Full digital amplifier with chip STA326
Hi guys,
Here are some pictures of my FDA-Phone Amp using the STA-333 board !...
First tests are really amazing compared to more "classical" phone amps, even balanced ones !
Hi Burgunder,
I opened a thread on Head-fi DIY headphones forum... Here is my opening post...
After testing several FDA units (Topping, FX802, YJHiFi, etc...) most of them based on STA326 chips, I found a board based on the 333BW circuit, and the idea was to derive a high quality audio DAC-Amplifier for headphones with it...
Here is the board :
https://fr.aliexpress.com/store/pro...108.1000016.1.7f75b2ee6zYumR&isOrigTitle=true
Below are some pictures of the resulting DIY unit...
The audio quality is really amazing for the price of the prototype. Perfect silence without modulation then no noise (the so-called "black background"), very high fidelity of the instruments and voices (I have a "personal" reference...), crystal clear sound and very good dynamics ! In addition, this is a fully balanced unit.
The very important points here are that there isn't neither any DAC nor any Operational Amplifier in this device !... Thus, the path is very short between the digital signal and its audition through the headphones. These are the most important reasons of the very good audio quality obtained with this little board. The PCM is converted in PWM...
My Best
mods picts
We made a few mods in order to have 3 different levels of attenuation to address almost all Headphones whatever their sensibility.
Here a the picts of the mods...
Hi y'all,
So I finally bought a YJ HiFi STA326 amp and wow, I'm impressed.
I found a few issues - one is "dangerous" - there is a cap rated at 25V that will receive the input voltage, which if you followed the maker's guidelines could be 32V less a schottky diode. So use 24V until you get that cap out :)
I've done a few changes to the amp - on my blog if you're interested.
Pure Digital Amplifier and APTX-HD | myL8test
I doubt I'll ever build another DAC again.
Cheers
Nanoloop, i have a similar situation needing the supply voltage near the caps rated voltage... . so i really trying to get your opinion as my confirmation for longevity of amplifier :D
It goes like this:
Gotten china-made amp, while its Class D chip datasheet recommends 32V (max operating at 38V), china-factory bundled with a 24V SMPS. However at this voltage, Class D amp not running at optimal power/min distortion.
I though of using 32~36V SMPS, checking its China-made amp PCB found a 25V cap which seems on side after LM2596 DC 12V regulator (ie. 24V/36 is not a concern). However rest of caps mostly rated at 35V, a couple 50V caps; so the question is:
How close the supply voltage can these caps handle safely on the long run without blowing-up or risk bring any danger (assuming on-board semiconductors could handle)?
Appreciate any thoughts...
Do you need to max the output? These amps sound best at a couple of watts not full power. There are benefits to having a higher current available because this usually infers a lower output impedance which translates into better dynamics, but it doesn't mean you need higher voltages to get the best sound.
Caps can withstand higher than rated voltages for very brief periods before they will suddenly hiss and spit out fluid...and are dead. To achieve the stated hours of life, I've seen datasheets recommend keeping them at least 10% and preferably 20% under their rated voltage - so a 35V cap at 28V to 32V. YMMV. I've never actually had to replace an "old" cap before so I don't have experience.
what is in Alientek D8 compare to other FDA which your recommendation? hope to learn more, as am an amateur on these FDA amps.
Comparing the D802 and D8 both have high quality SPDIF digital inputs and in this mode sound essentially identical to me. Both are good choices if your primary source is SPDIF.
The D802 has an poorer USB implementation and performs, to my ears, significantly worse with USB input that SPDIF. The D8 however has (for one of these cheap amps) an exceptionally good XMOS USB input and with this performs equally as well as with SPDIF so if you want to use USB this is the clear winner. The D8 is also available with an alternative cheaper but still decent quality USB implementation rather than the XMOS, I haven't listened to this but would expect it to be rather better than the D802.
The D8 is also physically much smaller and indeed rather cute. It's display and user interface is different so have a look at the model details and see which you prefer for that.
