diyAudio Power Supply Circuit Board v3 illustrated build guide
"star ground", what do you mean?
The amplifier must have a Main Audio Ground.
It's where the Signal Input, Signal Output and Power all receive a common reference from.
If you don't have this wired up the audio just won't work !
Or
did you mean Protective Earth?
This makes mains equipment safer to operate.
This is what will blow the Mains fuse if there is a catastrophic mains failure inside the Chassis, that shorts to Neutral or to Chassis.
This does not stop the audio working. This does not cause hum.
Or
Did you mean A connection from Chassis to main Audio Ground?
This is what stops exposed terminals becoming Live during a catastrophic mains failure.
This too blows the mains fuse.
If you have audio and hum, then that is due to a wiring error. Not to a missing Chassis connection.
Ok …. found the source of the darn hum ….. XLR cable . Duh :rolleyes:
Now I just need to set the DC off set …. I have -9.8 and -28.7 …. I'm lust watching it as the temp goes up !
From what I've read , I need 100mv using multi-turn at R8 measured across the speaker output .
Have I understood this procedure correctly ?
Thank you , Richard
Chip amp normally refers to an amp in an integrated circuit. To set your bias you need to measure the voltage drop across your source resistors. If you used .47 ohm resistors for R118, 120 & 122 you should measure 235 mv across them. Measure across all three one at a time and average the result. After that is set, check your DC offset at the speaker output and adjust it as close to zero as you can. Normally your bias adjustment is what determines how hot your heat sink will be. The more bias current you have, the hotter your heat sink will be.
