Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Joined 2009
bercovici : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700
LOBOONE: PCM, 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
roger57: 1x I2S FIFO KIT V3.80
mhgawel: 1x I2S to PCM converter
nanocamp: pcm
lordvader : 1x I2S to PCM converter
flowerpot: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board,5 x pkg Universal SMT XO Adapters,2x I2S to PCM converter
4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator
Gogi x1 PCM board
JustBuildLspkAS x4 finished FIFO i2s isolator Board => FIFO ll , x4 Si570 Clock Board V3.5 => Dual XO ll , x2 spdif interface , x8 I2S to PCM converter =OK Got them
casshan: 1 x I2S FIFO KIT v3.8, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board V2.5
fordgtlover: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x pkg Universal SMT XO Adapters
curryking: 16 x Dual XO II clock board
bisesik: 1x I2S to PCM converter
MadKid: 1 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT
dant100: 1x I2S FIFO kit, 1x Dual XO Clock Board, 1x Pack of SMT XO Adapters, 1x Finished FIFO isolator board, 1x Finished Battery management board
Phi: 5x I2S FIFO kit, 3x Dual XO Clock Board, 3x Pack of SMT XO Adapters, 5x Finished FIFO isolator board, 5x Finished TPS7A4700 Regulator board, 2x Finished Battery management board , 5x I2S to PCM converter, 1 x Si570 Clock Board (at least this)
zz1969: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
kenneth_obee: 2 x I2S FIFO Kit, 2 x Finished FIFO Isolator Board, 1 x Dual XO Clock board, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board, 2 x adapters for Crystek if you still have them
SomekPoland: 1x I2S to PCM
henry97: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished isolator, 1x I2S to PCM converter.
nopants: 1x I2S FIFO Kit, 1x SPDIF Kit, 3x SMT XO Adapters, 6 x 6" double-ended U.FL coaxial cable
GhostMM : 1xFIFO board, 1xIsolator Board V2.5, 1XDuax XO clock board, 1xI2S to PCM board, 1X10P 1.0mm FFC/FPC cables, 1xPackage of Universal SMT XO Adapters
vertigen: 1xPackage of Universal SMT XO Adapters
zjerneic: 1x S/PDIF Interface Board; 1xI2S FIFO kit
lbamda: 1* I2S FIFO KIT ; 1* Dual XO Clock board ; 1* S/PDIF Interface board ; 4* SMT U.FL socket ; 1* 4" U.FL doublr ended coax cable ; 1* 6" U.FL doublr ended coax cable ; 1* I2S backdoor kit for S/PDIF board ; 1* Universal SMT XO adapter kit ; 1* Si570 clock board V3.5(with Si570) ; 1* Finished FIFO Isolator board ; 1* Finished TPS7A4700 low noise regulator board V.2.5 ; 1* SMT Finished Battery management mini kit V.2.5
johnmarkp: 1 x BIII adapter PCB, 1 x SMT connector package for BIII, 4 x 4" double ended silver U.FL
zapio : 3x Dual Clock board
Joonas: 1*I2S FIFO kit, 1*S/PDIF interface board, 1*Si570 clock board, 1*Finished isolator 2*I2S to PCM converter, 1*Finished Battery management kit
name_hase: 1* I2S to PCM converter
SalvationMen: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x Package of Universal SMT XO Adapters, 2x Additional BIII adapters PCB, 2x SMT U.FL socket, 8x 4” double-ended 50 ohm coaxial cable
sebna: 4x Finished TPS7A4700 regulator
Nige2000: 2x I2S FIFO KIT, 2x Dual XO Clock Board, 2x Finished FIFO Isolator Board, 6x Package of Universal SMT XO Adapters, 2x Si570 Clock Board, 2x I2S to PCM converters
Jogi: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board
