Class-A Opamps
ampguru:
was that the SE/NE540?
i think it had two outputs for drving complementary output devices, maybe some current limit programming.
very fuzzy memory.
but it was an op amp like gain stage, not a buffer
mlloyd1
amplifierguru said:
Kanwar,
There was a Class A Opamp produced in the 80's although I can't recall whose it was, maybe Signetics or AD...
Workhorse said:
Hi everyone,
Has anybody came across Class-A opamps?.
Do they really exist.
Does there is a way in which a regular class-AB opamp could be converted to Class-A opamp.
waiting for replies.......
Kanwar:) ;)
Generally, why is almost no Chip OP-amplifier in Class A
I think is
when you go for an IC ( and not discrete ) Operational amplifier
- you want it simple
- you want it as low power supply as possible
- you might want to build a great number of identical devices
If you want to find TRUE Class A OP-amps, you have to go for discrete.
Like this one by Graham Maynard:
Hi-Fi Preamplifier by Graham Maynard
Hi lineup,
There are many modern op amps that operate enough standing output stage current that they will operate Class A into av high Z load - so they can be lightly loaded with a discrete buffer stage.
Class A may be a goal in itself in low power and preamps but in power amps it's generally a wasteful fallback position.
Greg
The simple answer is: If the "industry" wants class A opamps they would be designed and manufactured :nod: The truth is that the industry is rather satisfied with the present types.
Kanwar, have you thought of that pretty many opamps really do run in class A for not too heavy loads.
Two good class B examples are LM358 and LM324 :bigeyes:
This is a
TRUE Class A operational amplifier
It is designed and commercially used
by
Bryston Limited, located in Canada
lineup said:
This is a
by
Similar to the line stage of a Hafler DH101/110, except Hafler doesn't include the complimentary EF output stage which really improves output drive. BTW the EF is class AB.
I wonder, what is the purpose of the 47p capacitors? the time constant with the 150R is 7ns.
Those caps are a mystery.
But here I found another high quality discrete OP-Amp
using same small value cap, in addition to another high freq filter.
I am sure it is some compensation.
Compensation caps are generally in size of pF.
Re: Re: Class-A Opamps
Too bad I found your post AFTER I built a small preamp using a 324 :eek:
But thank your for that valuable information.
I will be adding 10k ohm resistors now to all four amps on my chip.
*I thought I was hearing crossover distortion, and I biased my big amp to 300mA (the one the 324 was driving) thinking it was the problem and got no difference, so backed it back down. After doing a test listening to the amp without the 324, the distortion is gone.
I'll be changing the chip soon.
