Very interesting technique!
I am investigating how to make a new membrane for a broken B&G RD-50. The problem is I can't make a tonerprint on a 1,25 meter long piece of foil.
Long shot but maybe doable... try using linux and open linux driver for printer. Modify driver for continuous printing.
Linux-drivers.org - Linux Hardware Compatibility Lists & Linux Drivers
Just an idea
Maybe it's easier to get small quantitiy samples from a monopoly company that is watching out for new applications.
PEEK Film, Flexible Polymers, High Temperature Plastic
Someone of the more experienced persons here should do the contact, so they see that he knows what he is talking about.
http://www.rogerscorp.com/index.aspx
It looks like a long road for you to get this right.
I really admire your stamina and determination!
Have you tried to fold and bake any of the new material yet?
It doesn't need to be a perfect circuit or even a complete membran to test if that part of the process works works.
Thank you for all the kind Words.
I have been painting my living room,plastic paint,and have not had the time to Work with the AMT.
I have been fidling with the one I made,and it crackles a bit.Much more than the others I build.
Measurements and listning will show if it sounds distorted.
Bernt
Bernt
Hi Bernt
Well you are getting something like 0.3 - 0.5 %THD, which is ok but not excellent.
At what sound preasure level 1m are you measuring?
From the graph it seems that you are not band limiting the input signal .... I was thining whather the crackling noise somes from the pleats touching eachother making for shorts between neighboring voice coil lines .... could it be this?
Maybe bandlimiting the signal from say 500 Hz, might help, and also keeping track on how high volumen you are playing.
Does it also crackle with a filter and music?
Anyway they look stunning.
..... one more ? ..... have you tried a magnet system like the one e.g. Mundorf is using .... essentially two iron plates, with open slots, and some neo magnets between ..... would think them much more efficient
BR Baldin
BR Baldin
- Planars & Exotics
- Diy AMT
