F4 power amplifier
Official Court Jester
Joined 2003
F4 is pretty close to "wire with no gain", bringing not so much of own character in game
pretty much, everything you hear is character of your preamp
and , that applies from 0V of input to F4 and all the way to clipping point which is , say, in range of 40Vpp
of course that THD of F4 is rising with output level, but I can bet that THD of your preamp is rising more rapidly ......
Joined 2003
let's be realistic, all mine are .......
Hello everybody, read many posts in the thread but it got too long for an absolute non-tech like me... started the process of building an F4, a skilled tech will build it for me, got the boards with the mosfets and the 4U case (in black flavour), next step caps and transformers but still bit nervous about my choice of heading the F4 as many suggested since preamp being an old AR SP9 with 20+ volts gain which should match with the F4, at the bottom mere (...) 90db/w speakers but with a small listening environment 25W should do it (using a KT88 push-pull now which sounds pretty nice to my nerd's ears).
Would it go all well (which I have no doubt on the builder's end) are the SP9 and 90db/W JBL L220 good match with the F4?
In a future occurrence how about a BA-3, is it easy as a DIY for a beginner and a good match with the F4? I would move the SP9 and the tubes to another room (along with turntable) and wondering about the BA-3 to remain in the Pass environment.
Grazie
Joined 2010
Since we are on the subject about preamps….
Any chance a XP-22 would have enough voltage gain for the F4? I can’t find any listed maximum voltage output, only gain of 9.3dB balanced. Speakers are efficient 93dB with impedance mostly around 10 ohms dropping to 8 at the worst.
I have a bad itch to try this diy FW amp thing out and can’t decide which to try first. Main amp is a XA30.8, not looking to replace it. Actually looking for some of those unique presentations Papa puts into his FW designs to give a different presentation than the XA30.8. I’ve read enough F4 threads I can’t remember who said it (think is was 6L6) but someone made a comment for those of us who live off vinyl with a good phono pre the F4 is the bomb if you preamp can drive it. They also commented that compared to the F5 is was maybe a kinder and maybe richer presentation which is up my alley. Phono pre is a XP-25 which does kick out plenty of voltage and everything is run balanced.
If the XP-22 will not have enough drive for the F4 I understand you can add the BA3 input gain stage which basically gets you to the BA3 amp with complimentary output stages. My naive understanding is that the BA3 gain stage shares characteristics with the .5 and .8 Pass amps which I think would push the presentation toward my XA30.8.
Thanks for any input, I love the simple elegance of the F4 just not convinced my preamp will match up well enough to reach the amps potential.
Joined 2010
Everyone says the same about the F4 and if it worked out it I would build a second to run mono balanced. Without voiding the warranty, any chance there is enough gain/voltage? Or do I look elsewhere like M2x, AJ, F6? I have some Tokin SITs set aside for Papas Tokin “VFET” amp so haven’t looked at the SIT amp versions.
Dear Audio Friends,
I am thinking about exchanging the F6 channel boards in my First Watt DIY amp with F4 boards.
My preamp (DAC) is a Gustard X20 Pro connected directly to the FW amp with RCA interconnects. The DAC gives the following output voltages.
  • RCA output level:3Vrms @ GAIN=+0dB
  • XLR output level: 6Vrms @ GAIN=+0dB
The gain of the preamp can be changed to +6db and +12db (not sure how much voltage gain this gives).
My speakers are open baffle, with the Lii Audio Silver 10 driver on top complimented by a 15 inch helper woofer (15PR400) driven by a SAM300D plate amp (taking high level input from the full range driver terminals).
Lii Audio Silver 10 Sensitivity: 98.6 dB(2.83V/1m)
My room is 4 x 4 meters.
My questions:
  • Will the DAC/Preamp + F4 combo be able to drive the Silver 10 driver to normal listening levels?
  • Is it correct that +12db volume gain will translate into 4 extra voltage gain (resulting in 3 volt (at 0db) + 4 volt (at 12db) = maximum 7 volt output over RCA?
Thanks for any input!
Regards,
Koos
Dear Zen Mod,
Thank you for your quick response, much appreciated (as well as all your other shared information, very helpful!) :)
Unfortunately, I could not find the maximum output voltage, the only information regarding output of the X20 Pro what's in the manual is this:
Frequency response: 20-20kHz /-0.08dB
SNR: >126dB
Channel crosstalk:-138dB @ 1kHz
THD+N: <0.0006% @ 1kHz
IMD: <0.0006% @ 1kHz
RCA output level: 3Vrms @ GAIN=+0dB
I searched the web and found several other threads about this DAC and people "complaining" about the abnormal high output voltages. However, no real numbers were given for the maximum output voltage.
Is this something I can just measure myself, for example by playing a test tone and measuring the RCA connections?
Regards,
Koos
Joined 2003
aha, in that case let's assume that they're logical
F4 having RCA input, so taking RCA in account
X20 - 3Vrms at 0db gain
means 6Vrms for 6db of gain
means 12Vrms for 12db of gain
12Vrms on input of F4 will give roughly 12Vrms on F4 output
12Vrms@8R is (P=Urms^2/R) 18W
which is almost 25W@8R , as F4 is declared (25W@8R being 14V14rms)
so, just try it .......
if you want to be sure , play 1KHz/0db sine with your DAC/pre , put DMM in RCA output, set to Vac, and write down measured values for 0db, 6db and 12db gain
black probe to RCA shield, red probe to RCA hot
Dear Zen Mod,
Thanks for your clear explanation! This is not only helpful for me for this specific topic, but will help me to calculate these thngs myself in the future :)
I will measure it accordingly for the ease of mind and order the PCB thereafter. I think it will be a wonderful combination, as the output stage of the DAC is a superb sounding one to my feeling.
Will post the outcome once the F4 boards are being fed by the X20, can't wait!
Happy 2022
Regards,
Koos
