A link to a local file on your C: drive won't help him much.Here's the schematic:
file:///C:/Users/User/Downloads/'59%20Bassman%20LTD%20Schematic.pdf
Bias should be adjusted (via R49) for 60mV at TP19. This corresponds to an idle current of 30mA per 6L6GC.
Use matched power tubes.
are you telling me your running signal through the amp when doing a bias adjustment?It's illuminating to hear how adjusting the output tubes' bias changes the sound of an amp. Higher bias results in more gain and more "crunch." Lower bias results in less gain and a cleaner, more sparkly sound.
OK, I see where you're coming from. Yes, I like to tune tube bias by ear as well as measurement. I almost always like the sound of an amp biased between 70% and 100% of the output tubes' maximum safe dissipation (determined by whether the circuit is class A or AB and whether it's cathode or fixed bias), but it's interesting to listen to different levels of bias. No argument that going above max safe dissipation counts as "badly biased," but sometimes a colder bias of an amp (say 50% of max dissipation) sounds good to me, given the guitars I play, the way I play them, and the way I hear.
outch ... ! ... it's the other way round ...... But if the amp sounds better to you with lower bias (the range between –52v and –25v or so), you can leave it there. A bias setting higher than –52v (–60 for example) will shorten the life of the output tubes...
the -52V goes directly to the grids of the 6L6s in fixed bias;
so, -60V is running the tubes cooler, not hotter ... less current, extending tube life
while -25V would run them super hot, probably way into red plating ... shortening tube life by orders of magnitude ...
- Tubes / Valves
- How to bias a Fender Bassman 59 Ltd guitar amp?
