denon dvd-3910 service manual ?
I think replaces all film capacitors
This company
LCR COMPONENTS - FSCEX 1%
Example
FSCEX 1000PF 1% 250V - LCR COMPONENTS - CAPACITOR, FILM, 250V | Farnell Israel
470pf-clr components fscex-1%
1000pf-clr components fscex 1%
1200pf-clr components fscex 1%
6.8nf-clr components fscex 1%
10nf-clr components fscex 1%
I also buy at the end 14 electrolyte capacitors of
NICHICON - UKZ1H101MHM1 -100uf 50v
Meanwhile I leave the capacitors of the original 18NF
I hope that after I replace 40 parts
The sound will be worth the effort :)
A week and a half until the parts arrive
i bought All equipment for the project :)
Finally I ordered all the parts for the project
:D:D:D
op-amps
10
LM4562
capacitor
6
NICHICON
UKZ1H101MHM1TO
5
LCR COMPONENTS
2
LCR COMPONENTS
FSCEX 6800PF 1%160V
8
LCR COMPONENTS
FSCEX 470PF 1% 630V
2
LCR COMPONENTS
FSCEX 1200PF 1%160V
2
LCR COMPONENTS - FSC 160V 10000PF - CAPACITOR, 10NF, 160V
10
PANASONIC - ECA1HAM101X - CAPACITOR, 100UF, 50V
4
PANASONIC - ECA1HAM470X - CAPACITOR, 47UF, 50V
resistor
8
VISHAY DALE- 150 OHM
CPF2150R00FKE14
4
VISHAY DALE- 30 KOHM
RN55D3002FB14
I finally finished the project improved audio circuit
The DENON DVD 3910
How to replace the 60 parts
op-amps
10
LM4562
capacitor
6
NICHICON
UKZ1H101MHM1TO
5
LCR COMPONENTS
2
LCR COMPONENTS
FSCEX 6800PF 1%160V
8
LCR COMPONENTS
FSCEX 470PF 1% 630V
2
LCR COMPONENTS
FSCEX 1200PF 1%160V
2
10
4
resistor
8
CPF2150R00FKE14
4
RN55D3002FB14
Photo before and after(With this signature before)
Now he goes BURN IN
100 hours
But for starters I can tell
The sound has become much more accurate
High frequencies Snmaim much clearer
And the sound stage is much greater
Remember we talked so what OP AMP responsible stereo?
i learn from Mistake of installing OP AMP
STERIO OP AMP are C301.C302.C.303.304.C305.306
At first I changed as you recommendations the OP AMP C307-C310
I did not hear a difference
So I started to replace the OP AMPS C301-C306
When I hooked it did not sound testing
On the left
I checked what the problem OP AMP C305
Was not installed good
I fixed it
And now everything works perfect
ׂ( Before you say
The device is set
SOURCE DIRECT-ON in the menu )
So two stereo channels autput op-amp is C301-C306 100%
Learn from mistakes lol ;)
It was a lot of work
I changed about 60 parts
10 OP AMP
14 resistors
and most
Film Capacitors
Electrolyte capacitors
Good to hear that it`s working and that you hear an improvement.
Are you going to mod the PSU next?
I now begin the design of the PSU
I will use the Monfrad capacitors
Now
what a diode company you recommend for the diode bridge ?
Another question
I want to replace the MASTER CLOCK
You can bring me a recommendation for one
And a link to who sells the specific model that fits DENON DVD 3910 ?
