I can of course put the extra LEDs in to bias higher (as Generg suggested), but since the amp did before bias up to 1.55 amps, would that just be a bandage in stead of a fix? - or would that actually fix the gate leakage difference issue?
Don't know, but it would be worth trying. It's possible that you have
damaged the Gate, but that is not indicated by anything other than the
change in bias.
Since SemiSouth is obsolete now, what is a substitute for SJEP 120100?
Thank you
R125s, which you can still get from Semisouthfan.
Jugi63,
Can you clarify which resistor (or resistor values) you measured he 7.xxmV which you indicated for leakage current. Nelson once said he used 20us as limit as he had some experience with those with high leakage having higher likelihood of premature failure. I had a few that had gate leakage current of 500uA. I could rig it to bias up but this also means more DC through the Jensen, not sure how much before core gets saturated. And I wasn't going to risk my speakers.
Sent from my C6903 using Tapatalk 2
The IRFP240 is a good (cheap) substitute. Other parts that will give
comparable gain, distortion and bandwidth are the UJN1208K and the
IXTH20n50d.
The IXTH20n50d although a depletion mode part, will self bias to the current
you want with a little ballast resistance. The UJN part will require substantial
negative bias voltage.
Jugi63,
R7 for 7.xx mV
R8 for 0.28mV
After two LEDs I got the bias up to 1,6A and Gate leakage was 0.3mV and 4.xxmV.
I swapped the jfets with each other to see if that changed anything. The 0.3mV value followed the jfet.
- F6 Amplifier
