meanman1964 said:Nordic,
I was looking at the part-list and came across C6 with value 2µ2 but where is X standing for?I can't find it on the board or schematic.
Hi Meanman1964,
I think you are looking at this page, right? This BOM shows a cross reference of Nordic's and my component numbers in the right hand column.
http://users.tpg.com.au/users/gerskine/dxamp/dx amplifier-12.htm
A little history. Nordic and I worked from Carlos's original schematic and unfortunately came up with slightly different results. The "X" means I could not find the component on Nordic's schematic. I always number my components top to bottom, left to right.
The cap in question is not extremely important and can be located on the Vbe board.
If you are building Nordic's boards, you might be better just sticking to information on Nordic's site.
regards
Morning Greg, thank you..
The BOM from the GB boards is here
https://www.dxamp.com/construction/DXHRII_amp_BOM_Ve.txt
It does not include the last resistor changes yet, but otherwise should be fine..
Greg is on to something... there is an (optional) 2u2 cap on the vbe multiplier... I don't use a cap there...
Hi Guys,
Daughter is sleeping and I am soldering and measuring. When she wakes I will saw some boards for speakers.
I have run into a few issues that I hope you can tell me if they are really problems or if they are fine.
1. I have 2 2k2 resistors labeled R4 and R9. These placements do not exist on the pcb board for the amp.
2. I have resistors R8 and R23 which are supposed to be 4R7 and are ohming out at 5r5. 17% more.
3. I have resistor R22 that is supposed to be 10R and is 11R1. 11% more.
4. I have R29 270R which has no place on the PCB board for the amp.
5. I have placements on the board for R10 and R19. The BOM specifies 0R22 but the multimeter says 1R, almost 500% more.
6. I have R28 which is 10k and is marked the same on the board. The BOM specifies 4.7k to 5k and to then adjust to max value before installing. I would assume the BOM means max value to be 4.7k to 5k but board and components on hand disagree with BOM.
I will search the thread again for these answers as I wait for replies and will check DXAMP website again.
Uriah
EDIT: POST #510 Takes care of R9 and R29. Is R4 the same as R9 but on the other servo board?
Uriah
On http://www.dxamp.com/construction/# there are links to Transformer wiring for single and dual transformers, troubleshooting guide, and checklist. These links all refer to the top of the page. Are they broken or do the documents exist?
Many may have seen this already but if you are building this amp and have not read the 10k or so posts about it you will find that Salesmonster has put together a WONDERFUL tutorial.
The AMP
http://picasaweb.google.com/salesmonster/DXHRIIBuild
The PSU
http://picasaweb.google.com/salesmonster/DXHRIIPowerSupplyPSUBuild
Bravo Salesmonster. These are excellent
So far I still have the questions from two posts up.
The AMP
The PSU
So Nordic,I can use the BOM of your site and do some changes of the resistors and some capacitors like the board is showingNordic said:Morning Greg, thank you..
HI Menaman, sorry, the thread showed as read, so I missed your post...
I started doing updates on the website yesterday, as i realised I have not uploaded the latest changes...
The image you have with the pink numbers is correct... only thing I would change further is a larger cap for the input... the 2u2 was a holdover from the plain DX which has a diffirent input impendance... affecting the lower bass rolloff point... If you are going to use a cheap np electrolytic... increase this value drasticaly...
Power to the zeners, use diodes of half watt or more
watt is already a big overkill....make your choice based in other factors, as how they look, how big they are...those things.
Of course you can use bigger..... will not be bad too....no problems.
Because 500 miliwatts, or 1/2 Watt is enougth.
Carlos
Carlos
Dougie085 said:Ok so this groupbuy is over I'm just curious if its possible to get the files so I can order some boards on my own?
I believe you can look at Nordic's place HERE. There you will still find some goodies. And may i say, you have never seen such a nice package.
Best regards
Ebbe
Hey Dougie, I keep on makeing a few of the boards for as long as there is a demand... obviously the price increases a little over when we did a group buy but is still hardly breaking even with the cost of providing this service...
On my website you will find free PCB layouts etc for makeing a DIY version if that is what you want too... free... no charge...a gift from me and uncle Carlos... well, mostly uncle Carlos...
Yeah I'm still trying to decide which amp to do. Only issue with the DX is that I was looking for more power then my chipamp and the DX actually does a little less in 8ohms. I was thinking about doing the Nmos350 as well so have to figure it out. I think I've decided I'm just going to get a laser printer and the stuff to make my own boards though sounds like fun and its nice being able to turn out a board in a couple hours.
Sure chipamp can put out nice peaks, but sounds like crap by the time it gets there... I can not imagine any domestic setting where you would need more power than the HRII can provide... the power rateing is deceptive... especialy whith the full spectrum of sound behaveing and being controlled right up to high level output...
PS.. even a buble jet printer works fine...
- Group Buys
- Destroyer x Amplifier DX HDII version.
