The width of the pulse is the analog, and the 1 and 0 involved in "on and off" in PWM cannot code a discrete value of the waveform absent the width component.
So it tracks based upon the analog width component, not the discrete on and off component.
I understand that. It's the 1 and 0 component I'm interested in. It's digital because it's a pulse.
But I don't really care to convince anyone of my terminology, except to say jitter is an important element in any pulse-current waveform. Timing is critical---err, more than that, it's essential.
Now this is funny ....
Class-D amplifier - Wikipedia, the free encyclopedia
Quote:
"The term "class D" is sometimes misunderstood as meaning a "digital" amplifier."
The terminology is irrelevant, Stig. Here's what I'm saying: the timing of the pulses is important, essential.
I'm not saying it does because I don't care about semantic games. What's important here is that the amp renders the input waveform a PWM version of that waveform where the timing of those pulses is essential to the amp's operational fidelity.
The best term I can find to describe variation in the timing of those pulses is jitter. Have you a better?
There is an abstraction, a CODING that makes digital what it is. The pulse width, an analog attribute, is what defines the signal output, a repeating 0 1 0 1 0 1 0 1 train ad inifinitum cannot contain an abstract variable coding, since the discrete on/off cycle is in a constant order.
A change in the timing of the PWM carrier will result in a non-reversible change in the analog audio output.
Jitter on a digital signal will not. The audio data remains the same, and can be successfully reclocked.
Yes, a non-reversible change in the analogue output. So get the timing right, yes?
You mean perfect?
Nothing is perfect. They got it right to the degree that their published specs show - and people listening to the amps can hear. Good enough for me. If you want to call a spade a forklift in your own terminology, feel free - but don't expect anyone else to agree or understand.
"Right to the degree"? That's vague fudge language that avoids real communication.
For instance, do those purported listeners know how a "righter" amp sounds to be able to say "right," which is a comparative term?
Here's my point. If comparator timing is imperfect, it can be improved. Same with forklifts. I hate badly timed forklifts.
Can I have some of whatever you are smoking?
I hate forklifts that violate the laws of quantum physics, for example those trying to occupy the same space at the same time.
Edit: The mods should be here soon and clean up.
I can hear them coming. But I don't want to lose my point in the semantic detour. Comparator (forklift) timing is imperfect, but how imperfect is it? Would a dedicated shunt, fed by dedicated series reg, fed by a transformer not clear up some ground bounce and other power supply artifacts affecting the timing of that delicate process? I think yes. Would that be audible? I think yes. Those are my hunches. I've yet to see evidence or reasoning that would suggest otherwise.
Indeed. I guess I forgot rule #1: DNFTT.
- Class D
- Hypex Ncore
