SY said:...a 1500 pF load from a high capacitance cable will destroy it (as with the old Polk cables). ...
You forget the Polk's best trick of all. The construction was essentially 'big Litz', overlapping layers of magnet wire of opposite polarity in a clear poly sheath. Walk on it enough times and layers short. The effective capacitance of a dead short; now that's a theoretical/theological conundrum. Pretty cable though.
A 'bright' cable should be bright on all systems, if not the 'brightness' is not a quality of the cable at all.
Correct. It's potentially a quality of system matching. SY's example was simple enough. A high cap cable with a very high Zout source will sound dull, with a low Zout source (taking the Objectivist stance) won't have any sound. Is the cable neutral or dull?
fredex said:To say that all cables sound different without describing exactly what these differences actually sound like is of no practical value, DIYers want to know which is the best. The usual answer, "it depends on the system", invalidates the claim that the cable itself has 'a sound'.
A "bright' cable would be bright on all systems,if all systems sounded the same
Neither. The source component's designer is dull.
Panicos K said:A "bright' cable would be bright on all systems,if all systems sounded the same
If there was such a thing it would not matter.
I used Sy as an example as his posts are extremely rational in his approach, therefore I could not imagine him making the sort of 'wax lyrical' subjective comments.Andre Visser said:
http://www.vdctrading.com/content.asp?SubSectionID=49Andre Visser said:My experience, based on listening tests which count for nothing , is that a smaller dia conductor will sound better than a larger dia conductor, therefore silver make sense because of its lower resistance. There are other possible influences also but I dont want to go there.
Going one gauge either side has a far greater effect than the 6% difference for silver.
Give me a good reason why it could.hihopes said:Brett, sure you see no reason to believe silver sounds different to copper - but it does nevertheless.
Are you being serious? I can give a whole host of reasons why two tubes from the same line and batch would measure differently, let alone those from different decades and different factories, even if they are nominally the same type.hihopes said:There is also no reason why one make of tube should sound different to another of the same design, but they most definitely do - even those made by the same manufacturer in one era can sound different to those made in another era.
Power cables make no difference. I find it an absurd assertion that a well designed component would have a significant difference from having a single strand of silver included in the construction of it's power cable.hihopes said:There is also no logical reason why a power cable should make a difference to the sound of a piece of audio equipment, but it surely does. If you would like to get a real surprise, try building a power cable with silver wire in it - even just one strand!
Alan Hope said:Ha ha , all these stupid gullible people believing all these myths about some things of one type being better than others. The ultimate science of ABX testing proves them all wrong!
Absolutely not. ABX tests is very good at highlighting audible differences in different gear and procesing, it's done with good success often, by many amateurs and pro's.
The fine things is that you exclude the possibility of being influenced by mumbo jumbo, snake oil, outer apearance of the DUT, its price and so on. Only if there is a real difference it will be perceived.
Personally, I have done one carefully set up interconnect IC blinded test in my system, and I could (I got a statistically significant result) differentiate between an Audionote solid silver IC and a Van den Hul carbon/silver-plated-copper one.
Mind telling the results and how the test was done?
How did I perform this impossible feat? They sound slightly, but consistently, different.
Ok, if the test was performed correct and you actually identified the IC's.. did you analyze the situation, performing measurements to se if there was a logic explanation to the differene in sound?
Perhaps you need more revealing systems guys!
I actually thought so before as well but I do not think the answer can be found there.
/Peter
Re: Audio Lies - Audio Myths
You forgot my favourite:
11. The simulation lie.
Not quite a lie, just a deluded simplification. Still, an amazing number of threads are based on it
lineup said:
10. The Golden Ear lie
I´m sorry, but in fact a ABX at first seperates only those who are used to do ABX tests from those who do not really have any experience in doing blind tests.
If people are conducting double blind tests, they normally all agree, that even quite big differences remain undetected in an ABX-Test (or other discrimination tests), if the participants are not trained to do a test like that.
That´s one reason, why the two "official" blind test protocols (ITU-BS1116 and MUSHRA) are both preference tests.
Wishes
lineup said:Audio Lies are not really lies.
But they are myths. They are magic. They are unverified opinions.
It is close to plain superstition.
--------------- quote -----------------
At the dark end of that spectrum, however,
a new age of ignorance, superstition,
and dishonesty holds sway. Why
and how that came about has been
amply covered in past issues of this
publication; here I shall focus on the
rogues’ gallery of currently proffered
mendacities to snare the credulous.
1. The Cable Lie
2. The Vacuum-Tube Lie
3. The Antidigital Lie
4. The Listening-Test Lie
5. The Feedback Lie
6. The Burn-In Lie
7. The Biwiring Lie
8. The Power Conditioner Lie
9. The CD Treatment Lie
The best defense against the Golden
Ear lie is of course the double-blind
ABX test (see No. 4 above). That separates
those who claim to hear something
from those who really do. It is amazing
how few, if any, GE’s are left in the
room once the ABX results are tallied.
