3.8, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board V2.5<br />
13. fordgtlover: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x pkg Universal SMT XO Adapters<br />
14. curryking: 16 x Dual XO II clock board<br />
15. bisesik: 1x I2S to PCM converter<br />
16. MadKid: 1 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT<br />
17. dant100: 1x I2S FIFO kit, 1x Dual XO Clock Board, 1x Pack of SMT XO Adapters, 1x Finished FIFO isolator board, 1x Finished Battery management board<br />
18. Phi: 5x I2S FIFO kit, 3x Dual XO Clock Board, 3x Pack of SMT XO Adapters, 5x Finished FIFO isolator board, 5x Finished TPS7A4700 Regulator board, 2x Finished Battery management board , 5x I2S to PCM converter, 1 x Si570 Clock Board (at least this)<br />
19. zz1969: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board<br />
20. kenneth_obee: 2 x I2S FIFO Kit, 2 x Finished FIFO Isolator Board, 1 x Dual XO Clock board, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board, 2 x adapters for Crystek if you still have them<br />
21. SomekPoland: 1x I2S to PCM<br />
22. henry97: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished isolator, 1x I2S to PCM converter.<br />
23. nopants: 1x I2S FIFO Kit, 1x SPDIF Kit, 3x SMT XO Adapters, 6 x 6" double-ended U.FL coaxial cable<br />
24. GhostMM : 1xFIFO board, 1xIsolator Board V2.5, 1XDuax XO clock board, 1xI2S to PCM board, 1X10P 1.0mm FFC/FPC cables, 1xPackage of Universal SMT XO Adapters<br />
25. vertigen: 1xPackage of Universal SMT XO Adapters<br />
26. zjerneic: 1x S/PDIF Interface Board; 1xI2S FIFO kit<br />
27. bamda: 1* I2S FIFO KIT ; 1* Dual XO Clock board ; 1* S/PDIF Interface board ; 4* SMT U.FL socket ; 1* 4" U.FL doublr ended coax cable ; 1* 6" U.FL doublr ended coax cable ; 1* I2S backdoor kit for S/PDIF board ; 1* Universal SMT XO adapter kit ; 1* Si570 clock board V3.5(with Si570) ; 1* Finished FIFO Isolator board ; 1* Finished TPS7A4700 low noise regulator board V.2.5 ; 1* SMT Finished Battery management mini kit V.2.5<br />
28. johnmarkp: 1 x BIII adapter PCB, 1 x SMT connector package for BIII, 4 x 4" double ended silver U.FL<br />
29. zapio : 3x Dual Clock board<br />
30. Joonas: 1*I2S FIFO kit, 1*S/PDIF interface board, 1*Si570 clock board, 1*Finished isolator 2*I2S to PCM converter, 1*Finished Battery management kit<br />
31. name_hase: 1* I2S to PCM converter<br />
32. SalvationMen: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x Package of Universal SMT XO Adapters, 2x Additional BIII adapters PCB, 2x SMT U.FL socket, 8x 4” double-ended 50 ohm coaxial cable<br />
33. sebna: 4x Finished TPS7A4700 regulator<br />
34. Nige2000: 2x I2S FIFO KIT, 2x Dual XO Clock Board, 2x Finished FIFO Isolator Board, 6x Package of Universal SMT XO Adapters, 2x Si570 Clock Board, 2x I2S to PCM converters<br />
35.Jogi: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board<br />
36. skybug: 1x I2S FIFO II, 1x Dual XO Clock Board II with two 14PIN IC sockets populated, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator Board, 1x Finished TPS7A4700 low noise regulator board, 1x I2S to PCM board with soldered U.FL sockets, 1 x Package of Universal SMT XO Adapters, possibly some additional cables<br />
37. emyeuoi: 1X I2S FIFO Kit, 1X Dual XO II Clock Board, 1X Finished FIFO Isolator Board<br />
38. Nikon1975: 2x I2S to PCM converters<br />
39. ernesternest: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x I2S to PCM converter, 4x 6"double-ended U.FL coaxial cable, 8x SMT U.FL socket<br />
40. COX77 : 1x I2S FIFO KIT V3.80, 1xS/PDIF interface board<br />
