Help me out here
Could I not fit a super bright lamp or burner, add a fan and, external power supply???
Seeking mega super bright out-put.
ywh said:Hi jason132pop !
do not try 300w. you will burn your DLP IC.
Hi vrp_brazil !
my 270W JYS/DC can work in your projector. it is a bulb only, without reflector
price is $40, shipping is $5
okay so I guess this is the place to contact YWH to get a new bulb to put in projector. I need a bulb for an Infocus IN72
http://www.projectorcentral.com/play_big_IN72.htm
let me know what I bulb I need. Thanks.
Well I got another projector so what about a bulb for the 3M S40
http://www.projectorcentral.com/3M-S40.htm
I would rather get the cheaper ones if I can. I dont care if its not as bright just as long as you can see it in a dark dark room.
Hmm so I cant use the cheaper $40 onesywh said:Infocus IN72: 200w BSM-DC
3M S40 : 150W BSM-AC
orice is $80 each
Also I see that there is a BDM-AC H and L which do I need and whats the difference?
Hey um YWH.... Hi there um, yea, my bulb is not working at all.... I'm getting absolutely nothing as of yet....
Is the 200w BSM-DC bulb an SHP type?
because its not igniting at all...
I will check my connections tomorrow and also try to post some pics....
PJ: Infocus IN72
PJ: Infocus IN72
Hi Laven205!
yes! 200w BSM-DC bulb is correct, moneybookers.com is correct too.
Hi sdubb123 !
you can use the cheaper $40 ones, it is 200W BSV-DC, but not so bright.
Hi jhoknow !
I have no 300w BSM-AC, 300w BSV-AC can work, but not so bright, only %40. each.
Hi fgm !
like 300w, I have no 300w BSM-AC, 300w BSV-AC can work, but not so bright, only %40. each.
Hi Hynotech83 !
pleace send back bulb to me. I will check it.give me your email address pleace.
Hi sdubb123 !
Hi jhoknow !
Hi fgm !
Hi Hynotech83 !
help with Sony projector lamp and infocus lamp
Need replacement bulb for both Sony VPL-HS51 bulb,
http://www.projectorcentral.com/sony_vpl-hs51.htm
also for a Infocus X3.
http://www.projectorcentral.com/InFocus-X3.htm
Hope those links work. Also do you attach the power wires for a fee? If so what is that? Both shells are perfectly fine, just dealing with busted bulbs. Thanks in advance for your help.
Hi ywh
I received the BSM DC 200W for infocus screenplay 4805. It worked initially but was really less bright and then it heated up. Second time it did not heat up but blew up in a few minutes. Do you know what went wrong ?Should I order 200W AC or DC this time???... Please help!!!
Hi ywh
Can I send you the blew up lamp, reflector and the older (original lamp i have parts of it only to tell which lamp is required)...can you put the new lamp in reflector for me?? and also whats your shipping address??
my email address is ankitgupta711@yahoo.com
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- I got my new lamp. It is for commercial projection use. people use it to replace the
