Thanks for the vote of confidence. I am attempting to demonstrate that the WAY better can be quantified.The Smith & Larson WT2 is WAY better than the WT3 (at least for T/S, i don't use it for anything else).
dave
And in the spirit if DIY I am showing how to make a speaker emulator that any user can construct to check the accuracy of their own T/S parameter measurement system.
I will say I vote for the WT2.
I had purchased mine from PE when PE was selling them.I believe it was purchased in 2007.
Ok I never used it or even opened the box.Well just a few months ago I had to test several hundred tweeter for CSS and wanted another way to confirm measurements I was getting.
Well a few hours of trying to get the WT2 working I contacted Keith Larson threw the woofertester.com site with in 1 day of my email being sent I was sent a contact info.
No promise was made from Keith as it was purchased years ago. Keith said please send it back.I sent the WT2 back and I was issued another one FREE of charge.And that was over 6years after I purchased the WT2 from PE.(mine was a defective unit)
NOW THAT is service...
Get the ORIGINAL WT2 not a copy or clone. With that you get a great product and service.
woofertester.com
Now I use the WT2 at least 3 times a day for testing products.Next will be a WT PRO to add to my Praxis, Sound Easy and LSP Cad PRO tools.
Thanks Keith again great product and sevice
woofertester.com
With cap values from 15000 down to 1800 uF the Fs is in the ballpark, but Qts is way off. Like .0019
Maybe my circuit is wrong? Isn't it just cap and coil in parallel?
Yes the circuit is just a cap and an inductor in parallel. The inductor has a resistance in series that is very helpful to make a great Qt emulator. The L and C make the Fs component.
By the way, the Fs measurement of the WT3 is discrete steps. You can see the steps if you start with 15000 uf and add small amounts (10 uf) in parallel in steps and test each step. You will see no change in Fs for a while until there is a jump.
It has been my experience that the Qt is way off for the WT3. That is kind of the whole point of me participating in this thread.
I am willing to send you a WT2 so that you can measure your various emulator configurations and see how accurate the WT is. The only requirement is that you will post your results in this thread and show the entire community an unbiased comparison.
I'm a bit confused here... I'd like to run the test with REW and Speaker Workshop which are the two programs I have always used for testing T/S params, however you need to take a second measurement with either added mass or in a known volume before you can calculate the T/S params. Does the WT2 and WT3 display the Qms/Qes/Qts without the second measurement (which is required for VAS)?
Do you just do two measurements one with a bigger cap to simulate dropping the freq with added mass? and take a guess as to what the added mass would actually be?
Tony.
Tony.
The purpose of the emulator is to test the accuracy and precision of your tester.
Testing emulator Fs reveals the frequency resolution/precision/accuracy.
Testing emulator Qt reveals the complex impedance resolution/precision/accuracy.
As you indicated, if you wanted to simulate/emulate the Vas test you would add/subtract capacitance to simulate/emulate the new Fs of adding mass. That test would be redundant. If the tester can resolve Fs extremely well, then it will be good with the mass-added Vas measurement.
Bump for WT3 test lead resistance calibration problem solved by following these steps. I also set the "USB Audio Codec" mic input to default just to be sure. Also, Windows 7 sets the input level to 100 by default and this must be changed to 1, per below and per the instructions provided with the WT3. Thanks!
Hi ThyDntWntMusic,
As others have said in this thread, problems with the WT3 are 99% of the time a PC/OS issue, not a faulty WT3 tester.
The WT3 tester is a great tool when its working properly and here’s my findings to have it working without issues:
1. First of all, always plug in your WT3 tester in the USB port before starting the WT3 software. Give the PC a couple of seconds to recognize the device before starting the software.
2. In the Control Panel\Hardware and Sound settings (win7) check the following settings for your WT3 device (USB Audio Codec):
a. Playback\Properties\Level. Set the volume to 100
b. Playback\Properties\Enhancements. The Enhancements properties should read “Status: Disabled”.
c. Playback\Properties\Advanced. Default Format: 16 bit, 44100Hz (CD Quality). Exclusive Mode: Both check boxes marked.
d. Recording\Properties\Level. Set the volume to 1
e. Recording \Properties\Advanced. Default Format: 2-channel 16 bit, 44100Hz (CD Quality). Exclusive Mode: Both check boxes marked.
f. Sounds. Sound Scheme: No Sounds.
3. Give the WT3 tester a 2min warm-up before doing any measurements or calibration.
4. Connect the calibration resistor and do an “Impedance Calibration” (It’s not needed to do this every time you start the WT3 tester, but if you think your calibration is corrupt or if you have “Restored the Default Calibration” it’s necessary to redo it.