skybug: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x I2S backdoor KIT, 1x Finished FIFO Isolator Board, 2x Finished TPS7A4700 low noise regulator board
emyeuoi: 1X I2S FIFO Kit, 1X Dual XO II Clock Board, 1X Finished FIFO Isolator Board
Nikon1975: 2x I2S to PCM converters
ernesternest: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x I2S to PCM converter, 4x 6"double-ended U.FL coaxial cable, 8x SMT U.FL socket
COX77 : 1x I2S FIFO KIT V3.80, 1xS/PDIF interface board
mikeg88: (1x) I2S FIFO KIT V3.80, (1x) Dual XO Clock Board, (1x) Finished FIFO Isolator Board, (1x) Package of Universal SMT XO Adapters, (6x) 6" double-ended U.FL coaxial cables, (1x) 2" double-ended PH 2.0 mm 7-pin I2S bridge cable, (1x) 2" 10-pin FPC/FFC cable, (1x) universal i2s isolator PCB, (1x) U.FL signal input connector board for BIII DAC
Luke: 1* Finished I2S to PCM Board; 12* SMT U.FL socket; 12* 4" U.FL doublr ended coax cable
sernikus : 2x DualXoBoard
Brumjam : 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator
zlahmoon : 2 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT
walangalam: 1x I2S to PCM converter
GaryB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator V2.5, 1 x S/PDIF Interface Board
ryanj: 1x I2S to PCM converter, 1X Finished FIFO Isolator Board, 4x Finished Battery management board
JimS:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator
badrisuper: 1 x I2S to PCM converter, 8 x U.FL socket, 8 x 4" double-ended U.FL Coax
damohpi: 1x I2S FIFO Kit, 1x Finished FIFO Isolator, 1x Dual XO Clock Board, 1x I2S - PCM Converter Board
LuisMCP: 3 x (Dual XO + i2s FIFO + Finished FIFO Isolator) + 2 x (I2S to PCM Converter + 1 x (Finished Battery Mngmnt brd. + SPDIF interface brd.)
IanS1 : 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator, 1 x S/PDIF Interface Board
bkdog: 1 x Dual XO board
mjensen: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,2x Finished FIFO Isolator
dubai2000: 1x I2S FIFO KIT, 1xDual XO Clock Board, 1x Finished FIFO Isolator Board
Aronier: 2x I2S FIFO Kit, 2x Finished FIFO Isolator, 2x Si570 Clock Board V3.5(with Si570), 2x low noise reg 2x I2S - PCM Converter Board, 2x 4 x 4" double-ended U.FL Coax, 2x Finished Battery management board
Aive: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board, 1 x SPDIF Interface Board, 1 x Finished FIFO Isolator, 2 x finished adapters for Crystek, 2 x 8" double-ended PH 2.0mm 7-pin I2S cables, 6 x 6" double-ended U.FL coaxial cable
brookbphx: 3x SMT XO adapter[/QUOTE
Myint67: 1x finish SPDIF interface board ,6 x 4" double ended Ufl,12inch double end 50ohm coaxial cable,L2S PCM board.
danielkol: 2 x I2S to PCM converter board V2.0;
nacder: 2x I2S FIFO Kit, 2x Dual XO Clock Board II, 2x SPDIF Interface Board, 2x Finished FIFO Isolator Board, 2x Adapters for Crystek, 6x SMT u.fl sockets, 6x 6" Double-ended u.fl Coaxial Cables.
chi0001: 10x SMT XO adapter, 5x U.FL input adapter, 2x finished FIFO-Clock Isolation, Board, 1 x Finished Si570 Clock board (with Si570), 1 x I2S to PCM converter
kenlaumm: 1x I2S FIFO KIT II, 1x Finished FIFO Isolator, 1x Dual XO Clock II
lazybonesxp: 1 x I2S to PCM converter, 8 x U.FL socket, 8 x 4" double-ended U.FL Coax
emrpus: 1x I2S FIFO Kit, 1x Finished FIFO Isolator, 1x Dual XO Clock
ceglar: 1x Dual XO v2.0
tubesguy: 1x Dual XO II
giordano: 1x I2S FIFO Kit, 1x Dual XO Clock (II?)
