Brad,
7025 would be fine. It in fact has the same gain as a 12AX7.
http://www.tubebooks.org/tubedata/HB-3/Receiving_Tubes_Part_2/7025.PDF
Ian
Ian
Brad,
Ian
Hi Ian,
The 7025 and the 12AX7A are one and the same.
-Chris
Thanks, I thought I read somewhere that they had more gain.
-Brad
Hi I have just resurected my ecc83/el84 stereo BH project. I have finished the power supply and would like to test it. I need to run it into a dummy load. Please can someone tell me what resistor value and wattage I should use to apply the correct load. I am no good at the maths so would appreciate help in this. Tube line-up is ecc83 x2 & el84 x4.Thanks.
Testing HT power Supply.
Thanks for the replies but what I should have asked is: I want to test my Baby Huey power supply in isolation from the amplifier circuit. The power supply has choke smoothing. Am I correct in thinking that I need to apply a dummy load from B+ to ground in place of the main amp circuit. I mentioned the tube line-up (2x ECC83 & 4x EL84) so that hopefully someone can tell me the expected current draw. My estimations are about 200-210mA since each of the EL84's draws 45-50mA and the ECC83 draw about 1.5mA per plate.
I am not sure but as the PS has a choke do I need to apply a dummy load in the form of a resistor? If so what value and rating should th resistor be?
Thanks.
Thanks.
Hi sharkey22,
You're going to need a very high power resistor from B+ to common. The voltage rating will also need to exceed your expected supply voltage. The approx resistance will be VB+/Iexpected= ? R.
Why would you want to run the power supply in isolation? That seems way too extreme. No one I know of does that simply due to the cost of the resistor(s). They also make dynamic loads, but that will be terribly high priced.
-Chris
-Chris
Why not use a couple of lightbulbs in series?
Current drawn depends on the voltage and the wattage of the bulbs, may take a little thinking out but Ohm's law's your friend here...
TBH--I cant see much point in testing the PSU in isolation to the main amp--Might as well finish it all up then test as a whole--Thats what most (I think) of us do....
Testing with a dummy load isnt going to tell you if there's an odd ground issue causing hum for instance...
Thank you Alastair and Anatech....As a newbie it just seemed like the thing to do but I must admit that I could not find much on the web about testing a high voltage DC PS in isolation and I am sure that is for the reasons you mention ie. it is not necessary or practical, my particular power supply was custom designed for me by Gingertube who is the co-creator of the BH amp so I imagine it is of sound design. I reckon that it would take a 1500 ohm 60W resistor which is a hefty piece and obviously impractical. I actually thought that people in the know must have some way of testing a power supply to iron out the DC and achieve the correct voltage, however I am new to valve amp building and have limited knowledge of electronic theory so at least thought I would ask. I will now press on with the amplifier construction and see what happens under real operating conditions.
Thank you for taking the time to reply. I am always impessed by and grateful for the advice of members on the forum....Much appreciated.
If you haven't built many/any HV power supplies before then there is a higher chance that you have made a "beginners mistake" somewhere. Testing the supply with a 60Watt (300V x 0.21 Amps) may just reveal that error. No, you won't get the actual circuit voltages but if the light bulb doesn't glow or the fuse blows you know you have a problem, Huston! If there is light then you can confidently move on to the next stage.
The alternative is you build the whole amp, switch it on and nothing happens. There is a whole lot more circuit to troubleshoot.
I've built a handful of tube amps and I like establishing that my PS is working before I attach the audio circuit. If your a pro whose done hundreds of 'em then you could probably skip it.
I know this thread has been dormant but I wonder how many people built this. More importly, how many thinks the BH topopogy is a way forward?
Could we restart this thread? I love the simplicicity of this design, tube availablility and wonder if it got anywhere beyond. Especially if people built it and listtened to it.
- Tubes / Valves
- EL84 Amp - Baby Huey
