Do you know how NX compares to N sonically ?
NX is clearly superior to N, I prefer them but they have the disadvantage that there aren't much values in that series and working voltages are low. 22 uF/47 uF 6.3 V and 0.1 uF 50 V are used most by me.
I'll check prices of N series 1000 uF 50 V for you, Peter.
Do you know how sonically NX compares to N?
I had NXQ's on my original IGC's and also in my modified Arcam A60's. They do sound very good after the have burned in but for a coupling cap of 4.7uF I don't think any electrolytic beats a polypropylene.
Peter Daniel said:You ever heard about people using film caps in PS? Well, some do. Even Sonic Frontieers tried that at one time.
You need around 212 film caps of 4.7uf to make 1000uf.
If you get higher values, better still, you need less of them.
But I would be curious how one can get these caps near the chips' PSU pins.
A wrong assumption but a very understandable one. Please compare them and report your results.
I have a hard time deciding which ones to use where in every case I want to replace caps. I like film caps because of their practically unlimited lifetime but soundwise N and NX can be better.
miguel2 said:I am using Elna Silmic II (1000u/50V) with very nice results when compared to the standard (I think Daweo) caps I had. But never compared it with BGs.
Miguel
Have you bypassed the Daewoos?
Curiously, I've used Daewoos too on a GC I made, but bypassed.
High-end to me and to everyone than listens to it.
Now this is exotic.
Our local BG prices (excl. VAT)
http://www.acoustic-dimension.com/
While the Super-E config of two BG N 4.7u/50V ain't the ultimate, it does offer good performance/price ratio. No-nonsense upgrade for the budget cd player modder I would say.
Personally I would spend a little more for an even better sounding coupling cap in a power opamp amplifier with such a low parts count.
Peter Daniel,
You keep amazing me with your results and experiments. You seem one of the few that actually tries in stead of spreading the word by hearsay.
Kudos to you.
Interesting about your super-E config test and standard versus the supposedly better N series...
Peter Daniel,
Kudos to you.
I have! I used an NXQ in my original IGC monoblocs as I had some handy and they were ideal with the lack of space.
I used polypropylenes on the next three Gainclones and have listened to all these amplifiers (and my modified A60's) at length.
I would say that the NXQ probably comes nearest to the sound of a film cap in that position although I have not heard all the 'exotic' alternatives.
If I remember correctly, the polyprops are a bit cheaper than the NXQ's (at UK prices anyway).
I don't know who you are referring to but there are more of those around, Rudolf. You both aren't the only ones really. The problem is to mix quality and quantity, something Peter is very able to do as he shows us jealous people every time he reveils one of his new babies.
I use N series 4.7 uF in super E config in almost any machine that comes in my hands. Recently I received 4.7 uF 5 mm pitch Wima MKT which can be placed instead of Ecaps too. Although I don't expect much of them I am curious what they can do. MKP most of the time is too large for 5 mm holes.
NX is better but not applicable in every situation.
I checked prices at http://www.acoustic-dimension.com/ and I saw N series 1000 uF 50 V is 42 Euro. I payed around 16 Euro/piece last time I ordered and I received quite bulky 1000 uF 50 V caps ( larger than standard series so I thought they were N series ).
Exotic talking.
Well, the last mod I made to my main GC was adding two parallel 0.47ohm 3 watt carbon resistors in series with the output.
This was after extensive listening tests.
Seriously, now I've put my Kimber 4TC cables back in my system and it plays s'beautiful.
That thing made a "click" (Peter? ) and that night I've been listening to some music until 3 AM.
With a direct output from the chips to the speaker terminals I had horrible bass and I had to change from my Kimbers to Supra 2.5.
The Kimbers are high capacitance.
Now the Kimber 4TC is back and I have a sound to die for.
What was high-end is now stratospheric.
Re: Exotic talking.
I'm not surprised. How much uF are you using in your PS?
I don't understand the fascination with film caps. Most of the ones I tried sound like crap anyway.
Nuuk said:
All the GC circuits that I have built have been based on circuits that I have seen on this and the Chip Amp forum.
Also, I am not sure which one of the four Gainclones that I have built you refer to.
The VBIGC feedback resistor is 1 meg as recommended by Joe Rasmussen who came up with the original idea. You can read more on his circuit HERE.
Peter - Thank you for clearing that up.
Nuuk - Another question- Your comments on the "buffered GC" of course make me want to build one! But I could not find any explination on your site as to what the buffer accomplishes technically. In other words, what is the mechanism behind that great sound (ie changes in impedence, etc). By the way, it is a great site for a begginer like me!
Re: Re: Exotic talking.
Come on, Peter, I've got back to 1000uf some time ago.
To be more pecise, 2000uf total per rail, as I have one toroid for both channels.
Some time ago I added capacitance to the PSU, but the problem was elsewhere.
It's now fantastic, and I love my old EPOS ES11 speakers more and more each time I listen to them.
That midband and treble makes me .
The amp helps, too.
The amp helps, too.
- Chip Amps
- Exotic component choice for a GC