MarcellD: 1x Si570 Clock Board V3.5(with 10MHz Si570), 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT
Fridrik: 1x I2s to PCM, 4 x 4" Double-ended u.fl Coaxial Cables,8 x U.FL socket,.
Clsidxxl:1x Dual XO II
kvl: 2x I2S FIFO Kit, 2x Dual XO Clock Board II, 1x SPDIF Interface Board, 1x Finished FIFO Isolator Board
Arledgsc: 1x I2S FIFO Kit, 1x Dual XO Clock Board II, FIFO Isolator board V 2.5, U.FL Connectors/ Cables
davej:1x Dual XO II
rab28: 1x I2S FIFO Kit, 1x Dual XO Clock Board II, 1x Finished FIFO Isolator Board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT, 1x I2S - PCM Converter Board
TNT: 2x Dual XO II
hirez69: 2x DualXO II
heathkit: 1x I2S FIFO kit, 1x Dual XO Clock Board II, 1x SMT finished Battery Management V2.5 Mini KIT, 2x Finished TPS7A4700 low noise regulator board V2.5
grepap: 1x I2S to PCM converter
ppap64: 1 x I2S FIFO Kit v.3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1 x I2S to PCM Converter
Zoran: 2x DualXO II
Nikon1975: 1x I2S FIFO kit, 1x Dual XO Clock Board II
MeiT: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5
andrea_mori: 3 x Dual XO II + 3 x Finished FIFO isolator board V2.5
Crom: 1x Dual XO v2.0
Lindamar: 16x SMT U.FL socket, 3x Additional BIII adapters, 3x SMT connector package for BIII adatpers, 4x 10P 1.0mm FFC/FPC cables combo (3 cables), 4x 4" double-ended silver plated U.FL coaxial cable, 2x Dual XO II, 1x I2S to PCM convertor board
tods: 1 x I2S FIFO Kit v.3.80, 1 x Dual XO Clock Board II, 1 x S/PDIF Interface Board, 4 x SMT U.FL socket, 4 x 4"double-ended U.FL coaxial cable,
4 x 6"double-ended U.FL coaxial cable, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters KIT lot of 5, 1 x Finished FIFO isolator board V2.5, 2 x Finished TPS7A4700 low noise regulator board V2.5, 2 x Bare PCB of TPS7A4700 low noise regulator, 1 x I2S to PCM Converter
Stixx: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, , 1 x I2S to PCM Converte
ripson: 1 x I2S FIFO finished, 1 x Dual XO Clock board, 1 x finished FIFO isolator, 1 x S/PDIF Interface Board
Zoef: 1 x Finished I2S FIFO Kit (v 3.80?), 1 x Finished Dual XO Clock Board (II?), 1 x Finished FIFO Isolator Board v.2.5
palmito: 2 x Dual XO II
tagheuer: 1 x Dual XO II
jimchan : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
Luanak: 1x I2S to PCM Converter
minionas: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5
vanwykca: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, Package of Universal SMT XO Adapters, 1x I2S to PCM Converter, 1x Finished TPS7A4700 low noise regulator board V2.5.
RollE2k: 1 x I2S FIFO-II, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1x Package of Universal SMT XO Adapters, 1x S/PDIF Interface board, 1x I2S backdoor KIT for S/PDIF board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x 10P 1.0mm FFC/FPC cables combo.
sidiropa: 2x Dual XO Clock Board II
nedi: 1x Dual XO Clock Board II
bigpandahk : 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board
Eldam : Dual XO II + finished FIFO (v?)
number9 : Dual XO Clock Board II
Mikhail Vorozhtsov: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II
hsi68 : 1 x Package of Universal SMT XO Adapters, 4 x SMT U.FL socket, 4 x 4" double-ended U.FL coaxial cable
shendrik: 3 x I2S FIFO Kit
vladspb62:2x Dual XO Clock Board II, 1xS/PDIF Interface Board
blitz: 1xdual xo board ii, buffallo adapter and 4" clock cable
JeffreyD: 1x dual XO Board II, 1x SPDIF Interface board, I2S FiFo kit, 3x TPS7A4700 low noise regulator board V2.5 incl. Interfacing cables and coaxes for the complete set.
