Qhanghao, a month has passed from the payment but I have not received anything.
Please tell me if you've sent it and if you have a tracking number or if you have to send it again.
Best,
Alessandro
Hi Alessandro,
I was sent Dac to you on date 04 May from my friends - Italy.
You see: Pakki.it
Please wait!
Thanks!
Quanghao.
Update list sent Dac
Hi All,
I update list sent Dac until date 05 May 2015 below:
1. Kanan_s, number tracking 520825694, sent on date 27 Mar and receive 2 Apr 2015.
2. Anton Mehl, number tracking 520825685, sent on date 27 Mar and receive 30 Mar 2015.
3. Bamarek, number tracking 520825822, sent on date 01 Apr and receive 8 Apr 2015.
4. Ankltam, number tracking 520825819, sent on date 01 Apr and receive 8 Apr 2015.
5. Hego, number tracking 520825836, sent on date 01 Apr and receive 9 Apr 2015.
6. Jazzbear, number tracking 520825924, sent on date 04 Apr and receive 7 Apr 2015.
7. SebastianL, number tracking 520825955, sent on date 04 Apr and receive 10 Apr 2015.
8.Roboto, number tracking 520825941, sent on date 04 Apr and receive 8 Apr 2015.
9. Atterbud, number tracking 520825938, sent on date 04 Apr and receive 13 Apr 2015.
10. Biblos, number tracking CP120148895VN, sent on date 11 Apr 2015.
11. Sanghun Lee, number tracking 520826108, sent on date 14 Apr and receive 17 Apr 2015.
12. Rifilex, number tracking 520826111, sent on date 14 Apr and receive 27 Apr 2015.
13. Feriandas, number tracking 520826139, sent on date 15 Apr and receive 21 Apr 2015.
14. Gianluca Andreani, number tracking 520826289, sent on date 20 Apr and receive 28 Apr 2015.
15. Artur5, number tracking 520826261, sent on date 20 Apr and receive 23 Apr 2015.
16. Edgar, number tracking 520826275, sent on date 20 Apr and receive 28 Apr 2015.
17. Studiosynx, number tracking 520826598, sent on date 21 Apr and receive 24 Apr 2015.
18. Nerkap, number tracking 520826669, sent on date 27 Apr and receive 29 Apr 2015.
19. Oydes, number tracking 520826672, sent on date 27 Apr and receive 30 Apr 2015.
20. Alessandro sent on date 04 May 2015, from my friend in Italy.
Please check, pay complete and pm.
Thanks for your wait!
Quanghao.
Hi All,
Quanghao.
Examining the Lundahl output boards, I discovered a small grey Ero capacitor (C7) which is only present on one of the boards. The C3 spot is empty. Assuming the boards for each channel (L/R) should be identical, I’m a bit puzzled. Is this supposed to be so?
Quanghao,
on April 16th you wrote to me that you would send the missing C3 capacitor the next day. As of today May 5th there's still no sign of it. Did you forget all about it or did it get lost in the mail?
Thanks Akltam,
tsop Ir receiver in the DAC unit is correctly positioned and powered at +5V
In this remote control is not present control led. Is the previous version, i think....
(In this version ic on board is tm2228 that seems to be a sort of chinese version of nec chip including ceramic resonator).
Battery in the tx unit is correctly positioned and there is an ir emission, but i have only tested the phisical emission of remote with a ir tester.
Dac arrived today, first problem:
remote control does not work. Battery is inside and charge.
I tested r.c. unit with an IR receiver tester and it seems to be work.
What to do?
ok, please check it, if not ok, i will sent to you new!
please hepl me check
thanks
Hi, Quanghao and Andrea!
Could you please explain a couple of strange things in the coax spdif input schematics?
1. Isolation transformer is shorted;
What you mean ??
2. Termination resistor is not 75ohm;
3. There is a 1uF cap in series with Spdif +, which is huge (it was 0.1uF on previous version of the dac).
It can run with 0.1uF to 10uF
The problem is: when i change my socket to true 75R bnc dac does not receive spdif anymore.
it is run , no problem
thanks
you can sent all you need to my e-mail; quanghao168@yahoo.com.vn
thanks
thanks
Thanks Quanghao,
tell me what I can try further...
the problem is to discriminate whether it is the remote control failure or the control pcb in the DAC.
Thanks Quanghao,
ok, so, i sent you the new control, it is ok??
thanks
Hi All,
Quanghao.
Quanghao,
I'm not received yet the DAC.... is lost for more a month into the TNT-Spain !!!.
Bad service for the expensive price.
May be Tomorrow.....????????
I will advised you when the DAC will be at home.
Xto
Hi SebastianL
yes, im sory , but this cap very small.
may be i can sent to you 10 $ for you, you can buy it hepl me,
becuase the shipping expensive for this cap!
You are ok ??
I understand. If you just tell me the specifications of the capacitor: how many μF and voltage?
I'll be OK. Can't be very expensive.
this cap :
0.1uf / 100VAC/160VDC, MKP-1837, Metalized Polypropylene, 1% Tolerance, 9mm W x 11mm H x 7.5mm L, Each
and link
Vishay R. Film Caps
thank your hepl!
Quanghao
Hi Hego,
I think you should contact TNT in your country directly to check the parcel. Hope everything goes well for you.
Thank's akltam ... the DAC is today (in the end) at home!!!
It sound very well, but my DIY analog source is still better, for a normal CD PCM 44Khz, of course.
This weekend I will have a few time to try it.
Regards.
Which jumpers I should remove to using the DAC-END R DAC in voltage-mode output, connecting directly to the amplifier with using the digital volume control in the DAC?
Thanx for any help
The Dac with Ll1684 alleway work voltage mode output.
You can conect to amli.
If Dac not have Iv stage (ll1684) or other.
You can not conect direct to amp. Your amli is died.
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board - version 2 - group 2
