Mark: Really!
No, I was trying to send Dan a gentle message. I didn't say anything about what I do or don't find credible. You don't know me very well, maybe about as well as I know you?
Dan, your bit-identical, different-sounding files are on the same media? Both on HD? Or both on flash USB? Or is at a pressed CD vs. CD-R?
They are on his cell phone which he uses as source to his integrated amplifier. I don't remember if he uses a separate DAC or the one in the phone.
Wow!
No, we don't know each other. Therefor necessary to clearly communicate.
The message: 'Jan: Really?' does not seem to be directed to any Dan, unless there is a typo ;-)
Jan
Jan
i was originally trying to send Dan a gentle message. That's all.
I guess the message wasn't bit perfect, or perhaps it was, but it reads different?The message: 'Jan: Really?' does not seem to be directed to any Dan, unless there is a typo ;-)
Jan
Wow!
He says he copied a music file from some other device (PC?) to his phone via a standard USB cable, then copied it again (different destination directory? different file name?) via a USB cable that he treated with his magic filter. The two files are the same size, have the same md5sum, etc; he says every tool at his disposal indicates they are identical. Further, even if he copies them back to his HD the difference in sound remains. Chew on that for a while.
My local supermarket has organic popcorn on special tonight....it's quite good.A little too gentle. now its turned into a fist fight.
Dan.
I let you know when I pass the mind-reading exam.
Jan
Pavel yes, Nez has it mostly correct.He says he copied a music file from some other device (PC?) to his phone via a standard USB cable, then copied it again (different destination directory? different file name?) via a USB cable that he treated with his magic filter. The two files are the same size, have the same md5sum, etc; he says every tool at his disposal indicates they are identical. Further, even if he copies them back to his HD the difference in sound remains. Chew on that for a while.
Two folders named`xxxx - 00 and xxxx - 01 were created on a HD newly formatted and bare partition.
The dowloaded files were copied to each of these newly created HD folders.
Folder xxxx - 00 was copied to phone flash memory utilising standard USB cable.
Folder xxxx - 01 was copied to phone flash memory utilising custom cable incorporating said mixture within each connector.
So, when using Samsung S5 as a playback device connected to pretty much the full spectrum of replay systems the resultant is that these two folders play back differently.
This difference is subtle, and perhaps not properly noticed until reverting to the non 'filtered' folder.
It is then that this kind of difference becomes apparent, and universally clear preference is expressed.
The nature of this difference is essentially the same as when my cable clampon filters are applied to system power/signal cables and when combined the effect is cumulative/multiplicative.
The effect is change in dynamically modulated modulations and intermodulations albeit at low levels, nevertheless it is these interacting behaviors that dictate the subtle signature of devices and systems.
These underlying dynamic behaviors can be dictated at will.
Dan.
Same old claims, complete with same old junk pseudoscience "explanations", same lack of any supporting evidence.
Actually, there is a new claim here! When did the difference become "subtle"?
I can believe that the effect is the same. Combining two zero effects will only multiply/accumulate in the trivial sense of still being zero.Max Headroom said:The nature of this difference is essentially the same as when my cable clampon filters are applied to system power/signal cables and when combined the effect is cumulative/multiplicative.
You need to understand that the effect you are claiming cannot come from physics and information, and so must come from something supernatural/paranormal (or merely psychological).
"'Reason'" is something he has yet to offer us.john curl said:I follow you Max, but is it worth it to 'reason' with these others? '-)
Anyway, this thread is supposed to be for laughing at nonsense not promoting it.
- Member Areas
- The Lounge
- Funniest snake oil theories
