D-Noizator: a magic active noise canceller to retrofit & upgrade any 317-based V.Reg.
That's nice and low.
I noticed on the NoNoiser that the base of the ADJ pin BJT is pretty sensitive. I had a hard time measuring with DMM across the coupling cap. Worked better to measure GND-base of ADJ pin BJT and GND-collector of denoiser BJT and subtract the values to get the voltage across the coupling cap. At least in my case.
Reactions: 1 user
