tinitus said:Might that be brain adjustment...seems that the hearing is very sensitive to any kind of short term changes, where as the brain adjustment works slower and only over time adjusts, and "falls back" to "its normal reference"...whatever that might be
Ever upgrade your computer for a newer, faster one? When I do this, the newer one really seems like a speed demon - but only for about 15 minutes . Then the new one becomes the "norm".
andy_c said:Ever upgrade your computer for a newer, faster one? When I do this, the newer one really seems like a speed demon - but only for about 15 minutes . Then the new one becomes the "norm".
Try and go back to the old one after a while, then you really appreciate the new one.
john curl said:...rigorous tests do not show much, yet more open tests show plenty...
How could you rationally claim that these 'open' tests are not showing you differences of level, frequency response, clipping or listener bias, rather than some improvement in the amplifiers design?
The silly thing is that listening test have shown that when the above mentioned variables are matched between amps, nobody has yet been able to identify the amps apart - which leads one to conclude that the differences in design have no audible signature.
For the record, I would not identify myself as an objectivist - I am much more interested in exploring the ground between the two camps to see what there is to be learned, if anything. I'm still waiting for a 'subjectivitst' to present an argument that easily fall apart....
Well, certainly not an obvious hear-it-instantly difference that the audio reviewers are so fond of. But I wouldn't be so ready to jump from that to "no audible signature."
john curl said:Many of you will learn, in time, that the rigorous tests do not show much, yet more open tests show plenty. The apparent reason is how the brain works under serious decision making, especially left brain activity. But then, what do I know? I only get good reviews.
John, you are someone with a lot of experience, and I would be honored to learn some of what you have to offer. I have no problem allowing for your claim in the first sentence.
My problem is that the 'left brain/right brain' stuff is pop science, and a great simplification of something that we know very little about. Using it as an explanation does your argument an injustice, as it prevents any further understanding. The only good explanation is one that allows further exploration, and since we have no way of actually knowing what our brain is doing, the explanation is more or less fallacious.
Any answer that prevents further understanding is not an full explanation. I know we can do better than that. How did we get here in the first place?
For myself, I have had to accept that if I cannot compare the first to the second, then any conclusions I draw are on weaker grounds, sad as it may be....
One of the things that seems strange is how 'subjectivists', in most instances, will rely on technical explanations, which are verifiable objectively, and then fail to present any objective evidence for their argument. For instance: masking; or time allowed; or switches.
Why won't any subjectivists take their arguments to truly subjective grounds, like 'Clark offended the Futterman amplifiers by using them alongside the cheap Pioneer amp. The amplifier decided it would not give out the good stuff because it felt the people involved didn't deserve it."
I'm not trying to be facetious - there are arguments that could explain the different sounds of amplifiers that don't rely on objectification, if only someone could articulate them.
For instance, the relationship between partners (man/wife/whatever) is not one based on performance specs - it is based on something else, and that sort of relationship may be at play with amplifiers too.
Anyone?...
Anyone?...
john curl said:It is too difficult for me to PROVE that we ever went to the Moon, much less, whether we are continually fooling ourselves in audio evaluations.
But you don't have to, someone else already did:
http://www.badastronomy.com/bad/tv/foxapollo.html
scott wurcer said:
Any difference in DC offset between the two paths will lead to 100% detection.
Yes. In this case, with no signal and elevated level, differences in noise level led to 100% detection. The same way Stanley Lipshitz made 100% detection at the Tiefenbrunn test.
But, with signal, no chance!
Jan Didden
John,
You keep on confusing me bigtime. Just the other day you said that you don't listen to your amps, that you let others do that. Was that just a joke?
Jan Didden
KSTR said:I have read the paper Janneman mentioned, a "Boston Tea Party" event of sorts
One might argue that the result is astonishing, to say the least. I won't tell you which camp I'm in, though.
- Klaus
Come on Klaus, tell us,.... from what I've learnt here is that I must be crazy to believe my ears, then also I must be crazy to believe somebody elses ears, so join the club
Andre Visser said:
Come on Klaus, tell us,.... from what I've learnt here is that I must be crazy to believe my ears, [snip]
Really? I must have missed that post...
Jan Didden
My idea is that in the end, rigorous testing works towards showing what we DON'T listen for, when the situation is under rule. That was all I wanted to point out as a gut feeling with my yesterday posts. Thanks John for putting it in a concrete paragraph.
john curl said:[snip]It is too difficult for me to PROVE [snip]whether we are continually fooling ourselves in audio evaluations.
Actually, John, it's not that difficult. Several people in this thread have tried to suggest possibilities on how that could be advanced.
Jan Didden
Andre Visser said:cuibono, may I ask what hi-fi equipment do you use?
Of course you may - but let me say that I make no claims as to my systems sound, besides that I like it and know it well enough to want to keep building on it, and I adhere to neither objectivist nor subjectivist camps. I am solely interested in understanding why the two camps see differently, and if there is a way to bridge them. For instance - if amplifiers meeting a certain criterion do not sound different, I know what I need to build so as to never worry about my poweramps again. If there are differences between amps with similar specs, than I will continue trying to learn what it takes to make great audio. I am not interested in a ******* contest (I live on the tenth floor, and have a balcony, so I am satisfied ).
My current setup uses a PC for audio storage (all music ripped to FLAC), my soundcard is a Delta1010LT, which I have heavily modified (PSU, clock and SPDIF out). SPDIF out from there feeds Peter Daniel's NOS DAC, which I have built into a box with Carlos Filipe's AD815 preamp. This in turn feeds a pair of PD's LM3875 amps running as monoblocks. My speakers are Zaph's bargain aluminum MTM's. I also have Cambridge Audio 640C V2 CD player which I don't use much. My previous source of amplification used to be a pair of 10W 6BM8 monoblocks, designed by a good friend and well know studio gear designer. Before them I used a Creek 5350SE integrated (at one time Stereophile Class A, for what its worth). I also own a pair of SL's Pluto speakers, which are out on loan. All interconnects and cables are Jon Risch's Belden diy recipes.
I am in the process of rebuilding a Lenco TT, and am also building a pair of OB speaker using Visaton B200's and Eminence Alpha 15s. They will be biamped, with XO, FR and time alignment done on the computer.
Interestingly, you didn't ask about my room. I have moved a number of times in the last couple of years, and have had a lot of different rooms to setup in, which has been very educational. I can safely say my current room is not very good, acoustically. Its small, and I share it with my fiancee, so we are cramped. I'll be moving again soon, and will again have a dedicated listening room designed for listening pleasure...
- Do all audio amplifiers really sound the same???