--------------- end quote -----------------
Audio Lies - topic & discussion
Wishes
fredex said:Ah the quest for the most 'revealing system', but what does it reveal ? Cables all sound different, everything you do to the system changes the sound.
There are other worthy quests eg a system that sounds beautiful no matter what cables you use.
There is no such system.The more I read threads like this the more I am convinced that "believers & non believers"are saying the same thing,that is ,cables "sound" different,but no one knows 100% why.RLC and shielding are now well understood even by the "foolest" of audiofools.What next?Or are there any
"golden RLC meters" out there and not all know about it yet?
The logic "I won't pay these thieves $200 for a cable"is well understood,but does not prove cables do not "sound"different.Mind can play such games too you know.
An "all in one"junk system might be a good and safe choice:It does not give you the chance to change cables at all.All has been competently designed and calculated.
Finally,the "quest" is not so much about the most revealing system,but more about a system that will please the ears of its owner.I am begining to hate my mind:It has never given me a cheap illusion
Hi hihopes
I fully endorse lineup's advice to you on the previous page. It is the best advice that you can imagine, although like bitter medicine it is not agreeable to take.
Also, note that all the (millions of lines of) audiophile anti-DBT and anti-ABX argumentativeness is the biggest waste of space in the audio enthusiasts' domain. These people are well intentioned (mostly), but really all they want to do is attack the messenger who brought them the unwelcome news that all their discoveries through informal sighted listening procedures are useless, and generally imaginary. As is all the advice they relied on for purchases, sprouting from the keyboards of the high priests of audio in the print and online media, who almost never use a proper listening test method.
I can totally guarantee you that, whatever weakness may or may not exist in controlled testing methods, the weaknesses of uncontrolled sighted listening are many thousands of times greater. Where these two test methods lead to different conclusions, there is really no contest, it is a no-brainer decision which to believe.
By all means trust your ears. But not sighted. That is 100% invalid.
Also read my signature below, and good luck in your quest for audio truth!
@ tnargs,
any dbt produces as easily false results as every other test routine.
That´s the reason why one has to use controls to show that the test results are meaningful and valid.
And otherwise a sighted listening can produce perfectly correct results, but unfortunately an observer can´t know about it.
If you train some listeners for reaching good results under blind test conditions, you´ll quite often see, that they will be able afterwards to confirm previous results from sighted tests.
Otherwise, if you do not train your dbt participants, you´ll quite likely provide a lot of false negatives on test subjects that are well known to be audible.
Thats the basic rule of science; your own (strong) beliefs just can be used to provide working hypothesis but any proof has to provided following accepted scientific routine.
For good reasons it shouldn´t be a matter of believe. Both test methods are prone to false results, so only proper scientific methodology does help to get some confidence in any result.
Wishes
Wishes
fredex said:There are other worthy quests eg a system that sounds beautiful no matter what cables you use.
My system sound beatifull no matter what cables I use, some cables make it sound more beatifull than other though.
André
Jakob2 said:Otherwise, if you do not train your dbt participants, you´ll quite likely provide a lot of false negatives on test subjects that are well known to be audible.
Wishes [/B]
I believe it is very important to be familiar with the sound of a system also, before trying to listen for small differences.
Cheers Frank. You have obviously put in the time and effort to investigate these things thoroughly. That, to my way of thinking, is the real scientific method. We have never met, have never even spoken to one another, yet, working independently, on different sides of the globe, we have produced exactly the same results. That seems pretty fair proof of accuracy to me.
Logic may provide a starting point for a theory, but without actual experiment, it can never be more than a theory. Those who have never heard the difference a cable can make will probably continue to swear that they cannot make a difference (except possibly in the most extreme cases), and those who have taken the time to try out different types of cable will know that they can make a difference and no amount of argument or attitude will convince them otherwise, because they are no longer working from logic, but from direct, repeatable observation.
The passage of electrons through various conductors is bound to be affected by the molecular structure of those conductors. Maybe this could be a starting point for understanding the differences in the sounds of various conductors.
Andre, I totally agree with your last post. I also always listen for at least a few days before deciding whether a change is a real improvement or not. In this way, I am able to perpetuate another audio myth (one that lineup omitted from his list) - the myth of "burning in".
cables... or not
Maybe the power companies should be convinced to replace all that lousy copper and aluminum wire strung throughout the world with higher quality "boutique" materials so that we can listen to music uncontaminated by the "grain"and "fog"of generator and transmission line insults?
After all, there is much more wire in anyone's system that is connected to the power grid than from the power socket to your speakers.
John L.
John L.
- Design & Build
- Parts
- I don't believe cables make a difference, any input?