Haiku: 1 x I2S FIFO Kit, 1 x Finished FIFO Isolator, 1 x Dual XO Clock Board II, 2 x I2S to PCM Converter incl. interfacing cables and coaxes for the complete set
AR2: 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board
necplusultra: 1 x Dual XO Clock Board II, 1 x I2S backdoor KIT for S/PDIF board, 1 x S/PDIF Board
Greg Stewart: 1 x Dual XO Clock Board II
duster1: 1 x Dual XO Clock Board II, 1 x Universal SMT XO Adapter KIT
alecm: 1 x S/PDIF Interface Board, 4 x 4” double-ended 50 ohm coaxial cable
xaled: 5x SMT U.FL socket, 1x Clock BIII adapter, 1x u.fl BIII adapter, 1x SMT connector package for BIII adatpers, 1x 10P 1.0mm FFC/FPC cables combo (3 cables), 4x 4" double-ended silver plated U.FL coaxial cable, 1x I2S to PCM convertor board, 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 1 x FIFO isolator board, 1 x TPS7A4700 low noise regulator board, 1x Si570 Clock Board, 1x SMT Battery Management Mini KIT
oyvind: 1 x I2S FIFO-II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
bigpandahk : 1 x Dual XO Clock Board II, 1 x S/PDIF Board, 1 x FIFO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
kenthf: 1 x Finished I2S FIFO, 1 x Finished FIFO isolator, 1 x Finished TPS7A4700 low noise regulator board, 1 x Finished SMT Battery Management Mini KIT, 1 x Finished Dual XO Clock board, 1 x Finished Si570 Clock Board, 1 x Finished S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" double-ended silver plated U.FL coaxial cable
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
moonong1: 1x I2S FIFO Kit v 3.80, 1x Dual XO Clock Board II, 1x Finished FIFO Isolator Board v.2.5, 1 x I2S backdoor KIT for S/PDIF board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT incl. Interfacing cables and coaxes for the complete set.
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
updated mine
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
minionas: 1 x I2S FIFO II Kit, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 10 x SMT U.FL socket
Joined 2009
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
hires: 2x DualXO II + 2 x I2S FIFO-II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
josoeff: 1 x FIFO kit, 3 x finished TPS7A4700 regulator boards
Update to my order:
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Crom: 1x Dual XO v2.0, 1 x FIFO v2.0
nanocamp: pcm
Gogi x1 PCM board
sernikus : 2x DualXoBoard II, 2x I2S FIFO II
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Zoef: 1 x Finished I2S FIFO Kit (v 3.80?), 1 x Finished Dual XO Clock Board (II?), 1 x Finished FIFO Isolator Board v.2.5, TPS7A4700 regulator? much as needed for this.
Update
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
number9 :1 X Dual XO Clock Board II, 1 X I2S FIFO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Stixx: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, , 1 x I2S to PCM Converter
Updated my part....
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
RollE2k: 1 x I2S FIFO-II, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1x S/PDIF Interface board, 2x Finished TPS7A4700 low noise regulator board V2.5, 1x 10P 1.0mm FFC/FPC cables combo.
nanocamp: pcm
Gogi x1 PCM board
Clsidxxl:1x Dual XO II-1xI2S to PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
bkdog: 1 x Dual XO II board, 1 x FIFO II, 1 x BIII adaptor board, 3 6" UFL cables.
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
damohpi: 1x FIFO kit, 1x FIFO Isolator, 1x dual xo board, 1x TPS7A4700 reg board, 1x I2S-PCM board, various cables
