Experience with this DIY DAC ?
@ Bill,
I read through the connected posts again and decided to try a 2.2k Resistor across the primaries. The DAC-chip sees about 1.5k now and the trannie about 300 Ohm. I guess that's better and yes it sounds more convincing already, but have to listen more.
See:
Does the non-descript trafo sound as good as the UTC? If so tell us the make/model/price as the UTC is said to be one of the best!
Just thought I'd report on my Sescom MI-97 trafos a pair of which I bought on ebay for $50. Great value, great sound - still to be tweaked http://www.diyaudio.com/forums/digi...c-ouput-using-transformer-10.html#post1972721
The non-descripts are 1:1 600ohm Japanese trafos that were pulled from a Ramsa mixing desk.
They do sound quite nice(musical and well balanced) but I have become increasingly addicted to the A-20's(UTC) stupendous bass. What's more - in identical setups I'm getting a substantial amount of hum(past 12 o'clock) from the board with the non-descripts so I find myself listening to the dead quiet UTC equipped board more often.
Which do I prefer? I would say that in an already bass heavy system I might prefer the non-descripts. In a system that needs more weight the UTCs are definitely the ones to go for.
PS - in my post I wrote 0.0001uF caps across primaries. I meant to write 0.001uF
Because the topend sounded not good I did some experimenting with listening and measuring with audiotester.
It looks like there is a 6 dB peak at about 33 kHz after which it goes down rapidly. With the RC the peak gets lower but a small peak at 20 kHz.
With the primary C there is a small influence too.
Then measuring the phase it looks horrible with the C's in!
Out the C's and the phase is flat between 200 and 20KHz.
Listening I did with Hallelujah by Bon Jovi. With the C's the voice gets really cracky, raspy, without the C's it sounds natural.
Next step try the listen to the difference of the shunt-R on the primary.
Maybe with it it sounds a little bit sat on.
So far..
Thank you all; especially Bill
Having lived with this DAC for some months set up with serial resistors and a small teflon across the inputs along with a small teflon/resistor, in series, across the secondaries to my A-20 transformers, I found that the treble was becoming very 'metallic' and shrill. It also seemed that there were some phase anomalies. I have also taken the whole dac off breadboard and fitted it in a 12"x6" 1/4"thick 'U' channel of alloy. This emphasized the above problems!
I have now put a 1k resistor across the input and lo behold it has not only solved the above problems but has given an enormous up in the overall sound quality. The most noticeable to me are that the sense of recording location is now very much improved and that solo piano has taken such a vast improvement in terms of control of attack and delay that the sound is now far far more credible than it was before this change.
Thank you!
This is the setup with my DAC:
There is a pair of LL1517(thanks Havoc08)with 2x560ohm in series with the primary.A RC at the out put with 1k and 2,2n.
The first thought was that it sounds more relaxed than the onboard opamps,
will listen more...
Is there any dissadvantage to leave the opams on the board,while taking the signal trough the trafos?
will listen more...
just disconnect the 12+12 supply ;)
will listen more...
Np ryssen. I will follow you findings closely as I have not had time to experiment myself yet.
Have you tried different resistors?
What type of caps are you using?
What does your setup look like at home and which music type do you listen to?
just disconnect the 12+12V supply
How about using a 12V battery for the 9V supply?
@brianco
For me the sound gets much better with a low sourceimpedance to the trafo.
I lowered the seriesresistance from 2 x 220 to 2X 47 ohm.
Everything improved, more natural and strong bass, cleaner and brilliant highs and more depth. A parallel resistor at the primary lowers the sourceimpedance too but for me it gave a loss of dynamics and sounded a bit strange.
Maybe I'll lower the seriesresistance to zero. Hope the dac doesn't mind.
It looks like the impedance is more important for the trafo to be right then for the DAC-chip.
The datasheet and measurements confirm a lower phasedifferense in the bass with lower sourceresistance. Distortionmeasurement gave at least 6 dB less distortion and 20 degree less phasechange.
@ Ryssen
Try the above and I'm sure you will hear a clear difference!
ryssen, I will too - I haven't had a chance to experiment with my LL1517. I tried them with 1K across primary, I think & i didn't like the sound - it was lack top & bottom end but this was just an quickie lash-up to get a flavour of their sound - I knew it was far from ideal.
I got my Sescoms MI-97 & connected them again quickly to get a flavour of the sound - much more open top & bottom but I need to tweak a bit before I comment further. I'm not using the DAC or board in this thread :)
No not yet
The caps where some orange ones I had in the
junkbox.
The setup is Squeeze box Duett,Roland M-1000 digitalmixer-DAC-F3-and homemade speakers with 12" sub.
I listen mostly on hard rock ex.Joe satriani and similar.and some jazz to.
No dont...I tried that by misstake,at first start I had no resistors at all,there where sound about 10 seconds then nothing until I pulled the mains plugg and inserted it again,then 10 seconds again....so the DAC doesn´t like that..
Yes,i will try some 47 ohms if I have some home.
