I have one question; Could you please elaborate on the difference(s) between "SqueezePlay" and "SqueezeLite" in the "Player" setting? I have done some googling and not found much info...
They are two different player programs. SqueezePlay is older code, SqueezeLite is a newer player.
Hi Kipeta,
Thanks for the nice software! Nice, relaxed and detailed sound.
I'm able to connect to my daphile-machine using my ipad, though i failed to connect using my the browser on my android-phone (HTC one X). Both http://daphile and http://daphile.local (also with trailing dot) cannot be resolved. Any suggestions?
Greetings,
Telrab
Android does not support mDNS. You could try to enable local DNS on your router or you just have to use IP address on Android.
New release on February 14th 2014
CHANGES:
CHANGES:
- Kernel version reverted to 3.12.5-rt7 (some HW platforms have boot problem with 3.12 RT patches rt9-rt15)
- More improvements to audio device initialization
- Stability fixes for some HW (disable C states > 1)
- Minor modifications and fixes to web UI (incl. battery indicator)
I had assumed they were two different players, however I am wondering more about the advantages/disadvantages of each. For example, does one provide better sound quality than the other? More/less file format/codec support?
With software, "newer" does not necessarily equate to "better". Any opinions on which is "better"?
Both are bit perfect. If I remember correctly, squeezeplay is limited to 44.1/16, while squeezelite can do hi-res formats.
Excellent. Thank you!
Not quite right, you were probably remembering squeezeslave (not used in Daphile) that's limited to 44.1kHz. SqueezePlay (patched up to 384kHz) supports high resolution as well as Squeezelite. SqueezePlay and Squeezelite should not have any difference on audio quality except that Squeezelite handles DSD-over-PCM a little bit better as it fills the pause gaps with DSD silence rather than PCM silence like SqueezePlay does.
Please compare the two players and give me feedback about possible differences. I'm planning to migrate eventually to Squeezelite as the default player (and probably even drop the SqueezePlay completely).
Ah, yes. Thanks for the correction!
Please don't, to me Squeezeplay seems to play a tad better.
Possibly a bit more musical, I switched between the two a few times and I always came back to Squeezeplay.
BTW, thanks for the great job you've done
Kipeta in the future Daphile can have parametric EQ?
I want to use Daphile with my new Windows Phone, any free player or low cost good & available?
HI merlin, the only one I looked at was this one, . It cost a few dollars though. Perhaps someone else can recommend a free windows phone app.... Dave
The CD ripping metadata fetch bug is now fixed. Update via your Daphile web UI or download from Daphile ? Digital Music Convenience for Audiophiles.
The CD ripping metadata fetch bug is now fixed. Update via your Daphile web UI or download from www.daphile.com.
Nice program!
Is it possible to control Daphile / Squeezeplay with a IR remote?
When i listening to music from a album or playlist I would like to have the basic control functions (pause, play, next, previous) with a simple IR remote.
Daphile does not support IR remote control. I would recommend tablet or smartphone apps for that.
I've barely managed to get Daphile working. Have had problems with right USB flash drives and when I managed to get that working, Daphile did not boot if external HDD was connected to PC while booting. But ok, that's solved and it is working.
I was wondering if somebody is using Daphile with 1GHz processor and 512MB RAM (I have Igel 5/4 Thin Client)? What's your experience with it's performance? And second, I saw that a few guys have MPD installed to, so can they summarize MPD vs Daphile regarding SQ?
P.S. Controlling Daphile with Orange Squeeze is great. Looks avesome.
- PC Based
- Daphile - Audiophile Music Server & Player OS