41. mikeg88: (1x) I2S FIFO KIT V3.80, (1x) Dual XO Clock Board, (1x) Finished FIFO Isolator Board, (1x) Package of Universal SMT XO Adapters, (6x) 6" double-ended U.FL coaxial cables, (1x) 2" double-ended PH 2.0 mm 7-pin I2S bridge cable, (1x) 2" 10-pin FPC/FFC cable, (1x) universal i2s isolator PCB, (1x) U.FL signal input connector board for BIII DAC<br />
42. Luke: 1* Finished I2S to PCM Board; 12* SMT U.FL socket; 12* 4" U.FL doublr ended coax cable<br />
43. sernikus : 2x DualXoBoard II, 2x I2S FIFO II<br />
44. Brumjam : 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator<br />
45. zlahmoon : 2 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT<br />
46. walangalam: 1x I2S to PCM converter<br />
47. GaryB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator V2.5, 1 x S/PDIF Interface Board<br />
48. ryanj: 1x I2S to PCM converter, 1X Finished FIFO Isolator Board, 4x Finished Battery management board<br />
49. JimS:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator<br />
50.badrisuper: 1 x I2S to PCM converter, 8 x U.FL socket, 8 x 4" double-ended U.FL Coax<br />
51. damohpi: 1x I2S FIFO Kit, 1x Finished FIFO Isolator, 1x Dual XO Clock Board, 1x I2S - PCM Converter Board<br />
52. LuisMCP: 3 x (Dual XO + i2s FIFO + Finished FIFO Isolator) + 2 x (I2S to PCM Converter + 1 x (Finished Battery Mngmnt brd. + SPDIF interface brd.)<br />
53. IanS1 : 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator, 1 x S/PDIF Interface Board<br />
54. bkdog: 1 x Dual XO II board, 1 x FIFO II, 1 x BIII adaptor board, 3 6" UFL cables.<br />
55. mjensen: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,2x Finished FIFO Isolator<br />
56. dubai2000: 1x I2S FIFO KIT, 1xDual XO Clock Board, 1x Finished FIFO Isolator Board<br />
57. Aronier: 2x I2S FIFO Kit, 2x Finished FIFO Isolator, 2x Si570 Clock Board V3.5(with Si570), 2x low noise reg 2x I2S - PCM Converter Board, 2x 4 x 4" double-ended U.FL Coax, 2x Finished Battery management board<br />
58. Aive: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board, 1 x SPDIF Interface Board, 1 x Finished FIFO Isolator, 2 x finished adapters for Crystek, 2 x 8" double-ended PH 2.0mm 7-pin I2S cables, 6 x 6" double-ended U.FL coaxial cable<br />
59. brookbphx: 3x SMT XO adapter[/QUOTE<br />
60. Myint67: 1x finish SPDIF interface board ,6 x 4" double ended Ufl,12inch double end 50ohm coaxial cable,L2S PCM board.<br />
61. danielkol: 2 x I2S to PCM converter board V2.0;<br />
62. nacder: 2x I2S FIFO Kit, 2x Dual XO Clock Board II, 2x SPDIF Interface Board, 2x Finished FIFO Isolator Board, 2x Adapters for Crystek, 6x SMT u.fl sockets, 6x 6" Double-ended u.fl Coaxial Cables.<br />
63. chi0001: 10x SMT XO adapter, 5x U.FL input adapter, 2x finished FIFO-Clock Isolation, Board, 1 x Finished Si570 Clock board (with Si570), 1 x I2S to PCM converter<br />
64. kenlaumm: 1x I2S FIFO KIT II, 1x Finished FIFO Isolator, 1x Dual XO Clock II<br />
65. lazybonesxp: 1 x I2S to PCM converter, 8 x U.FL socket, 8 x 4" double-ended U.FL Coax<br />
66. emrpus: 1x I2S FIFO Kit, 1x Finished FIFO Isolator, 1x Dual XO Clock<br />
67. ceglar: 1x Dual XO v2.0<br />
68. giordano: 1x I2S FIFO Kit, 1x Dual XO Clock (II?)<br />
69. MarcellD: 1x Si570 Clock Board V3.5(with 10MHz Si570), 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT<br />
70. Fridrik: 1x I2s to PCM, 4 x 4" Double-ended u.fl Coaxial Cables,8 x U.FL socket,.<br />
71. Clsidxxl:1x Dual XO II-1xI2S to PCM board<br />
72.kvl: 2x I2S FIFO Kit, 2x Dual XO Clock Board II, 1x SPDIF Interface Board, 2x Finished FIFO Isolator Board, 1x Finished TPS7A4700 low noise regulator board V2.5<br />
