Just read the article i just posted above the woofer you have is from DIY CABLE. Kevin Haskins designed and sold these.
The soundstage article on link is not valid.....bummer
Never mind...found it...The Kepler article
Could you post the link?
dave
Here or do a google search on Exodus Audio Kepler Loudspeaker April 2008
SoundStage! "D-I-Why & How" -- Exodus Audio Kepler Loudspeakers (4/2008)
So which one is better? The small motor on the SDX7 surprised me when they first arrived. The 'breakup' shows they are not useful as a midwoofer in a 2-way without treatment and the glowing reviews of the Kepler suggest that the EX-6.5 is a great mid-woofer.
That being said I have liked the sound of my SDX7s in various speakers I have built. Would like to go 2-way with it though.
The ‘breakup' shows they are not useful as a midwoofer in a 2-way without treatment
Minimal treatment is easy and AFAIC essential.I take it further and EnABL on top.
dave
Here was a test i did with my mods on the SDX7 woofer. Unmodified was in yellow and modified cone treatments are shown in red.
This was a quick test i did to see if 2 coats of the puzzle coat as Dave had mentioned had any effect on the fr of the driver. I then took it to 4 coats on the top and 2 on the underside. Mixing the puzzle coat 50 50 mix with water. The fr changes were suttle after i did this longer process just thinner coats. The main difference was in the distortion. Better results with thinner coats top and under the cone. Was it worth all the extra work over the 2 coats. Well personally i never used the SDX7 in a 2 way. I used the SDX7 in 3 ways. The one design i did for a SDX7 and the RA104.5 ribbon in a .75cft cabinet was for a single client.
- FR125S/SDX7 2-way
