korben69 said:Two questions about 74s and 170s :
1° - Do they need to be matched for the F4 ? (I've don't read it but I'm a newbie so... I'm asking the experts ! )
2° - How to match 74s and 170s ?
Many thanks to all.
Wish you stars for this new year.
Mine don't match, but I noticed that the difference does show up as a small voltage mismatch which can be adjusted out with the pot that balances voltage between upper and lower groups of mosfets. IIRC, the voltage mishmatch seemed to match the difference in mismatch between the jfets.
korben69 said:Hi Carpenter, thanks.
Where do you place the pot to adjust voltage ?
I've missed the link... what are the specs of the pot ?
I'm rusty on which pot (P1 or P2). Just read the text and use the pot that adjusts the offset voltage.
Edit: According to Peter Daniel's checklist, it's P2 that adjusts the DC offset. BTW, he's ordering more F4 pcbs. Go to his thread and purchase some if you're able.
anubisgrau said:
not much DIY job left on that link
Jacco is Jaccovitty
he meant that there you certainly can find one - in one piece ....
are you really so desperate , regarding F4 ?
Zen Mod said:
Jacco is Jaccovitty
i don't know what you mean by desperate, i've just thought that some shops would be clever enough to offer all the parts for sale - at least that's what i'd might do if selling parts. no hard feelings anyway
there is no hard feelings , in any way ;
with "desperate " I meant - are you so curious to try F4 ......?
FR fever
Re: Minimum Impedance
Oooooh, why not add a mirror disco ball and get back to us when it's all over...
chrismercurio said:
Will I have a cool arc welding light show in my living room?
Thanks,
C
It's stable into anything I've tried. Depending on the values of
the Zener diodes, you will run out of current. Sotck, it poops out
around 10 amps peak, implying full swing into 2 ohms.
chrismercurio said:How stable is the F4 when connected to speakers that drop below 4 ohms? 2 ohms? 1 ohm? Will I have a cool arc welding light show in my living room?
Re: High/low bias function?
why?
Skorpio said:I was wondering if it was possible to implement a low bias function for back ground listening?
I was thinking of af switch for changing the bias setting resistors?
why?
No reason why not.
I was thinking of a switch for changing the bias setting resistors?
No reason why not.
- F4 power amplifier