73.Arledgsc: 1x I2S FIFO Kit, 1x Dual XO Clock Board II, FIFO Isolator board V 2.5, U.FL Connectors/ Cables<br />
74. davej:1x Dual XO II<br />
75.rab28: 1x I2S FIFO Kit, 1x Dual XO Clock Board II, 1x Finished FIFO Isolator Board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT, 1x I2S - PCM Converter Board<br />
76. TNT: 2x Dual XO II<br />
77. hires: 2x DualXO II + 2 x I2S FIFO-II<br />
78. heathkit: 1x I2S FIFO kit, 1x Dual XO Clock Board II, 1x SMT finished Battery Management V2.5 Mini KIT, 2x Finished TPS7A4700 low noise regulator board V2.5<br />
79. grepap: 1x I2S to PCM converter<br />
80. ppap64: 1 x I2S FIFO Kit v.3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1 x I2S to PCM Converter<br />
81. Zoran: 2x DualXO II<br />
82. Nikon1975: 1x I2S FIFO kit, 1x Dual XO Clock Board II<br />
83. MeiT: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5<br />
84. andrea_mori: 3 x Dual XO II + 3 x Finished FIFO isolator board V2.5 + 3 x FIFO II<br />
85. Crom: 1x Dual XO v2.0, 1 x FIFO v2.0<br />
86. Lindamar: 16x SMT U.FL socket, 3x Additional BIII adapters, 3x SMT connector package for BIII adatpers, 4x 10P 1.0mm FFC/FPC cables combo (3 cables), 4x 4" double-ended silver plated U.FL coaxial cable, 2x Dual XO II, 1x I2S to PCM convertor board<br />
87. tods: 1 x I2S FIFO Kit v.3.80, 1 x Dual XO Clock Board II, 1 x S/PDIF Interface Board, 4 x SMT U.FL socket, 4 x 4"double-ended U.FL coaxial cable,<br />
4 x 6"double-ended U.FL coaxial cable, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters KIT lot of 5, 1 x Finished FIFO isolator board V2.5, 2 x Finished TPS7A4700 low noise regulator board V2.5, 2 x Bare PCB of TPS7A4700 low noise regulator, 1 x I2S to PCM Converter<br />
88. Stixx: 1 x I2S FIFO-II, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, , 1 x I2S to PCM Converter, 2 Finished TPS7A4700 low noise regulator board V2.5<br />
89. ripson: 1 x I2S FIFO finished, 1 x Dual XO Clock board, 1 x finished FIFO isolator, 1 x S/PDIF Interface Board<br />
90. Zoef: 1 x Finished I2S FIFO Kit (v 3.80?), 1 x Finished Dual XO Clock Board (II?), 1 x Finished FIFO Isolator Board v.2.5, TPS7A4700 regulator? much as needed for this.<br />
91. palmito: 2 x Dual XO II, 1 x I2S FIFO II<br />
92. tagheuer: 1 x Dual XO II<br />
93. jimchan : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator<br />
94. Luanak: 1x I2S to PCM Converter<br />
95. minionas: 1 x I2S FIFO II, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 10 x SMT U.FL socket, 1x Finished TPS7A4700 low noise regulator, Package of Universal SMT XO Adapters<br />
96. vanwykca: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, Package of Universal SMT XO Adapters, 1x I2S to PCM Converter, 1x Finished TPS7A4700 low noise regulator board V2.5.<br />
97. RollE2k: 1 x I2S FIFO-II, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1x S/PDIF Interface board, 2x Finished TPS7A4700 low noise regulator board V2.5, 1x 10P 1.0mm FFC/FPC cables combo.<br />
98. sidiropa: 2x Dual XO Clock Board II,1 x I2S FIFO-II<br />
99. nedi: 1x Dual XO Clock Board II<br />
100. bigpandahk : 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board, i x FIFO II<br />
101. Eldam : Dual XO II + finished FIFO (v?)<br />
102. number9 :1 X Dual XO Clock Board II, 1 X I2S FIFO II<br />
103. Mikhail Vorozhtsov: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II<br />
104. hsi68 : 1 x Package of Universal SMT XO Adapters, 4 x SMT U.FL socket, 4 x 4" double-ended U.FL coaxial cable<br />
105. shendrik: 3 x I2S FIFO Kit<br />
106. vladspb62:2x Dual XO Clock Board II, 1xS/PDIF Interface Board<br />