5. Do a “Test Leads Calibration”. It should be in the range of 0.26-0.30 Ohm. The “Test Leads Calibration” can be done every time you use the WT3 tester.
6. Make a test “Impedance Sweep” with the calibration resistor connected. You should now get a smooth measurement.
My general recommendations are:
1. Buy a better precision “calibration resistor”. Mine is in the range of +/- 0.1%
2. If having strange readings, try to “Restore the Default Calibration” and then redo the calibration.
3. Always use the same USB port every time you use the WT3 tester. Use a USB port that’s not shared with anything else. If you have problems, try switching USB port until you find a stable one and redo the above calibration.
4. Try the WT3 tester in a different PC/LapTop
I’m sure you have done most of the things above and you might actually have a faulty unit, but perhaps there are other readers of this thread that found it useful in their problem solving.
Personally I’ve had very little issues with my WT3 tester, but it can occasionally occur. Then I follow the above instructions.
/Göran
Have you tried checking the Qts accuracy with my earlier posted Fs/Qt emulator? It is dirt simple to construct and use. Everyone should verify the accuracy of their test rig.
My test results are also showing big Qts inaccuracies using my WT3. Here is what I measured:
Fs calculated: 59.7
Fs measured: 62.6
Qts calculated: 0.198
Qts measured: 0.226
Yikes. I'll take you up on a comparison with the WT2 and post the results. Send me a PM if you are interested.
Brian
Caveat: I am using an inexpensive multimeter to measure capacitance and inductance. I don't have a standard to verify its accuracy.
Fs calculated: 59.7
Fs measured: 62.6
Qts measured: 0.226
Brian
That's my problem, too. Will be building a test rig this weekend for accurate (I hope) L & C measurements.Caveat: I am using an inexpensive multimeter to measure capacitance and inductance. I don't have a standard to verify its accuracy.
Let's see what Pano comes up with for a DIY test rig to measure L and C. At this point you don't know if the inaccuracy is the emulator parts or the WT3.
If Pano's rig does not pan out, I am willing to test your emulator parts individually and as a circuit for exactness of Fs and Qt and send it back to you.
I have thought of offering such a thing as a product. It is unnecessary with a WT2 since the Fs and Qt error is less than 1%.
The issue comes about because PX claims that the WT3 is faster and more accurate than a WT2; that the WT3 is an upgrade of the WT2. All of these are not true. The WT2 can perform "Snap TS" which is a fast TS function using a chirp or a pulse. We don't advertise it since there are accuracy issues with the methodology. The WT2 is much more accurate than a WT3. The WT3 is not an upgrade. It is missing L and C measurement. It is missing box tuning alignment. It is missing the box simulator.
You spend $100s or $1000s on your speaker parts. You save $60 by buying a Chinese built knockoff of the WT2. The WT2 is built in the USA and supported by EEs in the USA.
For those wanting to trade in their WT3, I will accept shipment of your WT3 and give you a $60 trade-in allowance. You will have to email me to get permission individually.
Fs calculated: 59.7
Fs measured: 62.6
Qts measured: 0.226
Brian
For those on the fence or not even on the fence with the WT3 which is a copy of the WT2 get the original if you can. Product and support is GREAT...
the WT3 which is a copy of the WT2...
The only thing that is a copy is the name. WT2 iteratively probes the DUT to obtain the key data directly to derive T/S. WT3 runs an impedance sweep and then tries to derive the T/S indirectly from that.
WT2 HW has a built in current amp, not so sure about WT3
dave
dave
That is correct
Most of the public rather think they ARE getting a new improved WT2 when they purchase a WT3.But not the case The WT2 is a product that was copied and named in sequence to refer to the public they would be getting the same produce (WT2) but a newer version.WHICH IS NOT FACT.
Does WT2 work with Win7 and 8 and is it going to be guaranteed to work with future versions of Windows? The woofertester.com site only lists Vista, XP, 2000, ME and 98.
I'd like to buy a WT2 (and get rid of all my desktop computers and t/s measuring jigs) but if it won't work on newer operating systems there isn't much point.
I'm almost getting ready to buy something, I'd prefer the WT2 over the WT3.
Also, if the WT2 can work with Win7 and 8 and will be guaranteed to work on newer operating systems, please update the website. I suspect a lot of business is being lost over an outdated website.
Yes Win 7 and Win 8. Every time MS comes out with a new OS the WT2 s/w is updated.
The latest version auto-detects the OS and sets up the s/w to run correctly. Earlier versions required some tweaking of audio mixer settings based on OS.
s/w downloads are free. Last I checked, WT3 charges for software updates.
- Design & Build
- Equipment & Tools
- Faulty Dayton WT3...
