Telstar said:
Did you compare it with no filter at all?
Yes, I know some NO-systems. I do not understand why people are so font of NO. To me, oversampling is a must!
Ongoing
Thank you Herb!
Will still have to see, how to manage the replacemnet for my old BB DF1700... As you know I'm using the BB DF1704 (on DIP Adaptor), or the SM5842APT (on a seperate Adaptor).
Moreover, I just purchased a SM5847 replacement for the DF1700, on an Adaptor-Board, from China (as I'm in Taipei right now). My 3rd Filter...
Does not matter: Be sure, I'll be happy to give them all away. Half a year form now? Deal!!
Hmmmmmm... and then, shell I connect the Tent XO2.3 from my Transport, à la Rutgers DACPrincipa4 (through the external BNC cable, bypassing the receiver to the XTI pin nr. 6 on the new DF replacement???? Or may be - there will be no more XTI ??? whatsoever..)
OK, OK, I'll wait to have more info, once it becomes actuall.
Herb, it will be great to finally bypass the terrible influance which any/every common DF has on the sound!!
Last question: What will be now with your reclocking??
Greetings & Thanks
Thank you Herb!
Greetings & Thanks
Re: Ongoing
The reclocking will still be needed!!! between the FPGA and the DAC's...........
irgendjemand said:Thank you Herb!
Greetings & Thanks
Re: Re: Ongoing
Stopped Clock Mode on the FPGA? Same 74HC (etc.) Gates?
Re: Re: Re: Ongoing
Yes Sir.
Yes Sir.
With a DAC PCM1792 no reclocking any more
Hi IY,
as we discussed already at the Phone, you do not need reclocking any more if you use a PCN1792 DAC. You could find a complete description of the application in:
https://www.by-rutgers.nl/PDFiles/Balanced IV-converter.pdf
and
https://www.by-rutgers.nl/PDFiles/I2V details.pdf
and the Dutch (sorry):
https://www.by-rutgers.nl/PDFiles/CD624 met PCM1792.pdf
Succes!
Herbert.
Hi IY,
and
Succes!
Herbert.
- Digital Line Level
- From Transport to DAC - the different modes