107. blitz: 1xdual xo board ii, buffallo adapter and 4" clock cable<br />
108. JeffreyD: 1x dual XO Board II, 1x SPDIF Interface board, I2S FiFo II kit, 1x TPS7A4700 low noise regulator board V2.5 incl. Interfacing cables and coaxes for the complete set.<br />
109. Haiku: 1 x I2S FIFO Kit, 1 x Finished FIFO Isolator, 1 x Dual XO Clock Board II, 2 x I2S to PCM Converter incl. interfacing cables and coaxes for the complete set<br />
110. AR2: 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board<br />
111. necplusultra: 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board<br />
112. Greg Stewart: 1 x Dual XO Clock Board II, 1 x I2S FIFO II<br />
113. duster1: 1 x Dual XO Clock Board II, 1 x Universal SMT XO Adapter KIT<br />
114. alecm: 1 x S/PDIF Interface Board, 4 x 4” double-ended 50 ohm coaxial cable<br />
115. xaled: 5x SMT U.FL socket, 1x Clock BIII adapter, 1x u.fl BIII adapter, 1x SMT connector package for BIII adatpers, 1x 10P 1.0mm FFC/FPC cables combo (3 cables), 4x 4" double-ended silver plated U.FL coaxial cable, 1x I2S to PCM convertor board, 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 1 x FIFO isolator board, 1 x TPS7A4700 low noise regulator board, 1x Si570 Clock Board, 1x SMT Battery Management Mini KIT<br />
116. moonong1: 1x I2S FIFO Kit v 3.80, 1x Dual XO Clock Board II, 1x Finished FIFO Isolator Board v.2.5, 1 x I2S backdoor KIT for S/PDIF board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT incl. Interfacing cables and coaxes for the complete set.<br />
117. kenthf: 1 x Finished I2S FIFO, 1 x Finished FIFO isolator, 1 x Finished TPS7A4700 low noise regulator board, 1 x Finished SMT Battery Management Mini KIT, 1 x Finished Dual XO Clock board, 1 x Finished Si570 Clock Board, 1 x Finished S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" double-ended silver plated U.FL coaxial cable<br />
118. oyvind: 1 x I2S FIFO-II<br />
119. josoeff: 1 x FIFO II, 3 x finished TPS7A4700 regulator boards, 1 x Finished S/PDIF Interface Board II<br />
120. damohpi: 1x FIFO kit, 1x FIFO Isolator, 1x dual xo board, 1x TPS7A4700 reg board, 1x I2S-PCM board, various cables<br />
121. supra: 1x Fifo finished, 1x iso finished, 3x dual clock finished<br />
122. kannan_s: 1 x I2S FIFO Kit, 1 x Finished FIFO Isolator, 1 x Dual XO Clock Board II, 2 x I2S to PCM Converter incl. interfacing cables and coaxes for the complete set<br />
123. triode_al - PCM board <br />
125. vitalica 2 x I2S to PCM
42. Luke: finished Dual XO II + finished FIFO + Finished I2S to PCM Board; 12* SMT U.FL socket; 12* 4" U.FL doublr ended coax cable<br />
108. JeffreyD: 1x dual XO Board II, 1x SPDIF Interface board, I2S FiFo II kit, 1 x Finished Isolator board, 1x TPS7A4700 low noise regulator board V2.5 incl. Interfacing cables and coaxes for the complete set.<br />
Added the Isolator to my order. Thanks Ian!
GBVI: Ian FIFO II, Dual XO II and other accessories GB is running. Jul12, 2015
I appreciate very much that you guys like my projects. I’m very sorry for keeping you waiting for a long time. I thank you for your patience.
In the past five months, I’ve been working very hard preparing this GB. Both FIFO II and Dual XO II were carefully re-designed and upgraded from previous version. I had to go through many stages again, such as prototyping, PCB production, BOM ordering, SMT assembling and finial testing. That why it took longer than before.
Fortunately, GBVI is ready for now.
Items available of GBVI
Please see user’s manual and pictures for more details. Please refer to the file name of each pictures for what their respecting items. All prices are in USD.
