Looking at my past posts....I think I misrepresented some facts a bit. The Upsampling board does not share a rail with VA on CS4398. However the CS8416 has a single PSU as standard.
I wasnt completely misrepresenting....just a bit.
PSU is still a massive influence on audio performance.
This thread is about the (Gigaworks) CS4398 kit.Also...
Input on this DAC would be appreciated
As for a tube output stage I do know of a guy that used a tube stage from diyhifisupply and is very happy with it.
I just came across this impressive thread and have only zapped through some posts yet. It seems that for best sonics output transformers are preferred here.
I consider integrating this DAC in my new tube pre-amp. Because I don’t need low Zout (no interlink to drive) and the CS4398 has a normal line-level output, is a transformer still the best way to go, or can I tap the signal from the inverting- or non-inverting outputs by a coupling capacitor? Does anyone know the offset voltage at the output of the DAC?
Peter
Peter
Caps
I find that the best caps such as the Dayton foil sound better than any affordable transformers like the Jensens to block the 2.5V DC and I run with no ultrasonic filter.
Peter
Same
The offset voltage is the same +2.5v on both legs of the output so you can connect a trans primary across them with little to no dc current flowing as long as you don't center tap to ground.
Scott, thanks for your reply.
Is the offset voltage on both (+ and -) outputs the same, or are they inverted just like the signal.
Peter
The new "Lars/gigaworks dac" seems to be ready.
Gigawork Balanced DAC CS8416+CS8421+PCM1798 USB DAC W/ Headphone amp | eBay
$320 for that thing is insane....
Even the shipment at $60 is a rip-off.
Here's the Audio-GD NFB 5 with much better design, case, power supply, no OP's.... and the shipment is cheaper as well!
ºÍ§Óµ响
http://www.audio-gd.com/Pro/Headphoneamp/NFB5/NFB56.JPG
Boky
ºÍ§Óµ响
Boky
- Digital Line Level
- Experience with this DIY DAC ?
