Quick calculation of costs, in the US for a Basic
Mouser - 23.87 + 10.00 shipping All but K170 and trafo
Antek - 13.00 + 10.00 shipping 2x12 50VA toroid 115 x2 primary
Tech DIY 20.00 + 6.25 shipping 2x2 match and 8 unmatched k170
Totals 56.87 + 26.25 Shipping
Board cost and shipping TBD but should give a rough idea of project costs here in the States.
If you're in Europe, I'd recommend to buy the relays from Jan Oomis:
Nais TQ-2 5V on ebay
He should still have plenty of them...
Michi124 said:If you're in Europe, I'd recommend to buy the relays from Jan Oomis:
And this is a real bargain!
check item 130318765461
Do you want to share the buy with me .
We only need 5 pieces...
I can't see any improvement here. The new version forces a kind of mounting the whole thing that I don't like. I'd be much happier if you'd keep the scoring line and the ability to separate the two boards.xaudiox said:hi guys,
i've been trying to improve the layout of the deluxe b1 and came up with a idea of removing the scoring line and making it just one whole pcb..
please let me know what do you think about this.. sorry again for another layout..
HBarske said:I can't see any improvement here.
hi thanks for your reply.
from the post of salas in post # 123
The shunt must stay physically in contact with the buffer in the tightest way possible for lowest output impedance. Same board and no connectors and wiring is optimum.
AlanElsdon said:Does it matter that they are 6V?
you can use lm7806 regulator instead of 7805. thanks
Thanks xaudiox
Keep up the very good work it is much appreciated - I like the new board.
Alan
AlanElsdon said:Sorry about the confusion - I am now also bidding on the one from the states - if I get it I will obviously share the spoils!
Alan
If you are bidding the same item, it's silly to place higher bids between us... 50 pcs are enough for 10 B1 deluxe.
As xaudiox pointed out, you can use a 7806, or add a small diode from the center pin of an 7805 to gnd (out 5.6V)
But I'm pretty sure they will work at 5V too.
Edit: somebody else seems to be interested 2 bids so far
I am the second bidder - let us hope the last one as well!
AlanElsdon said:Got them! Massimo, Korben99 - I will let you know when they arrive.
Lucky guy!
(good call, isn't it?)
Edit: maybe the vendor has more than a tube of thise realys. Let's see if he will list another one in the next days.
Well done !
Let us know how to proceed with PM
- Group Buys
- GB for DC coupled B1 buffer with shunt PSUs