1. I2S FIFO II KIT $139.00
Free standoffs/screws set (20pcs M3) will be included for first 50 FIFO II orders
2A. Dual XO II Clock Board with 45/49 XOs and sockets $75.00
2B. Dual XO II Clock Board without XO and socket $65.00
3. S/PDIF Interface Board $89.00
4. SMT U.FL socket $1.00
5. 4"double-ended U.FL coaxial cable $2.00
6. 6"double-ended U.FL coaxial cable $3.00
7. 12"double-ended U.FL coaxial cable $4.00
8. I2S backdoor KIT for S/PDIF board $3.99
9. Package of Universal SMT XO Adapters KIT lot of 5 $9.99
10. Additional BIII adapters PCB $3.98
11. SMT connector package for BIII adapters $3.96
13. 10P 1.0mm FFC/FPC cables combo (3 cables) $3.95
14. Si570 Clock Board V3.5(with 10MHz Si570) $89.90
15. Standoffs/screws set(M3 4pcs, 15mm&8mm ) $1.10
16. Finished FIFO isolator board V2.5 $45.00
17. Finished TPS7A4700 low noise regulator board V2.5 $23.00
18. Anti-vibration screw grommet set (767KE-ND) $1.08
19. SMT finished Battery Management V2.5 Mini KIT $9.98
20. I2S to PCM converter board V2.0 $79.00
21. 4" double-ended silver plated U.FL coaxial cable $3.00
22. 6" double-ended silver plated U.FL coaxial cable $4.00
23. 7" double-ended silver plated U.FL 178 coaxial cable $6.00
How to buy
1. Download the empty GBVI order form (in Excel format) at the bottom of this post;
2. Fill in the blue sections with quantities, shipping options and other information
3. Rename it (named by your ID is preferred) and send it back to me at iancanada.mail@gmail.com .
That’s all you need to do, I’ll take care of the rest
***Please do not make any payment until you receive my PayPal invoice.
Shipping and Delivery
Items will be shipped by Canada Post. Please put a note in the order form if you need a tracking number (registered) and how much value you went to declare the insurance. I’ll decide the best way of shipping for your benefit based on to maximize the savings Shipping will be in one of the following options:
1. In an envelope (holds less than 100g) without tracing number and insurance:
To Canada: $4
To USA: $5
To other international places: $7
*If you just order one board, this option would be recommended for the best cost.
2. In an envelope (holds less than 500g) with tracing number and $50 insurance:
To Canada: $12
To USA: $19
To other international places: $29
3. In an box (holds less than 1kg) with tracing number and $100 insurance:
To Canada: $19
To USA: $25
To other international places: $68
Notes:
1. Please note that I’m not responsible for any lost packages. If you select the shipping without tracking number and insurance, you will be taking the risk of losing the package. Please make decision based on the safety reputation of your local post service.
2. Please put your correct shipping address on your order form so that the optimal shipping option may be selected for you and to save time.
3. If your PayPal shipping address is different from the one on your order form, I’ll ship to the PayPal address except if you put a note of a new address on your PayPal payment form.
4. For Canada Post, the package will only be registered mail if it has a tracking number. No tracking number means that it is not registered mail.
5. If you know your address has problems such as customs clearance or frequent package losses, please give me a safe address in Canada or USA to ship to.
Payment
I’ll send a PayPal invoice to your email box of your PayPal account after your order is processed. Please follow the invoice for the payment. I accept payment in PayPal only. Please make the payment within 7 days after your receive my invoice. I cannot reserve items for you if you don’t pay in time, unless you let me know in advance.
Please let me know if you don’t receive invoice 5 days after sending the order form.
Also, I’m afraid I have to ask for you to pay half the PayPal fee of 1.95%, like last time.
Terms and conditions
One year warranty for all finished PCB assembly. That means repairing service is free within 1 year from date of purchase, buyers pay any shipping fees and parts.
If the damage is done on your behalf, please donate some money to my PayPal account to help pay for my time. It usually takes me 1 hour to fix a board, and I will have to trouble shoot, rework the AMT, test and repackage.
I will provide firmware upgrades service for free within 1 year from purchases; buyers also need to pay any possible round-trip shipping.
KIT will be shipped within 7 days after I get the payment.
Some useful resources
FIFO I/II KIT and Dual XO I/II R&D thread:
http://www.diyaudio.com/forums/digi...ifo-project-ultimate-weapon-fight-jitter.html
Si570 clock board R&D thread:
http://www.diyaudio.com/forums/digi...low-jitter-universal-audio-clock-project.html
I2S to PCM board R&D thread:
http://www.diyaudio.com/forums/digi...1541-fifo-universal-i2s-pcm-driver-board.html
Have fun with your audio project!
Ian
How to buy
To Canada: $4
To USA: $5
To Canada: $12
To USA: $19
To Canada: $19
To USA: $25
Notes:
Payment
Ian
More pictures of GBVI items
Manuals of GBVI items
Links of some posts and pictures about FIFO II and Dual XO II
Some posts and pictures about FIFO II:
http://www.diyaudio.com/forums/digi...mate-weapon-fight-jitter-356.html#post4322196
Some posts and pictures about Dual XO II:
http://www.diyaudio.com/forums/digi...mate-weapon-fight-jitter-351.html#post4234120
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
